I just noticed that your launch line is wrong: rosrun zed_obj_det_sub_tutorial zed_obj_det_sub objes:=/zed2i/zed_node/obj_det/objects
it should be rosrun zed_obj_det_sub_tutorial zed_obj_det_sub objects:=/zed2i/zed_node/obj_det/objects
There’s a typo in the documentation, I’m going to fix it immediately
Works! Thank you. By the way, do you know why it detects only one person at a time? Is just wrapper limitation or can I enabled multi-person detection in some configs?
