When changing depth_mode to any setting other than NONE, all data stop published in the corresponding topic, even /zed_node/left/image_rect_color or /zed_node/imu/data which is published when depth_mode=NONE.
As a new user, I cannot upload the yaml file.
I post my setting as follow:
# config/common_yaml
# Common parameters to Stereolabs ZED X
# https://www.stereolabs.com/docs/video/camera-controls
# https://github.com/stereolabs/zed-ros2-wrapper/blob/master/zed_wrapper/config/common.yaml <- use this one as reference
# Note: the parameter svo_file is passed as exe argumet
ros__parameters:
general:
camera_model: "zedx"
camera_name: "zedx" # usually overwritten by launch file
grab_resolution: 'HD1080' # The native camera grab resolution. 'SVGA', 'HD1080', 'HD1200'
grab_frame_rate: 60 # ZED SDK internal grabbing rate
svo_file: "" # usually overwritten by launch file
svo_loop: false # Enable loop mode when using an SVO as input source
camera_timeout_sec: 5
camera_max_reconnect: 5
camera_flip: false
zed_id: 0 # IMPORTANT: to be used in simulation to distinguish individual cameras im multi-camera configurations - usually overwritten by launch file
serial_number: 0 # usually overwritten by launch file
pub_resolution: 'CUSTOM' # The resolution used for output. 'NATIVE' to use the same `general.grab_resolution` - `CUSTOM` to apply the `general.pub_downscale_factor` downscale factory to reduce bandwidth in transmission
pub_frame_rate: 60.0 # [DYNAMIC] - frequency of publishing of visual images and depth images
gpu_id: -1
region_of_interest: '[]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
#region_of_interest: '[[0.25,0.33],[0.75,0.33],[0.75,0.5],[0.5,0.75],[0.25,0.5]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
#region_of_interest: '[[0.25,0.25],[0.75,0.25],[0.75,0.75],[0.25,0.75]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
#region_of_interest: '[[0.5,0.25],[0.75,0.5],[0.5,0.75],[0.25,0.5]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
sdk_verbose: 1
video:
saturation: 4 # [DYNAMIC]
sharpness: 4 # [DYNAMIC]
gamma: 8 # [DYNAMIC]
exposure: 80 # [DYNAMIC]
gain: 80 # [DYNAMIC]
whitebalance_temperature: 42 # [DYNAMIC] - [28,65] works only if `auto_whitebalance` is false
qos_history: 1 # '1': KEEP_LAST - '2': KEEP_ALL
qos_depth: 1 # Queue size if using KEEP_LAST
qos_reliability: 1 # '1': RELIABLE - '2': BEST_EFFORT -
qos_durability: 2 # '1': TRANSIENT_LOCAL - '2': VOLATILE
depth:
depth_mode: "PERFORMANCE" # Matches the ZED SDK setting: 'NONE', 'PERFORMANCE', 'QUALITY', 'ULTRA', 'NEURAL', 'NEURAL_PLUS' - Note: if 'NONE' all the modules that requires depth extraction are disabled by default (Pos. Tracking, Obj. Detection, Mapping, ...)
depth_stabilization: 1 # Forces positional tracking to start if major than 0 - Range: [0,100]
point_cloud_freq: 10.0 # [DYNAMIC] - frequency of the pointcloud publishing (equal or less to `grab_frame_rate` value)
depth_confidence: 50 # [DYNAMIC]
pos_tracking:
pos_tracking_mode: "GEN_2" # Matches the ZED SDK setting: 'GEN_1', 'GEN_2'
publish_tf: true # [usually overwritten by launch file] publish `odom -> camera_link` TF
publish_map_tf: true # [usually overwritten by launch file] publish `map -> odom` TF
map_frame: "map"
odometry_frame: "odom"
area_memory_db_path: ""
gnss_fusion:
gnss_fusion_enabled: false # fuse 'sensor_msg/NavSatFix' message information into pose data
gnss_fix_topic: "/gps/fix" # Name of the GNSS topic of type NavSatFix to subscribe [Default: "/gps/fix"]
gnss_init_distance: 5.0 # The minimum distance traveled by the robot required to initilize the GNSS fusion
gnss_frame: "gnss_link" # [usually overwritten by launch file] The TF frame of the GNSS sensor
mapping:
mapping_enabled: false # True to enable mapping and fused point cloud pubblication
clicked_point_topic: "/clicked_point" # Topic published by Rviz when a point of the cloud is clicked. Used for plane detection
sensors:
sensors_pub_rate: 200. # frequency of publishing of sensors data. MAX: 400. - MIN: grab rate
object_detection:
model: 'MULTI_CLASS_BOX_MEDIUM' # 'MULTI_CLASS_BOX_FAST', 'MULTI_CLASS_BOX_MEDIUM', 'MULTI_CLASS_BOX_ACCURATE', 'PERSON_HEAD_BOX_FAST', 'PERSON_HEAD_BOX_ACCURATE'
confidence_threshold: 50.0 # [DYNAMIC] - Minimum value of the detection confidence of an object [0,99]
mc_people: false # [DYNAMIC] - Enable/disable the detection of persons for 'MULTI_CLASS_X' models
body_tracking:
body_format: 'BODY_38' # 'BODY_18','BODY_34','BODY_38','BODY_70'
use_sim_time: false # EXPERIMENTAL (only for development) - Set to true to enable SIMULATION mode #
sim_address: '192.168.1.90' # EXPERIMENTAL (only for development) - The local address of the machine running the simulator
debug:
debug_common: false
debug_video_depth: false
debug_camera_controls: false
debug_point_cloud: false
debug_positional_tracking: true
debug_gnss: false
debug_sensors: false
debug_mapping : false
debug_terrain_mapping : false
debug_object_detection : false
debug_body_tracking : false
Please let me know if any suggestions or questions.
Thank you for your precious time on this.
