Can i run your Gstreamer pipeline in parralell while also running the ros2 wrapper? The use case is i want to use the ros2 wrapper for communication on the local host, but stream using gstreamer to a third party ground control station on the network
No, you cannot share the same camera between two different processes.
You can search and use GStreamer ROS 2 nodes instead.
