i downloaded the zed-ros2-examples and when trying to run the zed_multi_camera launch i get
ros2 launch zed_multi_camera zed_multi_camera.launch.py \
cam_names:=‘[zed_left,zed_right]’
cam_models:=‘[zed2i,zed2i]’
cam_serials:=‘[35014157,39453324]’
[INFO] [launch]: All log files can be found below /root/.ros/log/2025-12-29-14-29-37-784393-ubuntu3-134
[INFO] [launch.user]: * Starting Composable node container: /zed_multi/zed_multi_container
[ERROR] [launch]: Caught exception in launch (see debug for traceback): ‘NoneType’ object is not iterablei tried running it with debug and got
–debug
[DEBUG] [launch.launch_context]: emitting event synchronously: ‘launch.events.IncludeLaunchDescription’
[INFO] [launch]: All log files can be found below /root/.ros/log/2025-12-29-14-36-28-466291-ubuntu3-143
[INFO] [launch]: Default logging verbosity is set to DEBUG
[DEBUG] [launch]: processing event: ‘<launch.events.include_launch_description.IncludeLaunchDescription object at 0xffff96874610>’
[DEBUG] [launch]: processing event: ‘<launch.events.include_launch_description.IncludeLaunchDescription object at 0xffff96874610>’ ✓ ‘<launch.event_handlers.on_include_launch_description.OnIncludeLaunchDescription object at 0xffff968742b0>’
Executing <Task finished name=‘Task-2’ coro=<LaunchService._process_one_event() done, defined at /opt/ros/humble/install/lib/python3.8/site-packages/launch/launch_service.py:228> exception=TypeError(“‘NoneType’ object is not iterable”) created at /opt/ros/humble/install/lib/python3.8/site-packages/launch/launch_service.py:318> took 0.310 seconds
[DEBUG] [launch]: An exception was raised in an async action/event
[DEBUG] [launch]: Traceback (most recent call last):
File “/opt/ros/humble/install/lib/python3.8/site-packages/launch/launch_service.py”, line 336, in run_async
raise completed_tasks_exceptions[0]
File “/opt/ros/humble/install/lib/python3.8/site-packages/launch/launch_service.py”, line 230, in _process_one_event
await self.__process_event(next_event)
File “/opt/ros/humble/install/lib/python3.8/site-packages/launch/launch_service.py”, line 250, in __process_event
visit_all_entities_and_collect_futures(entity, self.__context))
File “/opt/ros/humble/install/lib/python3.8/site-packages/launch/utilities/visit_all_entities_and_collect_futures_impl.py”, line 45, in visit_all_entities_and_collect_futures
futures_to_return += visit_all_entities_and_collect_futures(sub_entity, context)
[Previous line repeated 2 more times]
File “/opt/ros/humble/install/lib/python3.8/site-packages/launch/utilities/visit_all_entities_and_collect_futures_impl.py”, line 38, in visit_all_entities_and_collect_futures
sub_entities = entity.visit(context)
File “/opt/ros/humble/install/lib/python3.8/site-packages/launch/action.py”, line 108, in visit
return self.execute(context)
File “/opt/ros/humble/install/lib/python3.8/site-packages/launch_ros/actions/composable_node_container.py”, line 83, in execute
for node_object in self.__composable_node_descriptions:
TypeError: ‘NoneType’ object is not iterable[ERROR] [launch]: Caught exception in launch (see debug for traceback): ‘NoneType’ object is not iterable
[DEBUG] [launch.launch_context]: emitting event: ‘launch.events.Shutdown’
[DEBUG] [launch]: processing event: ‘<launch.events.shutdown.Shutdown object at 0xffff96874280>’
[DEBUG] [launch]: processing event: ‘<launch.events.shutdown.Shutdown object at 0xffff96874280>’ ✓ ‘<launch.event_handlers.on_shutdown.OnShutdown object at 0xffff968744c0>’might there be a bug in the launch?
this one works correctly
ros2 launch zed_wrapper zed_camera.launch.py
camera_model:=zed2i
container_name:=zed_container
serial_number:=$$SERIAL"; \
