SDK 5.2 pose integration with robot localization
I tried to fuse the position tracking pose with IMU with robot_localization, and I am getting the following error when I try to fuse pose_with_covariance or odom topic
[ekf_node-1] [ERROR] [1771446083.410758902] [ekf_filter_node]: Critical Error, NaNs were detected in the output state of the filter. This was likely due to poorly coniditioned process, noise, or sensor covariances.
[ekf_node-1] [ERROR] [1771446083.444097284] [ekf_filter_node]: Critical Error, NaNs were detected in the output state of the filter. This was likely due to poorly coniditioned process, noise, or sensor covariances.
[ekf_node-1] [ERROR] [1771446083.477384207] [ekf_filter_node]: Critical Error, NaNs were detected in the output state of the filter. This was likely due to poorly coniditioned process, noise, or sensor covariances.
[ekf_node-1] [ERROR] [1771446083.510755903] [ekf_filter_node]: Critical Error, NaNs were detected in the output state of the filter. This was likely due to poorly coniditioned process, noise, or sensor covariances.
All your help is appreciated!
This is a problem with the initialization of the robot_localization package.
I recommend you ask the ROS community: https://robotics.stackexchange.com/
