Hello @Myzhar. Thanks for the parameters. Unfortunately I have the same result. I still can see the outputs in RViz. Both mapping_enabled and pos_tracking_enabled are false. Here is the entire file:
# config/common_yaml
ros__parameters:
use_sim_time: false # Set to `true` only if there is a publisher for the simulated clock to the `/clock` topic. Normally used in simulation mode.
simulation:
sim_address: '127.0.0.1' # The connection address of the simulation server. See the documentation of the supported simulation plugins for more information.
general:
camera_model: 'zed2i'
camera_name: 'zed2i' # usually overwritten by launch file
grab_resolution: 'HD720' # The native camera grab resolution. 'HD2K', 'HD1080', 'HD720', 'VGA', 'AUTO'
grab_frame_rate: 30 # ZED SDK internal grabbing rate
svo_file: 'live' # usually overwritten by launch file
svo_loop: false # Enable loop mode when using an SVO as input source
camera_timeout_sec: 5
camera_max_reconnect: 5
camera_flip: false
serial_number: 0 # usually overwritten by launch file
pub_resolution: 'NATIVE' # antes CUSTOM # The resolution used for output. 'NATIVE' to use the same `general.grab_resolution` - `CUSTOM` to apply the `general.pub_downscale_factor` downscale factory to reduce bandwidth in transmission
pub_frame_rate: 30.0 # frequency of publishing of visual images and depth images
gpu_id: -1
optional_opencv_calibration_file: '' # Optional path where the ZED SDK can find a file containing the calibration information of the camera computed by OpenCV. Read the ZED SDK documentation for more information: https://www.stereolabs.com/docs/api/structsl_1_1InitParameters.html#a9eab2753374ef3baec1d31960859ba19
region_of_interest: '[]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
#region_of_interest: '[[0.25,0.33],[0.75,0.33],[0.75,0.5],[0.5,0.75],[0.25,0.5]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
#region_of_interest: '[[0.25,0.25],[0.75,0.25],[0.75,0.75],[0.25,0.75]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
#region_of_interest: '[[0.5,0.25],[0.75,0.5],[0.5,0.75],[0.25,0.5]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
video:
saturation: 4 # [DYNAMIC]
sharpness: 4 # [DYNAMIC]
gamma: 8 # [DYNAMIC]
exposure: 80 # [DYNAMIC]
gain: 80 # [DYNAMIC]
whitebalance_temperature: 42 # [DYNAMIC] - [28,65] works only if `auto_whitebalance` is false
qos_history: 1 # '1': KEEP_LAST - '2': KEEP_ALL
qos_depth: 1 # Queue size if using KEEP_LAST
qos_reliability: 1 # '1': RELIABLE - '2': BEST_EFFORT -
qos_durability: 2 # '1': TRANSIENT_LOCAL - '2': VOLATILE
depth:
min_depth: 0.5 # Min: 0.2, Max: 3.0
max_depth: 10.0 # Max: 40.0
depth_mode: 'ULTRA' # Matches the ZED SDK setting: 'NONE', 'PERFORMANCE', 'QUALITY', 'ULTRA', 'NEURAL' - Note: if 'NONE' all the modules that requires depth extraction are disabled by default (Pos. Tracking, Obj. Detection, Mapping, ...)
depth_stabilization: 0 # Forces positional tracking to start if major than 0 - Range: [0,100]
point_cloud_freq: 15.0 # [DYNAMIC] - frequency of the pointcloud publishing (equal or less to `grab_frame_rate` value)
depth_confidence: 10 # [DYNAMIC]
pos_tracking:
pos_tracking_enabled: false # antes true # True to enable positional tracking from start
pos_tracking_mode: 'STANDARD' # Matches the ZED SDK setting: 'QUALITY', 'STANDARD'
publish_tf: true # [usually overwritten by launch file] publish `odom -> camera_link` TF
publish_map_tf: true # [usually overwritten by launch file] publish `map -> odom` TF
base_frame: "base_link" # antes no habia, pero se agrego y no paso nada
map_frame: 'map'
odometry_frame: 'odom'
area_memory_db_path: ''
init_odom_with_first_valid_pose: true # Enable to initialize the odometry with the first valid pose
gnss_fusion:
gnss_fusion_enabled: false # fuse 'sensor_msg/NavSatFix' message information into pose data
gnss_fix_topic: '/gps/fix' # Name of the GNSS topic of type NavSatFix to subscribe [Default: '/gps/fix']
gnss_init_distance: 5.0 # The minimum distance traveled by the robot required to initilize the GNSS fusion [SDK <= v4.0.5]
gnss_frame: 'gnss_link' # [usually overwritten by launch file] The TF frame of the GNSS sensor
enable_reinitialization: true # determines whether reinitialization should be performed between GNSS and VIO fusion when a significant disparity is detected between GNSS data and the current fusion data. It becomes particularly crucial during prolonged GNSS signal loss scenarios.
gnss_vio_reinit_threshold: 5 # determines the threshold for GNSS/VIO reinitialization. If the fused position deviates beyond out of the region defined by the product of the GNSS covariance and the gnss_vio_reinit_threshold, a reinitialization will be triggered.
target_translation_uncertainty: 10e-2 # defines the target translation uncertainty at which the calibration process between GNSS and VIO concludes. By default, the threshold is set at 10 centimeters.
target_yaw_uncertainty: 0.1 # defines the target yaw uncertainty at which the calibration process between GNSS and VIO concludes. The unit of this parameter is in radian. By default, the threshold is set at 0.1 radians.
mapping:
mapping_enabled: false # True to enable mapping and fused point cloud pubblication
fused_pointcloud_freq: 0.0 # frequency of the publishing of the fused colored point cloud
sensors:
publish_imu_tf: true # [usually overwritten by launch file] enable/disable the IMU TF broadcasting
sensors_pub_rate: 100. # frequency of publishing of sensors data. MAX: 400. - MIN: grab rate
object_detection:
model: 'MULTI_CLASS_BOX_MEDIUM' # 'MULTI_CLASS_BOX_FAST', 'MULTI_CLASS_BOX_MEDIUM', 'MULTI_CLASS_BOX_ACCURATE', 'PERSON_HEAD_BOX_FAST', 'PERSON_HEAD_BOX_ACCURATE'
confidence_threshold: 50.0 # [DYNAMIC] - Minimum value of the detection confidence of an object [0,99]
mc_people: true # [DYNAMIC] - Enable/disable the detection of persons for 'MULTI_CLASS_X' models
body_tracking:
body_format: 'BODY_38' # 'BODY_18','BODY_34','BODY_38','BODY_70'
thread_sched_policy: 'SCHED_BATCH' # 'SCHED_OTHER', 'SCHED_BATCH', 'SCHED_FIFO', 'SCHED_RR' - NOTE: 'SCHED_FIFO' and 'SCHED_RR' require 'sudo'
debug:
debug_common: false
debug_sim: false
debug_video_depth: false
debug_camera_controls: false
debug_point_cloud: false
debug_gnss: false
debug_sensors: false
debug_mapping : false
debug_terrain_mapping : false
debug_object_detection : false
debug_body_tracking : false
debug_advanced: false
Is there other way to not to create the pointcloud?
