Please send the values that you are using with these bash variables.
On that page under v1.3.0 you see:
- Add support for up to 4 ZED X cameras per MAX96712 (require SDK 5.0)
- Add support for up to 2 ZED X cameras per MAX9296 (require SDK 5.0)
Do you have the MAX96712? Mine are in /lib/modules/5.15.148-tegra/updates/drivers/stereolabs
Your driver version specifically mentions MAX96712 but might be worth confirming given exactly 2 work.
Let’s clear things up a bit.
Maxim MAX96712 is the model of the GMSL2 deserializer chip installed on the ZED Link Duo and ZED Link Quad (2x chips) capture cards, not a library.
The ZED Link Mono and the Mini Carrier Board instead use the Maxim MAX9296A.
Regarding the multi-camera issue, I recommend that you all upgrade the ZED X Driver to v1.3.1 and the ZED SDK to v5.0.3.
They both introduce fixes to connectivity problems in multi-camera setups.
I have upgraded my ZED SDK to v5.0.3 and my ZED X Driver to v1.3.1 on my Jetson AGX Orin Dev Kit (L4T version 36.4.3). This time all the topics from my 4 cameras are published but there are warnings in the logs:
[component_container_isolated-2] e[33m[WARN] [1753441403.536702976] [wall.zed_x_0]: Corrupted frame detected: CORRUPTED FRAMEe[0m
[component_container_isolated-2] [2025-07-25 11:03:23 UTC][ZED][WARNING] Frames may be corrupted or degraded
[component_container_isolated-2] e[33m[WARN] [1753441403.677850784] [wall.zed_x_0]: Corrupted frame detected: CORRUPTED FRAMEe[0m
[component_container_isolated-2] e[33m[WARN] [1753441403.716070016] [wall.zed_x_mini_2]: Corrupted frame detected: CORRUPTED FRAMEe[0m
[component_container_isolated-2] e[33m[WARN] [1753441403.819320000] [wall.zed_x_mini_2]: Corrupted frame detected: CORRUPTED FRAMEe[0m
[component_container_isolated-2] e[33m[WARN] [1753441403.885193920] [wall.zed_x_0]: Corrupted frame detected: CORRUPTED FRAMEe[0m
[component_container_isolated-2] e[33m[WARN] [1753441403.907144832] [wall.zed_x_mini_2]: Corrupted frame detected: CORRUPTED FRAMEe[0m
[component_container_isolated-2] e[33m[WARN] [1753441403.993550400] [wall.zed_x_mini_2]: Corrupted frame detected: CORRUPTED FRAMEe[0m
[component_container_isolated-2] [2025-07-25 11:03:24 UTC][ZED][WARNING] Frames may be corrupted or degraded
[component_container_isolated-2] e[33m[WARN] [1753441404.516945856] [wall.zed_x_mini_2]: Corrupted frame detected: CORRUPTED FRAMEe[0m
[component_container_isolated-2] e[33m[WARN] [1753441404.579967872] [wall.zed_x_0]: Corrupted frame detected: CORRUPTED FRAMEe[0m
[component_container_isolated-2] e[33m[WARN] [1753441404.604031872] [wall.zed_x_mini_2]: Corrupted frame detected: CORRUPTED FRAMEe[0m
The launch command that I mentioned earlier is called 4 times in a loop for all the four cameras that I have.
The zedx.yaml file that I use contains:
# config/zedx.yaml
# Parameters for Stereolabs ZED X camera
ros__parameters:
general:
camera_model: 'zedx'
camera_name: 'zedx' # overwritten by launch file
grab_resolution: 'HD1200' # The native camera grab resolution. 'HD1200', 'HD1080', 'SVGA', 'AUTO'
grab_frame_rate: 15 # ZED SDK internal grabbing rate (HD1200/HD1080: 60, 30, 15 - SVGA: 120, 60,>
video:
exposure_time: 16000 # Defines the real exposure time in microseconds. Recommended to control ma>
auto_exposure_time_range_min: 28 # Defines the minimum range of exposure auto control in micro s>
auto_exposure_time_range_max: 30000 # Defines the maximum range of exposure auto control in micr>
exposure_compensation: 50 # Defines the Exposure-target compensation made after auto exposure. R>
analog_gain: 1255 # Defines the real analog gain (sensor) in mDB. Range [1000-16000]. Recommende>
auto_analog_gain_range_min: 1000 # Defines the minimum range of sensor gain in automatic control
auto_analog_gain_range_max: 16000 # Defines the maximum range of sensor gain in automatic control
digital_gain: 1 # Defines the real digital gain (ISP) as a factor. Range [1-256]. Recommended to>
auto_digital_gain_range_min: 1 # Defines the minimum range of digital ISP gain in automatic cont>
auto_digital_gain_range_max: 256 # Defines the maximum range of digital ISP gain in automatic co>
denoising: 50 # Defines the level of denoising applied on both left and right images. Range [0-1>
depth:
min_depth: 0.3 # Min: 0.3, Max: 3.0
max_depth: 10.0 # Max: 20.0
The zedxm.yaml contains:
# config/zedxm_yaml
# Parameters for Stereolabs ZED X Mini camera
ros__parameters:
general:
camera_model: 'zedxm'
camera_name: 'zedxm' # overwritten by launch file
video:
exposure_time: 16666 # Defines the real exposure time in microseconds. Recommended to control ma>
auto_exposure_time_range_max: 16666 # Defines the maximum range of exposure auto control in micr>
analog_gain: 8000 # Defines the real analog gain (sensor) in mDB. Range [1000-16000]. Recommende>
digital_gain: 128 # Defines the real digital gain (ISP) as a factor. Range [1-256]. Recommended >
depth:
The common_stereo.yaml file contains:
# config/common_stereo.yaml
# Common parameters to Stereolabs ZED Stereo cameras
ros__parameters:
use_sim_time: false # Set to `true` only if there is a publisher for the simulated clock to the `/clock` topic. Normally used in simulation mode.
simulation:
sim_address: '127.0.0.1' # The connection address of the simulation server. See the documentation of the supported simulation plugins for more information.
svo:
use_svo_timestamps: true # Use the SVO timestamps to publish data. If false, data will be published at the system time.
publish_svo_clock: false # [overwritten by launch file options] When use_svo_timestamps is true allows to publish the SVO clock to the `/clock` topic. This is useful for synchronous rosbag playback.
svo_loop: false # Enable loop mode when using an SVO as input source. NOTE: ignored if SVO timestamping is used
svo_realtime: false # if true the SVO will be played trying to respect the original framerate eventually skipping frames, otherwise every frame will be processed respecting the `pub_frame_rate` setting
general:
camera_timeout_sec: 5
camera_max_reconnect: 5
camera_flip: false
self_calib: true # Enable the self-calibration process at camera opening. See https://www.stereolabs.com/docs/api/structsl_1_1InitParameters.html#affeaa06cfc1d849e311e484ceb8edcc5
serial_number: 0 # overwritten by launch file
pub_resolution: 'CUSTOM' # The resolution used for image and depth map publishing. 'NATIVE' to use the same `general.grab_resolution` - `CUSTOM` to apply the `general.pub_downscale_factor` downscale factory to reduce bandwidth in transmission
pub_frame_rate: 15.0 # frequency of publishing of visual images and depth images
enable_image_validity_check: 1 # [SDK5 required] Sets the image validity check. If set to 1, the SDK will check if the frames are valid before processing.
gpu_id: -1
optional_opencv_calibration_file: '' # Optional path where the ZED SDK can find a file containing the calibration information of the camera computed by OpenCV. Read the ZED SDK documentation for more information: https://www.stereolabs.com/docs/api/structsl_1_1InitParameters.html#a9eab2753374ef3baec1d31960859ba19
async_image_retrieval: false # Enable/disable the asynchronous image retrieval - Note: enable only to improve SVO recording performance
video:
saturation: 4 # [DYNAMIC]
sharpness: 4 # [DYNAMIC]
gamma: 8 # [DYNAMIC]
exposure: 80 # [DYNAMIC]
gain: 80 # [DYNAMIC]
whitebalance_temperature: 42 # [DYNAMIC] - [28,65] x100 - works only if `auto_whitebalance` is false
sensors:
publish_imu_tf: false # [overwritten by launch file options] enable/disable the IMU TF broadcasting
sensors_pub_rate: 100. # frequency of publishing of sensors data. MAX: 400. - MIN: grab rate
region_of_interest:
automatic_roi: false # Enable the automatic ROI generation to automatically detect part of the robot in the FoV and remove them from the processing. Note: if enabled the value of `manual_polygon` is ignored
#manual_polygon: '[[0.25,0.33],[0.75,0.33],[0.75,0.5],[0.5,0.75],[0.25,0.5]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
apply_to_positional_tracking: true # Apply ROI to positional tracking processing
apply_to_spatial_mapping: true # Apply ROI to spatial mapping processing
depth:
depth_mode: 'NEURAL_PLUS' # Matches the ZED SDK setting: 'NONE', 'PERFORMANCE', 'QUALITY', 'ULTRA', 'NEURAL', 'NEURAL_PLUS' - Note: if 'NONE' all the modules that requires depth extraction are disabled by default (Pos. Tracking, Obj. Detection, Mapping, ...)
depth_stabilization: 30 # Forces positional tracking to start if major than 0 - Range: [0,100]
point_cloud_freq: 15.0 # [DYNAMIC] - frequency of the pointcloud publishing (equal or less to `pub_frame_rate` value)
point_cloud_res: 'COMPACT' # The resolution used for point cloud publishing - 'COMPACT'-Standard resolution. Optimizes processing and bandwidth, 'REDUCED'-Half resolution. Low processing and bandwidth requirements
depth_confidence: 95 # [DYNAMIC]
pos_tracking:
pos_tracking_mode: 'GEN_1' # Matches the ZED SDK setting: 'GEN_1', 'GEN_2'
publish_tf: true # [overwritten by launch file options] publish `odom -> camera_link` TF
publish_map_tf: true # [overwritten by launch file options] publish `map -> odom` TF
map_frame: 'map'
odometry_frame: 'odom'
area_memory_db_path: ''
reset_pose_with_svo_loop: true # Reset the camera pose the `initial_base_pose` when the SVO loop is enabled and the SVO playback reaches the end of the file.
gnss_fusion:
gnss_fusion_enabled: false # fuse 'sensor_msg/NavSatFix' message information into pose data
gnss_fix_topic: '/fix' # Name of the GNSS topic of type NavSatFix to subscribe [Default: '/gps/fix']
target_translation_uncertainty: 10e-2 # defines the target translation uncertainty at which the calibration process between GNSS and VIO concludes. By default, the threshold is set at 10 centimeters.
target_yaw_uncertainty: 1e-2 # defines the target yaw uncertainty at which the calibration process between GNSS and VIO concludes. The unit of this parameter is in radian. By default, the threshold is set at 0.1 radians.
mapping:
mapping_enabled: false # True to enable mapping and fused point cloud pubblication
object_detection:
model: 'MULTI_CLASS_BOX_FAST' # 'MULTI_CLASS_BOX_FAST', 'MULTI_CLASS_BOX_MEDIUM', 'MULTI_CLASS_BOX_ACCURATE', 'PERSON_HEAD_BOX_FAST', 'PERSON_HEAD_BOX_ACCURATE', 'CUSTOM_YOLOLIKE_BOX_OBJECTS'
custom_onnx_file: '' # Only used if 'model' is 'CUSTOM_YOLOLIKE_BOX_OBJECTS'. Path to the YOLO-like ONNX file for custom object detection directly performed by the ZED SDK.
custom_onnx_input_size: 512 # Resolution used with the YOLO-like ONNX file. For example, 512 means a input tensor '1x3x512x512'
custom_label_yaml: '' # Only used if 'model' is 'CUSTOM_YOLOLIKE_BOX_OBJECTS'. Path to the COCO-like YAML file storing the custom class labels.
confidence_threshold: 75.0 # [DYNAMIC] - Minimum value of the detection confidence of an object [0,99]
mc_people: true # [DYNAMIC] - Enable/disable the detection of persons for 'MULTI_CLASS_X' models
body_tracking:
body_format: 'BODY_38' # 'BODY_18','BODY_34','BODY_38','BODY_70'
stream_server:
bitrate: 12500 # [1000 - 60000] Streaming bitrate (in Kbits/s) used for streaming. See https://www.stereolabs.com/docs/api/structsl_1_1StreamingParameters.html#a873ba9440e3e9786eb1476a3bfa536d0
target_framerate: 0 # Framerate for the streaming output. This framerate must be below or equal to the camera framerate. Allowed framerates are 15, 30, 60 or 100 if possible. Any other values will be discarded and camera FPS will be taken.
thread_sched_policy: 'SCHED_BATCH' # 'SCHED_OTHER', 'SCHED_BATCH', 'SCHED_FIFO', 'SCHED_RR' - NOTE: 'SCHED_FIFO' and 'SCHED_RR' require 'sudo'
debug:
sdk_verbose_log_file: '' # Path to the file where the ZED SDK will log its messages. If empty, no file will be created. The log level can be set using the `sdk_verbose` parameter.
debug_common: false
debug_sim: false
debug_video_depth: false
debug_camera_controls: false
debug_point_cloud: false
debug_gnss: false
debug_sensors: false
debug_mapping: false
debug_terrain_mapping: false
debug_object_detection: false
debug_body_tracking: false
debug_roi: false
debug_streaming: false
debug_advanced: false
Now aswering your question about the values used in the bash launch command:
The launch command is called in a loop 4 times where it launches all the 4 cameras one by one.
For the ZEDX camera the camera_model is passed with zedx and the camera_config_path is passed the path to the zedx.yaml file that I shared above, the common_config_path was passed with the path to the common_stero.yaml file, the serial number with the serial number of the camera [40919615] and finally the namespace and camera name with wall and zed_x_0.
The other three zedxm cameras are launched similarly but with the camera_config_path having the path to the zedxm.yaml file and their respective serial numbers, namespace, camera name and camera model (Please see the logs above).
Why do I have this warning of Frames may be corrupted or degraded?
However I can render the rgb data from all the 4 cameras in rviz.
This warning is issued because the image validity check is enabled by default and the camera is probably looking at something that is too close and is covering the most of the field of view.
Please send the picture of what the cameras are seeing. They will be useful to learn more concerning why the warning is issued.
This is a good indicator that the system is working.
