I use jp6.2 with jetson orin nx at 40w power mode and zed mini.
I run the wrapper with
depth performance mode
720HD@ 30
point cloud publish rate 10
GEN 2
At the begining the publish rate is 30hz but quickly drops to 16hz.
What might be the priblem?
Yes, still not great improvement.
I use neural_light mode.
is that possible to change the wrapper to publish for example only positional tracking data + compressed images?
sudo ZED_Diagnostic --dmesg
ZED_Diagnostic -c
The wrapper only publishes to a topic when the topic is subscribed.
Sorry for the late answer. Based on your setup and use of the wrapper, you shouldn’t see this behavior normally.
A few reasons could explain this behavior : a high temperature or issue with the power of the board. Is the camera connected directly to a USB 3.0 port on your end ?
Can you also provide your ROS2 configuration files ?
