TF-Tree configuration for multi camera setup
HI,
I am a little unsure about the correct configuration of the TF-tree (as shown following) for pose tracking in a outdoor application, therefore I set utm → map (hope this is correct)
We have four ZED X cameras and a dual-antenna GPS module. I would now like to determine the pose in relation to dbas base-link [0.0, 0.0, 0.0]. I only do the locaisation with the ZED cameras and the GPS+RTK module. Shouldn’t a base_link appear in the TF-tree? Unfortunately, the documentation did not help me to solve my problem.
My config file and urdf files look like this:
stereo_common.yaml
# config/common_stereo.yaml
# Common parameters to Stereolabs ZED Stereo cameras
    ros__parameters:
        use_sim_time: false # Set to `true` only if there is a publisher for the simulated clock to the `/clock` topic. Normally used in simulation mode.
        simulation:
            sim_address: '127.0.0.1' # The connection address of the simulation server. See the documentation of the supported simulation plugins for more information.
        svo:
            use_svo_timestamps: true # Use the SVO timestamps to publish data. If false, data will be published at the system time.
            publish_svo_clock: false # [overwritten by launch file options] When use_svo_timestamps is true allows to publish the SVO clock to the `/clock` topic. This is useful for synchronous rosbag playback.
            svo_loop: false # Enable loop mode when using an SVO as input source. NOTE: ignored if SVO timestamping is used
            svo_realtime: false # if true the SVO will be played trying to respect the original framerate eventually skipping frames, otherwise every frame will be processed respecting the `pub_frame_rate` setting
        general:
            camera_timeout_sec: 5
            camera_max_reconnect: 5
            camera_flip: false
            self_calib: true # Enable the self-calibration process at camera opening. See https://www.stereolabs.com/docs/api/structsl_1_1InitParameters.html#affeaa06cfc1d849e311e484ceb8edcc5
            serial_number: 0 # overwritten by launch file
            pub_resolution: 'CUSTOM' # The resolution used for image and depth map publishing. 'NATIVE' to use the same `general.grab_resolution` - `CUSTOM` to apply the `general.pub_downscale_factor` downscale factory to reduce bandwidth in transmission
            pub_frame_rate: 15.0 # [DYNAMIC] Frequency of publishing of visual images and depth data (not the Point Cloud, see 'depth.point_cloud_freq'). This value must be equal or less than the camera framerate.
            enable_image_validity_check: 0 # [SDK5 required] Sets the image validity check. If set to 1, the SDK will check if the frames are valid before processing.
            gpu_id: 0
            optional_opencv_calibration_file: '' # Optional path where the ZED SDK can find a file containing the calibration information of the camera computed by OpenCV. Read the ZED SDK documentation for more information: https://www.stereolabs.com/docs/api/structsl_1_1InitParameters.html#a9eab2753374ef3baec1d31960859ba19
            async_image_retrieval: false # If set to true will camera image retrieve at a framerate different from \ref grab() application framerate. This is useful for recording SVO or sending camera stream at different rate than application.
            # Other parameters are defined, according to the camera model, in the 'zed.yaml', 'zedm.yaml', 'zed2.yaml', 'zed2i.yaml'
            # 'zedx.yaml', 'zedxmini.yaml', 'virtual.yaml' files
        video:
            saturation: 4 # [DYNAMIC]
            sharpness: 4 # [DYNAMIC]
            gamma: 8 # [DYNAMIC]
            exposure: 80 # [DYNAMIC]
            gain: 80 # [DYNAMIC]
            whitebalance_temperature: 42 # [DYNAMIC] - [28,65] x100 - works only if `auto_whitebalance` is false
        sensors:
            publish_imu_tf: true # [overwritten by launch file options] enable/disable the IMU TF broadcasting
            sensors_image_sync: true # Synchronize Sensors messages with latest published video/depth message
            sensors_pub_rate: 100. # frequency of publishing of sensors data. MAX: 400. - MIN: grab rate
        region_of_interest:
            automatic_roi: false # Enable the automatic ROI generation to automatically detect part of the robot in the FoV and remove them from the processing. Note: if enabled the value of `manual_polygon` is ignored
            #manual_polygon: '[[0.25,0.33],[0.75,0.33],[0.75,0.5],[0.5,0.75],[0.25,0.5]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
            apply_to_positional_tracking: true # Apply ROI to positional tracking processing
            apply_to_spatial_mapping: true # Apply ROI to spatial mapping processing
        depth:
            depth_mode: 'NEURAL_LIGHT' # Matches the ZED SDK setting: 'NONE', 'PERFORMANCE', 'QUALITY', 'ULTRA', 'NEURAL', 'NEURAL_PLUS' - Note: if 'NONE' all the modules that requires depth extraction are disabled by default (Pos. Tracking, Obj. Detection, Mapping, ...)
            depth_stabilization: 10 # Forces positional tracking to start if major than 0 - Range: [0,100]
            point_cloud_freq: 5.0 # [DYNAMIC] Frequency of the pointcloud publishing. This value must be equal or less than the camera framerate.
            point_cloud_res: 'COMPACT' # The resolution used for point cloud publishing - 'COMPACT'-Standard resolution. Optimizes processing and bandwidth, 'REDUCED'-Half resolution. Low processing and bandwidth requirements
            depth_confidence: 95 # [DYNAMIC]
        pos_tracking:
            pos_tracking_mode: 'GEN_3' # Matches the ZED SDK setting: 'GEN_1', 'GEN_2', 'GEN_3'
            publish_tf: true # [overwritten by launch file options] publish `odom -> camera_link` TF
            publish_map_tf: true # [overwritten by launch file options] publish `map -> odom` TF
            map_frame: 'map'
            odometry_frame: 'odom'
            area_memory_db_path: ''
            path_pub_rate: 5.0 # [DYNAMIC] - Camera trajectory publishing frequency
            fixed_z_value: 0.0 # Value to be used for Z coordinate if `two_d_mode` is true
            reset_pose_with_svo_loop: true # Reset the camera pose the `initial_base_pose` when the SVO loop is enabled and the SVO playback reaches the end of the file.
        gnss_fusion:
            gnss_fusion_enabled: true # fuse 'sensor_msg/NavSatFix' message information into pose data
            gnss_fix_topic: '/gps/ZED_tracking' # Name of the GNSS topic of type NavSatFix to subscribe [Default: '/gps/fix']
            broadcast_utm_transform_as_parent_frame: true # if 'true' publish `utm` -> `map` TF, otherwise `map` -> `utm`
            target_translation_uncertainty: 0.1 # defines the target translation uncertainty at which the calibration process between GNSS and VIO concludes. By default, the threshold is set at 10 centimeters.
            target_yaw_uncertainty: 0.1 # defines the target yaw uncertainty at which the calibration process between GNSS and VIO concludes. The unit of this parameter is in radian. By default, the threshold is set at 0.1 radians.
        mapping:
            mapping_enabled: true # True to enable mapping and fused point cloud pubblication
            max_mapping_range: 10.0 # maximum depth range while mapping in meters (-1 for automatic calculation) [2.0, 20.0]
            fused_pointcloud_freq: 5.0 # frequency of the publishing of the fused colored point cloud
        object_detection:
            enable_tracking: true # Whether the object detection system includes object tracking capabilities across a sequence of images.
            detection_model: 'MULTI_CLASS_BOX_FAST' # 'MULTI_CLASS_BOX_FAST', 'MULTI_CLASS_BOX_MEDIUM', 'MULTI_CLASS_BOX_ACCURATE', 'PERSON_HEAD_BOX_FAST', 'PERSON_HEAD_BOX_ACCURATE', 'CUSTOM_YOLOLIKE_BOX_OBJECTS'
            max_range: 20.0 # [m] Upper depth range for detections.The value cannot be greater than 'depth.max_depth'
            filtering_mode: 'NMS3D' # Filtering mode that should be applied to raw detections: 'NONE', 'NMS3D', 'NMS3D_PER_CLASS'
            prediction_timeout: 2.0 # During this time [sec], the object will have OK state even if it is not detected. Set this parameter to 0 to disable SDK predictions
            # Other parameters are defined in the 'object_detection.yaml' and 'custom_object_detection.yaml' files
        body_tracking:
            body_format: 'BODY_38' # 'BODY_18','BODY_34','BODY_38'
            max_range: 15.0 # [m] Defines a upper depth range for detections
        stream_server:
            bitrate: 12500 # [1000 - 60000] Streaming bitrate (in Kbits/s) used for streaming. See https://www.stereolabs.com/docs/api/structsl_1_1StreamingParameters.html#a873ba9440e3e9786eb1476a3bfa536d0
            target_framerate: 0 # Framerate for the streaming output. This framerate must be below or equal to the camera framerate. Allowed framerates are 15, 30, 60 or 100 if possible. Any other values will be discarded and camera FPS will be taken.
            thread_sched_policy: 'SCHED_BATCH' # 'SCHED_OTHER', 'SCHED_BATCH', 'SCHED_FIFO', 'SCHED_RR' - NOTE: 'SCHED_FIFO' and 'SCHED_RR' require 'sudo'
        debug:
            sdk_verbose_log_file: '' # Path to the file where the ZED SDK will log its messages. If empty, no file will be created. The log level can be set using the `sdk_verbose` parameter.
            debug_common: false
            debug_sim: false
            debug_video_depth: false
            debug_camera_controls: false
            debug_point_cloud: false
            debug_gnss: false
            debug_sensors: false
            debug_mapping: false
            debug_terrain_mapping: false
            debug_object_detection: false
            debug_body_tracking: false
            debug_roi: false
            debug_streaming: false
            debug_advanced: false
urdf file in ZED-Examples node for multi camera:
<?xml version="1.0"?>
// Copyright 2024 Stereolabs
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
//      http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
<robot name="zed_multi_camera" xmlns:xacro="http://ros.org/wiki/xacro">
  <!-- <xacro:property name="M_PI"     value="3.1415926535897931" /> -->
  <!-- Define the required parameters -->
  <xacro:arg name="multi_link" default="zed_multi_link" />
  <xacro:arg name="camera_name_0" default="zed_front_left" />
  <xacro:arg name="camera_name_1" default="zed_front_right" />
  <xacro:arg name="camera_name_2" default="zed_rear_left" />
  <xacro:arg name="camera_name_3" default="zed_rear_right" />
  <!-- Define the reference links -->
  <link name="$(arg multi_link)" />
  <link name="$(arg camera_name_0)_camera_link" />
  <link name="$(arg camera_name_1)_camera_link" />
  <link name="$(arg camera_name_2)_camera_link" />
  <link name="$(arg camera_name_3)_camera_link" />
  <!-- Note the URDF of the cameras are loaded by the respective launch files.
       We must only provide the position of each of them with respect to the reference link -->
  <!-- Define the position of the front_left camera with respect to the reference link -->
  <joint name="$(arg camera_name_0)_camera_joint" type="fixed">
      <parent link="$(arg camera_name_0)_camera_link"/>
      <child link="$(arg multi_link)"/>
      <origin xyz="1.02523 1.14077 1.32922" rpy="-0.349066 0.349066 2.35619" />
  </joint>
  <!-- Define the position of the front_right camera with respect to the reference link -->
  <joint name="$(arg camera_name_1)_camera_joint" type="fixed">
      <parent link="$(arg multi_link)"/>
      <child link="$(arg camera_name_1)_camera_link"/>
      <origin xyz="0.89978 -0.90007 0.72141" rpy="0.349066 0.349066 0.785398" />
  </joint>
  <!-- Define the position of the rear_left camera with respect to the reference link -->
  <joint name="$(arg camera_name_2)_camera_joint" type="fixed">
      <child link="$(arg camera_name_2)_camera_link"/>
      <origin xyz="-0.99078 1.02823 0.97763" rpy="-0.349066 -0.349066 -2.35619" />
  </joint>
  <!-- Define the position of the rear_right camera with respect to the reference link -->
  <joint name="$(arg camera_name_3)_camera_joint" type="fixed">
      <child link="$(arg camera_name_3)_camera_link"/>
      <origin xyz="-0.99981 -0.9978 0.97763" rpy="0.349066 -0.349066 -0.785398" />
  </joint>
</robot>
zed_descr urdf in zed_wrapper - here is defined the offset between the front left camera and the GPS antenna. Is this correct, or do I have to set the offset w.r.t the base_link, if I want to track this position?
<robot name="stereolabs_camera" xmlns:xacro="http://ros.org/wiki/xacro">
  <xacro:arg name="camera_name"   default="zed" />
  <xacro:arg name="camera_model"  default="zed" />
  <xacro:arg name="custom_baseline"  default="0.0" />
  <!-- If GNSS fusion is enabled the position of the antenna with respect to the camera mount point is required -->
  <xacro:arg name="enable_gnss"   default="false" />
  <xacro:arg name="gnss_x" default="-1.66657" />
  <xacro:arg name="gnss_y" default="-0.54662" />
  <xacro:arg name="gnss_z" default="0.57043" />
  <xacro:include filename="$(find zed_wrapper)/urdf/zed_macro.urdf.xacro" />
  <xacro:zed_camera name="$(arg camera_name)" model="$(arg camera_model)" custom_baseline="$(arg custom_baseline)" enable_gnss="$(arg enable_gnss)">
	    <origin xyz="$(arg gnss_x) $(arg gnss_y) $(arg gnss_z)" rpy="0 0 0"/>
  </xacro:zed_camera>
</robot>
Hi @robinvetsch
Please read the Robot Integration guide:
Hi @Myzhar,
I already checked the documentation carefully. To me it is still unclear, how to setup all the staff correctly in the multi_camera node. Since we are launch the zed_multi_camera node from the ROS2 examples repo, I assume that I have to adjust the urdf.axcro file “zed_multi.urdf.xacro”. I have done it in the following way:
<robot name="our_robot" xmlns:xacro="http://ros.org/wiki/xacro">
  <xacro:arg name="camera_name_1"   default="zed_front_left" />
  <xacro:arg name="camera_name_2"   default="zed_front_right" />
  <xacro:arg name="camera_name_3"   default="zed_rear_left" />
  <xacro:arg name="camera_name_4"   default="zed_rear_right" />
  <xacro:arg name="camera_model_1"  default="zedx" />
  <xacro:arg name="camera_model_2"  default="zedx" />
  <xacro:arg name="camera_model_3"  default="zedx" />
  <xacro:arg name="camera_model_4"  default="zedx" />
  <xacro:arg name="use_zed_localization" default="false" />
  <!-- Include the robot -->
  <xacro:include filename="$(find zed_multi_camera)/urdf/robot.urdf.xacro" />
  <!-- Load the ZED xacro macro -->
  <!-- Add the ZED Cameras - they will create their own internal link structure -->
  <xacro:zed_camera name="$(arg camera_name_1)" model="$(arg camera_model_1)">
    <gnss_origin/>
  </xacro:zed_camera>
  <xacro:zed_camera name="$(arg camera_name_2)" model="$(arg camera_model_2)">
    <gnss_origin/>
  </xacro:zed_camera>
  <xacro:zed_camera name="$(arg camera_name_3)" model="$(arg camera_model_3)">
    <gnss_origin/>
  </xacro:zed_camera>
  <xacro:zed_camera name="$(arg camera_name_4)" model="$(arg camera_model_4)">
    <gnss_origin/>
  </xacro:zed_camera>
  <!-- Add the joints to connect the ZED Cameras to the robot -->
  <xacro:if value="$(arg use_zed_localization)">
    <!-- ZED Localization -> The reference link is '$(arg camera_name_1)_camera_link' and 'base_link' is a child -->
    <joint name="$(arg camera_name_1)_joint" type="fixed">
      <parent link="$(arg camera_name_1)_camera_link"/>
      <child link="base_link"/>
      <origin
    </joint>
  </xacro:if>
  <xacro:unless value="$(arg use_zed_localization)">
    <!-- NO ZED Localization -> '$(arg camera_name)_camera_link' is a child of 'base_link' -->
      <parent link="base_link"/>
      <origin
    </joint>
  </xacro:unless>
  <!-- Add the joint of the second camera -->
  <joint name="$(arg camera_name_2)_joint" type="fixed">
    <origin
  </joint>
  <joint name="$(arg camera_name_3)_joint" type="fixed">
    <origin
  </joint>
  <joint name="$(arg camera_name_4)_joint" type="fixed">
    <child link="$(arg camera_name_4)_camera_link"/>
    <origin
  </joint>
</robot>
The robot’s urdf is quite simple, because i simly use the base_linke at the origin position:
<robot name="base_robot" xmlns:xacro="http://ros.org/wiki/xacro">
    <!-- Define materials -->
  <material name="black">
    <color rgba="0.000 0.000 0.000 1.000"/>
  </material>
  <!-- Base link - this is required -->
  <link name="base_link">
    <visual>
      <origin xyz="0 0 0" rpy="0 0 0"/>
      <geometry>
        <box size="1.0 1.0 1.0"/>
      </geometry>
      <material name="black"/>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
    <inertial>
      <mass value="50.0"/>
      <inertia ixx="1.0" ixy="0.0" ixz="0.0"
               iyy="1.0" iyz="0.0"
               izz="1.0"/>
    </inertial>
  </link>
</robot>
Currently I’m struggeling a bit, because to me it is not clear if I also have the modify the launch.py file of zed_multi_camera, that it fits with the example of zed_robot_integration launch file, because currently it doesn’t work as expected and I don’t see a base_link in the tf-tree.
Many thanks for a short clarification
I think I managed to set the zed_multi_camera setup correctly…
Here is the current tf_tree:
And here the adapted launch.py file for the multi camera node - probably this helps someone else.
# Copyright 2024 Stereolabs
# Licensed under the Apache License, Version 2.0 (the 'License');
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
#     http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an 'AS IS' BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import os
from ament_index_python.packages import get_package_share_directory
from launch.launch_description_sources import PythonLaunchDescriptionSource
from launch import LaunchDescription
from launch.actions import (
    DeclareLaunchArgument,
    OpaqueFunction,
    IncludeLaunchDescription,
    LogInfo
from launch.substitutions import (
    LaunchConfiguration,
    Command,
    TextSubstitution
from launch_ros.actions import (
    Node,
    ComposableNodeContainer
def parse_array_param(param):
    str = param.replace('[', '')
    str = str.replace(']', '')
    str = str.replace(' ', '')
    arr = str.split(',')
    return arr
def launch_setup(context, *args, **kwargs):
    # List of actions to be launched
    actions = []
    namespace_val = 'zed_multi'
    # URDF/xacro file to be loaded by the Robot State Publisher node
    multi_zed_xacro_path = os.path.join(get_package_share_directory('zed_multi_camera'),
                                        'urdf',
                                        'zed_multi.urdf.xacro')
    names = LaunchConfiguration('cam_names')
    models = LaunchConfiguration('cam_models')
    serials = LaunchConfiguration('cam_serials')
    ids = LaunchConfiguration('cam_ids')
    disable_tf = LaunchConfiguration('disable_tf')
    use_zed_localization = LaunchConfiguration('use_zed_localization')
    names_arr = parse_array_param(names.perform(context))
    models_arr = parse_array_param(models.perform(context))
    serials_arr = parse_array_param(serials.perform(context))
    ids_arr = parse_array_param(ids.perform(context))
    disable_tf_val = disable_tf.perform(context)
    num_cams = len(names_arr)
    if (num_cams != len(models_arr)):
        return [
            LogInfo(msg=TextSubstitution(
                text='The `cam_models` array argument must match the size of the `cam_names` array argument.'))
    if ((num_cams != len(serials_arr)) and (num_cams != len(ids_arr))):
        return [
                text='The `cam_serials` or `cam_ids` array argument must match the size of the `cam_names` array argument.'))
    # ROS 2 Component Container
    container_name = 'zed_multi_container'
    distro = os.environ['ROS_DISTRO']
    if distro == 'foxy':
        # Foxy does not support the isolated mode
        container_exec='component_container'
    else:
        container_exec='component_container_isolated'
    info = '* Starting Composable node container: /' + namespace_val + '/' + container_name
    actions.append(LogInfo(msg=TextSubstitution(text=info)))
    zed_container = ComposableNodeContainer(
        name=container_name,
        namespace=namespace_val,
        package='rclcpp_components',
        executable=container_exec,
        arguments=['--ros-args', '--log-level', 'info'],
        output='screen',
    actions.append(zed_container)
    # Set the first camera idx
    cam_idx = 0
    for name in names_arr:
        model = models_arr[cam_idx]
        if len(serials_arr) == num_cams:
            serial = serials_arr[cam_idx]
        else:
            serial = '0'
        if len(ids_arr) == num_cams:
            id = ids_arr[cam_idx]
        else:
            id = '-1'
        pose = '['
        info = '* Starting a ZED ROS2 node for camera ' + name + \
            ' (' + model
        if(serial != '0'):
            info += ', serial: ' + serial
        elif( id!= '-1'):
            info += ', id: ' + id
        info += ')'
        # Only the first camera send odom and map TF
        publish_tf = 'false'
        if (cam_idx == 0):
            if (disable_tf_val == 'False' or disable_tf_val == 'false'):
                publish_tf = 'true'
        # A different node name is required by the Diagnostic Updated
        node_name = 'zed_node_' + str(cam_idx)
        # Add the node
        # ZED Wrapper launch file
        zed_wrapper_launch = IncludeLaunchDescription(
            launch_description_source=PythonLaunchDescriptionSource([
                get_package_share_directory('zed_wrapper'),
                '/launch/zed_camera.launch.py'
            launch_arguments={
                'container_name': container_name,
                'camera_name': name,
                'camera_model': model,
                'serial_number': serial,
                'camera_id': id,
                'publish_tf': publish_tf,
                'publish_map_tf': publish_tf,
                'namespace': namespace_val
            }.items()
        actions.append(zed_wrapper_launch)
        cam_idx += 1
    # Robot URDF from xacro
    robot_description = Command(
                    'xacro', ' ', multi_zed_xacro_path, ' ',
                    'camera_name_0:=', 'zed_front_left', ' ',
                    'camera_name_1:=', 'zed_front_right', ' ',
                    'camera_name_2:=', 'zed_rear_left', ' ',
                    'camera_name_3:=', 'zed_rear_right', ' ',
                    'camera_model_0:=', 'zedx', ' ',
                    'camera_model_1:=', 'zedx', ' ',
                    'camera_model_2:=', 'zedx', ' ',
                    'camera_model_3:=', 'zedx', ' ',
                    'use_zed_localization:=', use_zed_localization,
    # Robot State Publisher node
    # this will publish the static reference link for a multi-camera configuration
    # and all the joints. See 'urdf/zed_dual.urdf.xacro' as an example
    rsp_name = 'state_publisher'
    info = '* Starting robot_state_publisher node to link all the frames: ' + rsp_name
    multi_rsp_node = Node(
        package='robot_state_publisher',
        executable='robot_state_publisher',
        name=rsp_name,
        output='screen',
        parameters=[{
            'robot_description': robot_description
    # Add the robot_state_publisher node to the list of nodes to be started
    actions.append(multi_rsp_node)
    return actions
def generate_launch_description():
    return LaunchDescription(
            DeclareLaunchArgument(
                'cam_names',
                description='An array containing the name of the cameras, e.g. [zed_front,zed_back]'),
                'cam_models',
                description='An array containing the model of the cameras, e.g. [zed2i,zed2]'),
                'cam_serials',
                default_value=[],
                description='An array containing the serial number of the cameras, e.g. [35199186,23154724]'),
                'cam_ids',
                default_value=[],
                description='An array containing the ID number of the cameras, e.g. [0,1]'),
                'disable_tf',
                default_value='False',
                description='If `True` disable TF broadcasting for all the cameras in order to fuse visual odometry information externally.'),
                'use_zed_localization',
                default_value='True',
                description='Creates a TF tree with `camera_link` as root frame if `true`, otherwise the root is `base_ling`.'),
            OpaqueFunction(function=launch_setup)
I confirm that this is the expected TF tree for using the ZED Positional Tracking module as the only odometry source
