Can someone explain or verify what is the frame of orientation available in ~/imu/data ros2 topic.
especially is the pitch and roll data in local imu frame or is it somehow corrected. My camera is tilted about 10-15 degrees down so if the data would be in local IMU frame then the pitch angle should be initially around zero. Now it seems that it is somehow corrected to earth frame or something.
