fromLL returns 0,0,0 point when converting from lat lon to odom / map frame
The gnss fusion is enabled on zed2.
I was using the robot_localization/srv/FromLL for converting a geopoint from latitude, longitude to map frame point.
The magnetometer was calibrated a few years ago and I’m using a spoof gps till the snow clears out. Does that affect this much or should i drive the robot around a bit for it to work better?
The calibration keeps reoccuring a bit
[component_container_isolated-10] [INFO] [1768258269.279415297] [zed.zed_node]: * Rotation: {-0.000,-0.000,0.002}
[component_container_isolated-10] [INFO] [1768258269.345709774] [zed.zed_node]: GNSS fusion status: CALIBRATION_IN_PROGRESS
[component_container_isolated-10] [INFO] [1768258269.345849037] [zed.zed_node]: GNSS reference localization initialized
[component_container_isolated-10] [INFO] [1768258269.345903885] [zed.zed_node]: Static transform UTM to MAP [utm → map]
[component_container_isolated-10] [INFO] [1768258269.345937932] [zed.zed_node]: * Translation: {-395294.016,-4439748.763,-229.000}
The configs are:
# config/common_stereo.yaml
# Common parameters to Stereolabs ZED Stereo cameras
    ros__parameters:
        use_sim_time: false # Set to `true` only if there is a publisher for the simulated clock to the `/clock` topic. Normally used in simulation mode.
        simulation:
            sim_address: '127.0.0.1' # The connection address of the simulation server. See the documentation of the supported simulation plugins for more information.
        svo:
            use_svo_timestamps: true # Use the SVO timestamps to publish data. If false, data will be published at the system time.
            publish_svo_clock: false # [overwritten by launch file options] When use_svo_timestamps is true allows to publish the SVO clock to the `/clock` topic. This is useful for synchronous rosbag playback.
            svo_loop: false # Enable loop mode when using an SVO as input source. NOTE: ignored if SVO timestamping is used
            svo_realtime: false # if true the SVO will be played trying to respect the original framerate eventually skipping frames, otherwise every frame will be processed respecting the `pub_frame_rate` setting
        general:
            camera_timeout_sec: 5
            camera_max_reconnect: 5
            camera_flip: false
            self_calib: true # Enable the self-calibration process at camera opening. See
            serial_number: 0 # overwritten by launch file
            pub_resolution: 'CUSTOM' # The resolution used for image and depth map publishing. 'NATIVE' to use the same `general.grab_resolution` - `CUSTOM` to apply the `general.pub_downscale_factor` downscale factory to reduce bandwidth in transmission
            pub_frame_rate: 15.0 # [DYNAMIC] Frequency of publishing of visual images and depth data (not the Point Cloud, see 'depth.point_cloud_freq'). This value must be equal or less than the camera framerate.
            enable_image_validity_check: 1 # [SDK5 required] Sets the image validity check. If set to 1, the SDK will check if the frames are valid before processing.
            gpu_id: -1
            optional_opencv_calibration_file: '' # Optional path where the ZED SDK can find a file containing the calibration information of the camera computed by OpenCV. Read the ZED SDK documentation for more information:
            async_image_retrieval: false # If set to true will camera image retrieve at a framerate different from \ref grab() application framerate. This is useful for recording SVO or sending camera stream at different rate than application.
            publish_status: true # Advertise the status topics that are published only if a node subscribes to them
            # Other parameters are defined, according to the camera model, in the 'zed.yaml', 'zedm.yaml', 'zed2.yaml', 'zed2i.yaml'
            # 'zedx.yaml', 'zedxmini.yaml', 'virtual.yaml' files
        video:
            saturation: 4 # [DYNAMIC]
            sharpness: 4 # [DYNAMIC]
            gamma: 8 # [DYNAMIC]
            exposure: 80 # [DYNAMIC]
            gain: 80 # [DYNAMIC]
            whitebalance_temperature: 42 # [DYNAMIC] - [28,65] x100 - works only if `auto_whitebalance` is false
            publish_rgb: true # Advertise the RGB image topics that are published only if a node subscribes to them
            publish_left_right: false # Advertise the left and right image topics that are published only if a node subscribes to them
            publish_raw: false # Advertise the raw image topics that are published only if a node subscribes to them
            publish_gray: false # Advertise the gray image topics that are published only if a node subscribes to them
            publish_stereo: false # Advertise the stereo image topic that is published only if a node subscribes to it
        sensors:
            publish_imu_tf: true # [overwritten by launch file options] enable/disable the IMU TF broadcasting
            sensors_pub_rate: 100. # frequency of publishing of sensors data. MAX: 400. - MIN: grab rate
            publish_imu: true # Advertise the IMU topic that is published only if a node subscribes to it
            publish_imu_raw: false # Advertise the raw IMU topic that is published only if a node subscribes to it
            publish_cam_imu_transf: false # Advertise the CAMERA-IMU transformation topic that is published only if a node subscribes to it
            publish_mag: false # Advertise the magnetometer topic that is published only if a node subscribes to it
            publish_baro: false # Advertise the barometer topic that is published only if a node subscribes to it
            publish_temp: false # Advertise the temperature topics that are published only if a node subscribes to them
        region_of_interest:
            automatic_roi: false # Enable the automatic ROI generation to automatically detect part of the robot in the FoV and remove them from the processing. Note: if enabled the value of `manual_polygon` is ignored
            #manual_polygon: '[[0.25,0.33],[0.75,0.33],[0.75,0.5],[0.5,0.75],[0.25,0.5]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
            apply_to_positional_tracking: true # Apply ROI to positional tracking processing
            apply_to_spatial_mapping: true # Apply ROI to spatial mapping processing
            publish_roi_mask: false # Advertise the ROI mask image topic that is published only if a node subscribes to it
        depth:
            depth_mode: 'NEURAL_PLUS' # Matches the ZED SDK setting: 'NONE', 'PERFORMANCE', 'QUALITY', 'ULTRA', 'NEURAL_LIGHT', 'NEURAL', 'NEURAL_PLUS' - Note: if 'NONE' all the modules that requires depth extraction are disabled by default (Pos. Tracking, Obj. Detection, Mapping, ...)
            depth_stabilization: 30 # Forces positional tracking to start if major than 0 - Range: [0,100]
            point_cloud_freq: 10.0 # [DYNAMIC] Frequency of the pointcloud publishing. This value must be equal or less than the camera framerate.
            point_cloud_res: 'COMPACT' # The resolution used for point cloud publishing - 'COMPACT'-Standard resolution. Optimizes processing and bandwidth, 'REDUCED'-Half resolution. Low processing and bandwidth requirements
            depth_confidence: 95 # [DYNAMIC]
            publish_depth_map: true # Advertise the depth map topics that are published only if a node subscribes to them
            publish_depth_info: true # Advertise the depth info topic that is published only if a node subscribes to it
            publish_point_cloud: false # Advertise the point cloud topic that is published only if a node subscribes to it
            publish_depth_confidence: true # Advertise the depth confidence topic that is published only if a node subscribes to it
            publish_disparity: false # Advertise the disparity topic that is published only if a node subscribes to it
        pos_tracking:
            pos_tracking_mode: 'GEN_3' # Matches the ZED SDK setting: 'GEN_1', 'GEN_2', 'GEN_3'
            publish_tf: true # [overwritten by launch file options] publish `odom -> camera_link` TF
            publish_map_tf: true # [overwritten by launch file options] publish `map -> odom` TF
            map_frame: 'map'
            odometry_frame: 'odom'
            area_file_path: '' # Path to the area memory file for relocalization and loop closure in a previously explored environment.
            save_area_memory_on_closing: false # Save Area memory before closing the camera if `area_file_path` is not empty. You can also use the `save_area_memory` service to save the area memory at any time.
            publish_3d_landmarks: false # Publish 3D landmarks used by the positional tracking algorithm
            publish_lm_skip_frame: 5 # Publish the landmarks every X frames to reduce bandwidth. Set to 0 to publish all landmarks
            fixed_z_value: 0.0 # Value to be used for Z coordinate if `two_d_mode` is true
            reset_pose_with_svo_loop: true # Reset the camera pose the `initial_base_pose` when the SVO loop is enabled and the SVO playback reaches the end of the file.
            publish_odom_pose: true # Advertise the odometry and pose topics that are published only if a node subscribes to them
            publish_pose_cov: false # Advertise the pose with covariance topic that is published only if a node subscribes to it
            publish_cam_path: true # Advertise the camera odometry and pose path topics that are published only if a node subscribes to them
        gnss_fusion:
            gnss_fusion_enabled: true # fuse 'sensor_msg/NavSatFix' message information into pose data
            gnss_fix_topic: '/navsatfix' # Name of the GNSS topic of type NavSatFix to subscribe [Default: '/gps/fix']
            enable_reinitialization: true # determines whether reinitialization should be performed between GNSS and VIO fusion when a significant disparity is detected between GNSS data and the current fusion data. It becomes particularly crucial during prolonged GNSS signal loss scenarios.
            target_translation_uncertainty: 0.1 # defines the target translation uncertainty at which the calibration process between GNSS and VIO concludes. By default, the threshold is set at 10 centimeters.
            target_yaw_uncertainty: 0.1 # defines the target yaw uncertainty at which the calibration process between GNSS and VIO concludes. The unit of this parameter is in radian. By default, the threshold is set at 0.1 radians.
        mapping:
            mapping_enabled: false # True to enable mapping t # Pand fused point cloud pubblication
            publish_det_plane: false # Advertise the plane detection topics that is published only if a node subscribes to it
        object_detection:
            enable_tracking: true # Whether the object detection system includes object tracking capabilities across a sequence of images.
            detection_model: 'MULTI_CLASS_BOX_FAST' # 'MULTI_CLASS_BOX_FAST', 'MULTI_CLASS_BOX_MEDIUM', 'MULTI_CLASS_BOX_ACCURATE', 'PERSON_HEAD_BOX_FAST', 'PERSON_HEAD_BOX_ACCURATE', 'CUSTOM_YOLOLIKE_BOX_OBJECTS'
            max_range: 20.0 # [m] Upper depth range for detections.The value cannot be greater than 'depth.max_depth'
            filtering_mode: 'NMS3D' # Filtering mode that should be applied to raw detections: 'NONE', 'NMS3D', 'NMS3D_PER_CLASS'
            prediction_timeout: 2.0 # During this time [sec], the object will have OK state even if it is not detected. Set this parameter to 0 to disable SDK predictions
            # Other parameters are defined in the 'object_detection.yaml' and 'custom_object_detection.yaml' files
        body_tracking:
            body_format: 'BODY_38' # 'BODY_18','BODY_34','BODY_38'
            max_range: 15.0 # [m] Defines a upper depth range for detections
        stream_server:
            bitrate: 12500 # [1000 - 60000] Streaming bitrate (in Kbits/s) used for streaming. See
            target_framerate: 0 # Framerate for the streaming output. This framerate must be below or equal to the camera framerate. Allowed framerates are 15, 30, 60 or 100 if possible. Any other values will be discarded and camera FPS will be taken.
            # Reference documentation:
            thread_sched_policy: 'SCHED_BATCH' # 'SCHED_OTHER', 'SCHED_BATCH', 'SCHED_FIFO', 'SCHED_RR' - NOTE: 'SCHED_FIFO' and 'SCHED_RR' require 'sudo'
        debug:
            sdk_verbose: 0 # Set the verbose level of the ZED SDK
            sdk_verbose_log_file: '' # Path to the file where the ZED SDK will log its messages. If empty, no file will be created. The log level can be set using the `sdk_verbose` parameter.
            use_pub_timestamps: false # Use the current ROS time for the message timestamp instead of the camera timestamp. This is useful to test data communication latency.
            debug_common: false
            debug_sim: false
            debug_video_depth: false
            debug_camera_controls: false
            debug_point_cloud: false
            debug_gnss: false
            debug_sensors: false
            debug_mapping: false
            debug_terrain_mapping: false
            debug_object_detection: false
            debug_body_tracking: false
            debug_roi: false
            debug_streaming: false
            debug_advanced: false
            debug_nitros: false
            disable_nitros: false # If available, disable NITROS usage for debugging and testing purposes
Hi @adipotnis
What’s the status of the tracking?
What you described is expected if the calibration is not completed.
Please read more on the documentation:
Thanks this guide is helpful. Is there any experience/ approximate time it needs to converge. In terms of time or distance i should drive it before the calibration will start.
Will try with rolling calibration and reducing accuracy threshold
It’s not a matter of time, but of distance and data quality
got it, it worked once i reduced the accuracy threshold a bit and drove for calibration for a while. Thanks.
