I’m currently working on a school project where I’m creating an autonomous robot using a 2D LiDAR and a ZEDX camera. I have my robot state publisher and robot urdf file set correctly, but what resources or help can I get on how to now add/include the ZEDX xacro files to my existing robot? I’m having trouble with the ROS2 Navigation stack (Nav2) due to TF tree issues when I try using both the ZEDX and my robot. Thanks!
Attached is my frames output from ROS2. The error we get is saying there is no TF from ‘map’ to ‘base_link’ but after monitoring the TF’s any TF between ‘map’ and the other frame have this error. For example ‘Zed_camera_link’ and ‘map’ also have the same error. However, when we run the ROS2 Nav2 stack ‘map’ and ‘base_link’ is what stops the robot from working correctly.
frames.pdf (15.4 KB)
