Cannot open ZED_Explore
./ZED_Explorer
./ZED_Diagnostic
libpng warning: iCCP: known incorrect sRGB profile
“Specific resolutions are not available
Replug your device or connect the camera to another USB 3.0 port.”
I’ve changed several usb 3.0 port ,and it didn’t work.
but I can open ZED_Depth_Viewer
Hi @lyehan
To better understand what is causing your problem, we need more information on your device’s status and your system’s configuration.
Please connect the camera to the USB3 port, run the ZED Diagnostic tool, and send me the report file it generates.
This is report file
ZED_Diagnostic_Results.json (9.7 KB)
I’m sure that the camera is connected to the USB3 port
It seems that the resolution HD720@60FPS is not correctly working.
Can you confirm that the cable screws are strongly strengthened?
