Using External FOG-IMU with ZED2i for Better EKF Accuracy – Frame Alignment Issue in robot_localization (ROS2)
To improve pose accuracy and reduce drift during rotation, I’m trying to replace the ZED2i’s built-in IMU with my own FOG-IMU (Fiber-Optic Gyroscope). I’m using ROS 2 (Humble) and the robot_localization package for sensor fusion with an Extended Kalman Filter (EKF). Here’s what I did:
  1. Set imu_fusion to false in common_stereo.yaml.
  2. Launched ZED node with: ros2 launch zed_wrapper zed_camera.launch.py camera_model:=zed2i
  3. Created a custom ROS2 node to publish my FOG-IMU data at /Fog_imu/imu_data.
  4. Launched EKF fusion node: ros2 launch ekf_fusion.launch.py
# ekf_fusion.launch.py
from launch import LaunchDescription
from launch_ros.actions import Node
def generate_launch_description():
    return LaunchDescription([
        # Static transform: imu_link → base_link
        Node(
            package='tf2_ros',
            executable='static_transform_publisher',
            name='imu_to_base',
            arguments=['0', '0', '0', '0', '0', '0', 'base_link', 'imu_link'],
        # EKF node
        Node(
            package='robot_localization',
            executable='ekf_node',
            name='ekf_filter',
            output='screen',
            parameters=[{
                'use_sim_time': False,
                'frequency': 50.0,
                'sensor_timeout': 0.1,
                'two_d_mode': False,
                'publish_tf': True,
                'transform_tolerance': 0.1,
                'pose0': '/zed/zed_node/pose_with_covariance',
                'pose0_config': [
                    True,  True,  True,   # X, Y, Z
                    False, False, False,   # roll, pitch, yaw
                    False, False, False,   # VX, VY, VZ
                    False, False, False,  # VRoll, VPitch, VYaw
                    False, False, False,   # AX, AY, AZ
                'pose0_differential': False,
                'pose0_queue_size': 5,
                'imu0': '/Fog_imu/imu_data',
                'imu0_config': [
                    False, False, False,  # X, Y, Z
                    True,  True,  True,   # roll, pitch, yaw
                    True,  True,  True,   # VRoll, VPitch, VYaw
                'imu0_differential': False,
                'imu0_queue_size': 5,
                'odom0': '/zed/zed_node/odom',
                'odom0_config': [
                    False, False, False
                'odom0_differential': False,
                'odom0_queue_size': 10
  1. Monitored the output from /odometry/filtered.
Platform Specs:
  • Jetson Orin NX 8GB
  • ROS 2: Humble
  • ZED SDK: 5.0.1 (L4T 36.4)
:warning: Problem Encountered
I noticed that:
  • /zed/zed_node/pose_with_covariance has frame_id = "map"
  • /odometry/filtered has frame_id = "odom"
As a result, /odometry/filtered outputs nearly identical values to /zed/zed_node/odom, which is not what I expected.
To address this, I duplicated the topic /zed/zed_node/pose_with_covariance into a new one /zed/zed_node/pose_cov_for_ekf, but changed the frame_id to "odom". Feeding this to the EKF seems to work: the /odometry/filtered position aligns more closely with the corrected /pose.
However, as a ROS beginner, I’m unsure whether this is the correct approach. Should I have instead set world_frame = "map" in robot_localization and kept the original topic? What is the recommended way to handle this kind of frame inconsistency?
:puzzle_piece: Additional Context
Due to the hardware configuration, the ZED2i is mounted at a 45° upward angle relative to the mobile robot. When the robot moves forward, the /zed/zed_node/odom Z-position drifts negatively (goes downward), which is incorrect. But the /zed/zed_node/pose output stays aligned with the true vertical axis. This is likely due to set_gravity_as_origin = true, which uses IMU gravity information to keep the orientation aligned with the real-world Z-axis.
Hi @ZaWaLuDo77
Welcome to the Stereolabs community
This is not correct. The pose topic is for localization and can jump when loop closures happen. You must use the odom topic.
Have you added this tilt information to the URDF?
I recommend you read the robot integration guide for more information.
Hi Myzhar:
Thank you for the clarification !
Yes, I originally used the /odom topic, but the result was almost the same as when using the /pose topic (at least before any loop closure occurred). The reason I chose the /pose topic was to take advantage of set_gravity_as_origin = true, which helps keep the Z-axis aligned with gravity.
If I want to use the /odom topic instead, do I need to manually implement a method that uses gravity information from the FOG-IMU to rotate the odometry’s XYZ into alignment with the world frame?
Thank you for the suggestion! I’ll work on adding the tilt information into the URDF.
This parameter is also affecting the /odom/ topic.
However, I tried visualizing the trajectory directly using Three.js by extracting and plotting the following data on a canvas:
  • Blue: /zed/zed_node/pose (pose: x, y, z)
  • Orange: /zed/zed_node/odom (pose: x, y, z)
  • Green: /odometry/filtered (pose: x, y, z)
In my experiment, I moved the robot by roughly the same distance across tests.
I observed the following:
So from what I’ve seen, the set_gravity_as_origin setting significantly affects the /pose, but doesn’t seem to visually influence /odom in the same way in my use case. Let me know if I misunderstood something here.
Hi @ZaWaLuDo77,
Could you please share the common_stereo.yaml config and the zed2i.yaml config so that we can try and reproduce this issue?
common_stereo.yaml
# config/common_stereo.yaml
# Common parameters to Stereolabs ZED Stereo cameras
    ros__parameters:
        use_sim_time: false # Set to `true` only if there is a publisher for the simulated clock to the `/clock` topic. Normally used in simulation mode.
        simulation:
            sim_address: '127.0.0.1' # The connection address of the simulation server. See the documentation of the supported simulation plugins for more information.
        svo:
            use_svo_timestamps: true # Use the SVO timestamps to publish data. If false, data will be published at the system time.
            publish_svo_clock: false # [overwritten by launch file options] When use_svo_timestamps is true allows to publish the SVO clock to the `/clock` topic. This is useful for synchronous rosbag playback.
            svo_loop: false # Enable loop mode when using an SVO as input source. NOTE: ignored if SVO timestamping is used
            svo_realtime: false # if true the SVO will be played trying to respect the original framerate eventually skipping frames, otherwise every frame will be processed respecting the `pub_frame_rate` setting
        general:
            camera_timeout_sec: 5
            camera_max_reconnect: 5
            camera_flip: false
            self_calib: true # Enable the self-calibration process at camera opening. See https://www.stereolabs.com/docs/api/structsl_1_1InitParameters.html#affeaa06cfc1d849e311e484ceb8edcc5
            serial_number: 0 # overwritten by launch file
            pub_resolution: 'CUSTOM' # The resolution used for image and depth map publishing. 'NATIVE' to use the same `general.grab_resolution` - `CUSTOM` to apply the `general.pub_downscale_factor` downscale factory to reduce bandwidth in transmission
            pub_frame_rate: 30.0 # frequency of publishing of visual images and depth images
            enable_image_validity_check: 1 # [SDK5 required] Sets the image validity check. If set to 1, the SDK will check if the frames are valid before processing.
            gpu_id: -1
            optional_opencv_calibration_file: '' # Optional path where the ZED SDK can find a file containing the calibration information of the camera computed by OpenCV. Read the ZED SDK documentation for more information: https://www.stereolabs.com/docs/api/structsl_1_1InitParameters.html#a9eab2753374ef3baec1d31960859ba19
            async_image_retrieval: false # Enable/disable the asynchronous image retrieval - Note: enable only to improve SVO recording performance
        video:
            saturation: 4 # [DYNAMIC]
            sharpness: 4 # [DYNAMIC]
            gamma: 8 # [DYNAMIC]
            exposure: 80 # [DYNAMIC]
            gain: 80 # [DYNAMIC]
            whitebalance_temperature: 42 # [DYNAMIC] - [28,65] x100 - works only if `auto_whitebalance` is false
        sensors:
            publish_imu_tf: false # [overwritten by launch file options] enable/disable the IMU TF broadcasting
            sensors_pub_rate: 100. # frequency of publishing of sensors data. MAX: 400. - MIN: grab rate
        region_of_interest:
            automatic_roi: false # Enable the automatic ROI generation to automatically detect part of the robot in the FoV and remove them from the processing. Note: if enabled the value of `manual_polygon` is ignored
            #manual_polygon: '[[0.25,0.33],[0.75,0.33],[0.75,0.5],[0.5,0.75],[0.25,0.5]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
            apply_to_positional_tracking: true # Apply ROI to positional tracking processing
            apply_to_spatial_mapping: true # Apply ROI to spatial mapping processing
        depth:
            depth_mode: 'NEURAL_LIGHT' # Matches the ZED SDK setting: 'NONE', 'PERFORMANCE', 'QUALITY', 'ULTRA', 'NEURAL', 'NEURAL_PLUS' - Note: if 'NONE' all the modules that requires depth extraction are disabled by default (Pos. Tracking, Obj. Detection, Mapping, ...)
            depth_stabilization: 30 # Forces positional tracking to start if major than 0 - Range: [0,100]
            point_cloud_freq: 15.0 # [DYNAMIC] - frequency of the pointcloud publishing (equal or less to `pub_frame_rate` value)
            point_cloud_res: 'COMPACT' # The resolution used for point cloud publishing - 'COMPACT'-Standard resolution. Optimizes processing and bandwidth, 'REDUCED'-Half resolution. Low processing and bandwidth requirements
            depth_confidence: 95 # [DYNAMIC]
        pos_tracking:
            pos_tracking_mode: 'GEN_1' # Matches the ZED SDK setting: 'GEN_1', 'GEN_2'
            publish_tf: true # [overwritten by launch file options] publish `odom -> camera_link` TF
            publish_map_tf: true # [overwritten by launch file options] publish `map -> odom` TF
            map_frame: 'map'
            odometry_frame: 'odom'
            area_memory_db_path: ''
            reset_pose_with_svo_loop: true # Reset the camera pose the `initial_base_pose` when the SVO loop is enabled and the SVO playback reaches the end of the file.
        gnss_fusion:
            gnss_fusion_enabled: false # fuse 'sensor_msg/NavSatFix' message information into pose data
            gnss_fix_topic: '/fix' # Name of the GNSS topic of type NavSatFix to subscribe [Default: '/gps/fix']
            target_translation_uncertainty: 10e-2 # defines the target translation uncertainty at which the calibration process between GNSS and VIO concludes. By default, the threshold is set at 10 centimeters.
            target_yaw_uncertainty: 1e-2 # defines the target yaw uncertainty at which the calibration process between GNSS and VIO concludes. The unit of this parameter is in radian. By default, the threshold is set at 0.1 radians.
        mapping:
            mapping_enabled: false # True to enable mapping and fused point cloud pubblication
        object_detection:
            model: 'MULTI_CLASS_BOX_FAST' # 'MULTI_CLASS_BOX_FAST', 'MULTI_CLASS_BOX_MEDIUM', 'MULTI_CLASS_BOX_ACCURATE', 'PERSON_HEAD_BOX_FAST', 'PERSON_HEAD_BOX_ACCURATE', 'CUSTOM_YOLOLIKE_BOX_OBJECTS'
            custom_onnx_file: '' # Only used if 'model' is 'CUSTOM_YOLOLIKE_BOX_OBJECTS'. Path to the YOLO-like ONNX file for custom object detection directly performed by the ZED SDK.
            custom_onnx_input_size: 512 # Resolution used with the YOLO-like ONNX file. For example, 512 means a input tensor '1x3x512x512'
            custom_label_yaml: '' # Only used if 'model' is 'CUSTOM_YOLOLIKE_BOX_OBJECTS'. Path to the COCO-like YAML file storing the custom class labels.
            confidence_threshold: 75.0 # [DYNAMIC] - Minimum value of the detection confidence of an object [0,99]
            mc_people: true # [DYNAMIC] - Enable/disable the detection of persons for 'MULTI_CLASS_X' models
        body_tracking:
            body_format: 'BODY_38' # 'BODY_18','BODY_34','BODY_38','BODY_70'
        stream_server:
            bitrate: 12500 # [1000 - 60000] Streaming bitrate (in Kbits/s) used for streaming. See https://www.stereolabs.com/docs/api/structsl_1_1StreamingParameters.html#a873ba9440e3e9786eb1476a3bfa536d0
            target_framerate: 0 # Framerate for the streaming output. This framerate must be below or equal to the camera framerate. Allowed framerates are 15, 30, 60 or 100 if possible. Any other values will be discarded and camera FPS will be taken.
            thread_sched_policy: 'SCHED_BATCH' # 'SCHED_OTHER', 'SCHED_BATCH', 'SCHED_FIFO', 'SCHED_RR' - NOTE: 'SCHED_FIFO' and 'SCHED_RR' require 'sudo'
        debug:
            sdk_verbose_log_file: '' # Path to the file where the ZED SDK will log its messages. If empty, no file will be created. The log level can be set using the `sdk_verbose` parameter.
            debug_common: false
            debug_sim: false
            debug_video_depth: false
            debug_camera_controls: false
            debug_point_cloud: false
            debug_gnss: false
            debug_sensors: false
            debug_mapping: false
            debug_terrain_mapping: false
            debug_object_detection: false
            debug_body_tracking: false
            debug_roi: false
            debug_streaming: false
            debug_advanced: false
zed2i.yaml
# config/zed2i_yaml
# Parameters for Stereolabs zed2i camera
    ros__parameters:
        general:
            camera_model: 'zed2i'
            camera_name: 'zed2i' # overwritten by launch file
            grab_resolution: 'HD720' # The native camera grab resolution. 'HD2K', 'HD1080', 'HD720', 'VGA', 'AUTO'
            grab_frame_rate: 30 # ZED SDK internal grabbing rate
        depth:
            min_depth: 0.3 # Min: 0.3, Max: 3.0
            max_depth: 40.0 # Max: 40.0
When launching ekf_fusion.launch.py using ros2 launch, the resulting TF tree appears as shown in the figure. In addition, I will also evaluate the configuration with the ZED IMU disabled by setting imu_fusion: false.
frames_2025-05-26_19.07.23.pdf (16.1 KB)
Hi @ZaWaLuDo77,
We have been able to test your configuration and have not been able to reproduce on our side. Can you confirm that you can see the difference in results from setting the set_gravity_as_origin from a clean build of the zed-ros2-wrapper without any modifications?
I’d like to share a photo showing the mounting setup of the ZED2i and the FOG-IMU.
The ZED2i is installed at a 45-degree upward tilt relative to the robot’s base frame.
As a result, when the robot moves forward in a straight line, I observe that the z value in the /odom topic’s pose keeps decreasing — likely due to the camera’s tilted mounting angle.
Hi @ZaWaLuDo77
The TF tree is wrong. If you are using an external Kalman Filter, then the zed_camera_link must be a child of base_link and you must disable the parameter publish_tf of the ZED Node.
This is explained in the Robot Integration documentation.
Thank you for pointing out the issue!
Currently, I’ve made the following adjustments without using the URDF (since my motors don’t have encoders, and I only need to configure the FOG-IMU and ZED2i), and it seems the problem is now resolved:
In common_stereo.yaml (Snippet code):
pos_tracking:
    imu_fusion: false
    publish_tf: false
    map_frame: 'map'
    odometry_frame: 'base_link' # original : odom !!
    area_memory: false
    area_file_path: '~/test_area_memory.area'
In ekf_fusion.launch.py:
        # Static transform: base_link → imu_link
        # IMU is mounted at the center of the robot base
        Node(
            package='tf2_ros',
            name='base_to_imu',
            arguments=['0', '0', '0.1', '0', '0', '0', 'base_link', 'imu_link'],
        # Static transform: base_link → zed_camera_center
        # ZED camera is mounted forward of the robot base
        Node(
            package='tf2_ros',
            name='base_to_zed',
            arguments=['0.2', '0', '0.15', '0', '0', '0', 'base_link', 'zed_camera_link'],
        # EKF node
        Node(
            name='ekf_filter',
            output='screen',
            parameters=[{
                'frequency': 100.0,
                'publish_tf': True,
                'publish_acceleration': False,
                # Frame configuration
                'map_frame': 'map',
                'odom_frame': 'odom',
                'base_link_frame': 'base_link',
                'world_frame': 'odom',
                # IMU configuration
                'imu0_config': [
                    False, False, False,  # position (x, y, z) - not used from IMU
                    True,  True,  True,   # orientation (roll, pitch, yaw) - use all
                    False, False, False,  # linear velocity (vx, vy, vz) - not from IMU
                    True,  True,  True,   # angular velocity (vroll, vpitch, vyaw) - use all
                    False, False, False,   # linear acceleration (ax, ay, az) - use all for better fusion
                'imu0_relative': False,
                'imu0_queue_size': 50,
                'imu0_remove_gravitational_acceleration': True,
                # ZED odometry configuration
                'odom0_config': [
                    True,  True,  True,   # position (x, y, z) - use all
                    False, False, False,    # orientation (roll, pitch, yaw) - only yaw
                    False, False, False,   # linear velocity (vx, vy, vz) - x,y only
                    False, False, False,    # angular velocity (vroll, vpitch, vyaw) - only vyaw
                    False, False, False   # linear acceleration (ax, ay, az) - not from odom
                'odom0_relative': False,
                'odom0_queue_size': 10,
                # Process noise covariance (increase for faster convergence if needed)
                'process_noise_covariance': [
                    0.05, 0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,
                    0.0,  0.05, 0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,
                    0.0,  0.0,  0.06, 0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,
                    0.0,  0.0,  0.0,  0.03, 0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,
                    0.0,  0.0,  0.0,  0.0,  0.03, 0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,
                    0.0,  0.0,  0.0,  0.0,  0.0,  0.06, 0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,
                    0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.025,0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,
                    0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.025,0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,
                    0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.04, 0.0,  0.0,  0.0,  0.0,  0.0,  0.0,
                    0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.01, 0.0,  0.0,  0.0,  0.0,  0.0,
                    0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.01, 0.0,  0.0,  0.0,  0.0,
                    0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.02, 0.0,  0.0,  0.0,
                    0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.01, 0.0,  0.0,
                    0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.01, 0.0,
                    0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.0,  0.015
TF Tree (see tf2_tree.png):
frames_2025-09-17_11.11.43.pdf (16.0 KB)
Now, zed_camera_link is a child of base_link, which matches the expected setup when using an external Kalman filter.
After these changes, the /odometry/filtered output now behaves as expected.
However, I’ve noticed some noticeable drift caused by the integration of angular velocity over time, which seems to accumulate — but that’s a separate topic.
Thanks again for your help!
