Is there a way to get 100hz IMU data with timestamps precisely synchronized with 30fps camera data timestamps in python or ROS? I need it for ORB SLAM 3.
If answer is no, what are the recommendations to run ORB SLAM 3 with ZED?
Thanks
Thanks
Hi @Vasa,
Welcome to the forums ![]()
You can retrieve sensor data at up to 200Hz using the getSensorsData API call.
You can find an example on our official github to read sensor data including IMU here: zed-sdk/tutorials/tutorial 7 - sensor data/cpp/main.cpp at master · stereolabs/zed-sdk · GitHub
