Camera Initial pose not working when using gnss_fusion
I am using ZED SDK 4.2 and using the data from a simulated camera. My initial pose of the camera is not [0, 0, 0] in the map frame, so I set it up with some offset. That works normally, but when I enable gnss fusion, the initial pose is set back to [0, 0, 0]. How should I fix this?
Here is my config:
# config/common_yaml
    ros__parameters:
        use_sim_time: false # Set to `true` only if there is a publisher for the simulated clock to the `/clock` topic. Normally used in simulation mode.
        simulation:
            sim_address: "127.0.0.1" # The connection address of the simulation server. See the documentation of the supported simulation plugins for more information.
        svo:
            svo_loop: false # Enable loop mode when using an SVO as input source
        general:
            camera_timeout_sec: 5
            camera_max_reconnect: 5
            camera_flip: false
            serial_number: 0 # usually overwritten by launch file
            pub_resolution: "CUSTOM" # The resolution used for output. 'NATIVE' to use the same `general.grab_resolution` - `CUSTOM` to apply the `general.pub_downscale_factor` downscale factory to reduce bandwidth in transmission
            pub_frame_rate: 30.0 # frequency of publishing of visual images and depth images
            gpu_id: -1
            optional_opencv_calibration_file: "" # Optional path where the ZED SDK can find a file containing the calibration information of the camera computed by OpenCV. Read the ZED SDK documentation for more information: https://www.stereolabs.com/docs/api/structsl_1_1InitParameters.html#a9eab2753374ef3baec1d31960859ba19
        video:
            saturation: 4 # [DYNAMIC]
            sharpness: 4 # [DYNAMIC]
            gamma: 8 # [DYNAMIC]
            exposure: 80 # [DYNAMIC]
            gain: 80 # [DYNAMIC]
            whitebalance_temperature: 42 # [DYNAMIC] - [28,65] works only if `auto_whitebalance` is false
        region_of_interest:
            automatic_roi: false # Enable the automatic ROI generation to automatically detect part of the robot in the FoV and remove them from the processing. Note: if enabled the value of `manual_polygon` is ignored
            #manual_polygon: "[[0.25,0.33],[0.75,0.33],[0.75,0.5],[0.5,0.75],[0.25,0.5]]" # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
            apply_to_positional_tracking: true # Apply ROI to positional tracking processing
            apply_to_spatial_mapping: true # Apply ROI to spatial mapping processing
        depth:
            depth_mode: "ULTRA" # Matches the ZED SDK setting: 'NONE', 'PERFORMANCE', 'QUALITY', 'ULTRA', 'NEURAL', 'NEURAL_PLUS' - Note: if 'NONE' all the modules that requires depth extraction are disabled by default (Pos. Tracking, Obj. Detection, Mapping, ...)
            depth_stabilization: 1 # Forces positional tracking to start if major than 0 - Range: [0,100]
            point_cloud_freq: 10.0 # [DYNAMIC] - frequency of the pointcloud publishing (equal or less to `grab_frame_rate` value)
            depth_confidence: 50 # [DYNAMIC]
        pos_tracking:
            pos_tracking_mode: "GEN_1" # Matches the ZED SDK setting: 'GEN_1', 'GEN_2'
            publish_tf: true # [usually overwritten by launch file] publish `odom -> camera_link` TF
            publish_map_tf: true # [usually overwritten by launch file] publish `map -> odom` TF
            map_frame: "map"
            odometry_frame: "odom"
            area_memory_db_path: ""
            initial_base_pose: [0.42, 0.0, 0.6, 0.0, 0.0, 0.0] # Initial position of the `camera_link` frame in the map -> [X, Y, Z, R, P, Y]
            fixed_z_value: 1.00 # Value to be used for Z coordinate if `two_d_mode` is true
        gnss_fusion:
            gnss_fusion_enabled: true # fuse 'sensor_msg/NavSatFix' message information into pose data
            gnss_fix_topic: "/gps/fix" # Name of the GNSS topic of type NavSatFix to subscribe [Default: '/gps/fix']
            publish_utm_tf: false # Publish `utm` -> `map` TF
            enable_rolling_calibration: false # If this parameter is set to true, the fusion algorithm will used a rough VIO / GNSS calibration at first and then refine it. This allow you to quickly get a fused position.
            target_translation_uncertainty: 10e-2 # defines the target translation uncertainty at which the calibration process between GNSS and VIO concludes. By default, the threshold is set at 10 centimeters.
            target_yaw_uncertainty: 1e-2 # defines the target yaw uncertainty at which the calibration process between GNSS and VIO concludes. The unit of this parameter is in radian. By default, the threshold is set at 0.1 radians.
        mapping:
            mapping_enabled: false # True to enable mapping and fused point cloud pubblication
            clicked_point_topic: "/clicked_point" # Topic published by Rviz when a point of the cloud is clicked. Used for plane detection
        sensors:
            publish_imu_tf: true # [usually overwritten by launch file] enable/disable the IMU TF broadcasting
            sensors_pub_rate: 200. # frequency of publishing of sensors data. MAX: 400. - MIN: grab rate
        object_detection:
            model: "MULTI_CLASS_BOX_MEDIUM" # 'MULTI_CLASS_BOX_FAST', 'MULTI_CLASS_BOX_MEDIUM', 'MULTI_CLASS_BOX_ACCURATE', 'PERSON_HEAD_BOX_FAST', 'PERSON_HEAD_BOX_ACCURATE'
            confidence_threshold: 50.0 # [DYNAMIC] - Minimum value of the detection confidence of an object [0,99]
            mc_people: true # [DYNAMIC] - Enable/disable the detection of persons for 'MULTI_CLASS_X' models
        body_tracking:
            model: "HUMAN_BODY_MEDIUM" # 'HUMAN_BODY_FAST', 'HUMAN_BODY_MEDIUM', 'HUMAN_BODY_ACCURATE'
            body_format: "BODY_38" # 'BODY_18','BODY_34','BODY_38','BODY_70'
            body_kp_selection: "FULL" # 'FULL', 'UPPER_BODY'
        stream_server:
            bitrate: 12500 # [1000 - 60000] Streaming bitrate (in Kbits/s) used for streaming. See https://www.stereolabs.com/docs/api/structsl_1_1StreamingParameters.html#a873ba9440e3e9786eb1476a3bfa536d0
            target_framerate: 0 # Framerate for the streaming output. This framerate must be below or equal to the camera framerate. Allowed framerates are 15, 30, 60 or 100 if possible. Any other values will be discarded and camera FPS will be taken.
            thread_sched_policy: "SCHED_BATCH" # 'SCHED_OTHER', 'SCHED_BATCH', 'SCHED_FIFO', 'SCHED_RR' - NOTE: 'SCHED_FIFO' and 'SCHED_RR' require 'sudo'
        debug:
            debug_common: false
            debug_sim: false
            debug_video_depth: false
            debug_camera_controls: false
            debug_point_cloud: false
            debug_gnss: false
            debug_sensors: false
            debug_mapping: false
            debug_terrain_mapping: false
            debug_object_detection: false
            debug_body_tracking: false
            debug_roi: false
            debug_streaming: false
            debug_advanced: false
Hi @ShyamKrishna33
the behavior that you describe is correct.
GNSS fusion cannot be used currently with an offset.
hi @Myzhar
Is there any way to fix this or get around this problem?
The only solution is to create a node that subscribes to the pose topic and applies the initial offset transformation to it.
