Connection issues ZED_Multi ROS2 node
Hi all,
We are currently doing several tests with a largescale machine for data collection. We have one mono camera and four stereo cameras. Data collection with the mono camera works pretty well, but when using the ROS2 ZED multi node we have several issues. When launching the node, we get often the following output:
[component_container_isolated-3] [ERROR] [1751015028.615011015] [zed_multi.zed_front_left]: Connection issue detected: CAMERA REBOOTING
[component_container_isolated-3] (Argus) Error FileOperationFailed: Failed socket read: Connection reset by peer (in src/rpc/socket/common/SocketUtils.cpp, function readSocket(), line 79)
[component_container_isolated-3] (Argus) Error FileOperationFailed: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 277)
[component_container_isolated-3] (Argus) Error FileOperationFailed: Receive worker failure, notifying 5 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 350)
[component_container_isolated-3] (Argus) Error FileOperationFailed: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
[component_container_isolated-3] (Argus) Error FileOperationFailed: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
[component_container_isolated-3] (Argus) Error InvalidState: Argus client is exiting with 4 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
[component_container_isolated-3] (Argus) Error FileOperationFailed: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 379)
[component_container_isolated-3] (Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
[component_container_isolated-3] (Argus) Error InvalidState: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
[ERROR] [component_container_isolated-3]: process has died [pid 4503, exit code -11, cmd '/opt/ros/humble/lib/rclcpp_components/component_container_isolated --ros-args --log-level info --ros-args -r __node:=zed_multi_container -r __ns:=/zed_multi'].
Using the command ZED_Explorer -a show all four stereo camera. In the attachement you can find the json file from the ZED_Diagnostics.
ZED_Diagnostic_Results.json (27.1 KB)
Have you an idea, what the reason could be?
Many thanks for your help.
Hi @robinvetsch
What’s the host that you are using?
What power mode?
Is jetson_clocks.sh running?
Hi @Myzhar,
We are using a jetson Orin AGX 64GB. The powermode is MAXN and jetson_clocks is running.
We have installed the newest version of SDK 5.0.2 but the problem occured also in earlier versions
Hi @Myzhar ,
We are currently experiencing the exact same issue under the same conditions.
We have also tried to use cam_ids instead of cam_serials, but the issue persists.
We’ve noted your reports and opened a bug for the ZED SDK team.
