Hi, I have been using the ZED2i camera indoors with great performance in terms of positional tracking, always starting the ZED node from the launch file. Since taking the camera outdoors, however, the positional tracking demonstrates very poor performance, jumping around frequently and not tracking properly. I have included a the contents of my yaml file below that I have been using indoors fine but doesn’t track well outdoors.
- Ubuntu 22.04, ROS2 Humble, 11th gen i9 CPU, 3070 GPU, CURA 11.8.89, ZED SDK 4.0.5
- Performance probably not an issue, works well indoors.
- Plenty of features outdoors.
Taking .svo file and post-processing works very well in ZEDfu and launching ZED Node with svo_path also works well even using the same yaml. This confuses me because I thought that .svo files are processed in real time, but maybe I am mistaken?
Please let me know what to include to help sort this, or let me know how to improve performance outdoors in any way.
# config/common_yaml
# Note: the parameter svo_file is passed as exe argumet
ros__parameters:
general:
svo_file: "" # usually overwritten by launch file
svo_loop: false # Enable loop mode when using an SVO as input source
camera_timeout_sec: 5
camera_max_reconnect: 5
camera_flip: false
zed_id: 0 # IMPORTANT: to be used in simulation to distinguish individual cameras im multi-camera configurations - usually overwritten by launch file
serial_number: 0 # usually overwritten by launch file
pub_resolution: 'HD720' # The resolution used for output. 'HD2K', 'HD1080', 'HD1200', 'HD720', 'MEDIUM', 'SVGA', 'VGA', 'LOW'
pub_frame_rate: 15.0 # [DYNAMIC] - frequency of publishing of visual images and depth images
gpu_id: -1
region_of_interest: '[]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
#region_of_interest: '[[0.25,0.33],[0.75,0.33],[0.75,0.5],[0.5,0.75],[0.25,0.5]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
#region_of_interest: '[[0.25,0.25],[0.75,0.25],[0.75,0.75],[0.25,0.75]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
#region_of_interest: '[[0.5,0.25],[0.75,0.5],[0.5,0.75],[0.25,0.5]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
sdk_verbose: 1
video:
saturation: 4 # [DYNAMIC]
sharpness: 4 # [DYNAMIC]
gamma: 8 # [DYNAMIC]
exposure: 80 # [DYNAMIC]
gain: 80 # [DYNAMIC]
whitebalance_temperature: 42 # [DYNAMIC] - [28,65] works only if `auto_whitebalance` is false
qos_history: 1 # '1': KEEP_LAST - '2': KEEP_ALL
qos_depth: 1 # Queue size if using KEEP_LAST
qos_reliability: 1 # '1': RELIABLE - '2': BEST_EFFORT -
qos_durability: 2 # '1': TRANSIENT_LOCAL - '2': VOLATILE
depth:
depth_mode: 'NEURAL' # Matches the ZED SDK setting: 'NONE', 'PERFORMANCE', 'QUALITY', 'ULTRA', 'NEURAL' - Note: if 'NONE' all the modules that requires depth extraction are disabled by default (Pos. Tracking, Obj. Detection, Mapping, ...)
depth_stabilization: 1 # Forces positional tracking to start if major than 0 - Range: [0,100]
point_cloud_freq: 10.0 # [DYNAMIC] - frequency of the pointcloud publishing (equal or less to `grab_frame_rate` value)
depth_confidence: 50 # [DYNAMIC]
pos_tracking:
publish_tf: true # [usually overwritten by launch file] publish `odom -> base_link` TF
publish_map_tf: true # [usually overwritten by launch file] publish `map -> odom` TF
publish_imu_tf: true # [usually overwritten by launch file] enable/disable the IMU TF broadcasting
base_frame: "base_link" # usually overwritten by launch file
map_frame: "map"
odometry_frame: "odom"
area_memory_db_path: ""
initial_base_pose: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0] # Initial position of the `base_frame` in the map -> [X, Y, Z, R, P, Y]
init_odom_with_first_valid_pose: true # Enable to initialize the odometry with the first valid pose
two_d_mode: false # Force navigation on a plane. If true the Z value will be fixed to "fixed_z_value", roll and pitch to zero
transform_time_offset: 0.0 # The value added to the timestamp of `map->odom` and `odom->base_link`` transform being generated
