ZED X Fakra lifespan
I have noticed that after a few mating cycles of the Fakra connector and the ZED X cam, the performance of the cable deteriorates.
After some research I found out that the manufacturer of the fakra cable rates their cable for only 25 mating cycles.
Do you have any information how many mating cycles the Zed Camera can do?
Hi @MM10
normally FAKRA connections are not designed for continuous connection/disconnection operations.
I can check with the team for this specific information.
Thanks for the feedback.
It would be good to know how many cycles a camera is good for.
The connector and the plug are certified for minimum 100 cycles
