Camera connection issue in ZED-multi node
We are using the ZED_Multi node with ROS2 humble in a launch file where we start several other nodes. Normally the node starts up properly and the topics are published. Sometimes, however, the following error appears. After aborting the launch and running it again, it usually works again.
Are there any improvements we can make to avoid this behavior?
[component_container_isolated-1] [INFO] [1748413245.643182276] [zed_multi.zed_back]: *** CAMERA OPENING ***
[component_container_isolated-1] [INFO] [1748413245.649893146] [zed_multi.zed_left]: *** CAMERA OPENING ***
[component_container_isolated-1] [INFO] [1748413245.652065104] [zed_multi.zed_right]: *** CAMERA OPENING ***
[component_container_isolated-1] [INFO] [1748413245.652594671] [zed_multi.zed_front]: *** CAMERA OPENING ***
[component_container_isolated-1] (Argus) Error Timeout:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 219)
[component_container_isolated-1] (Argus) Error Timeout: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
[component_container_isolated-1] [2025-05-28 06:21:02 UTC][ZED][INFO] Logging level INFO
[component_container_isolated-1] [WARN] [1748413262.202372090] [zed_multi.zed_back]: Error opening camera: CAMERA NOT DETECTED
[component_container_isolated-1] [INFO] [1748413262.202492211] [zed_multi.zed_back]: Please verify the camera connection
[component_container_isolated-1] [2025-05-28 06:21:02 UTC][ZED][WARNING] CAMERA NOT DETECTED in sl::ERROR_CODE sl::Camera::open(sl::InitParameters)
[component_container_isolated-1] [2025-05-28 06:21:03 UTC][ZED][INFO] Logging level INFO
[component_container_isolated-1] [WARN] [1748413263.211191416] [zed_multi.zed_left]: Error opening camera: CAMERA NOT DETECTED
[component_container_isolated-1] [INFO] [1748413263.211314384] [zed_multi.zed_left]: Please verify the camera connection
[component_container_isolated-1] [2025-05-28 06:21:03 UTC][ZED][WARNING] CAMERA NOT DETECTED in sl::ERROR_CODE sl::Camera::open(sl::InitParameters)
[component_container_isolated-1] [2025-05-28 06:21:04 UTC][ZED][INFO] Logging level INFO
[component_container_isolated-1] [2025-05-28 06:21:04 UTC][ZED][WARNING] CAMERA NOT DETECTED in sl::ERROR_CODE sl::Camera::open(sl::InitParameters)
[component_container_isolated-1] [WARN] [1748413264.218634589] [zed_multi.zed_right]: Error opening camera: CAMERA NOT DETECTED
[component_container_isolated-1] [INFO] [1748413264.218745142] [zed_multi.zed_right]: Please verify the camera connection
[component_container_isolated-1] [2025-05-28 06:21:05 UTC][ZED][INFO] Logging level INFO
[component_container_isolated-1] [WARN] [1748413265.227065334] [zed_multi.zed_front]: Error opening camera: CAMERA NOT DETECTED
[component_container_isolated-1] [INFO] [1748413265.227173999] [zed_multi.zed_front]: Please verify the camera connection
[component_container_isolated-1] [2025-05-28 06:21:05 UTC][ZED][WARNING] CAMERA NOT DETECTED in sl::ERROR_CODE sl::Camera::open(sl::InitParameters)
[component_container_isolated-1] [2025-05-28 06:21:07 UTC][ZED][INFO] Logging level INFO
[component_container_isolated-1] [2025-05-28 06:21:07 UTC][ZED][ERROR] [ZED] sl::Camera::Open has not been called, no Camera instance running.
[component_container_isolated-1] [2025-05-28 06:21:07 UTC][ZED][WARNING] CAMERA NOT DETECTED in sl::ERROR_CODE sl::Camera::open(sl::InitParameters)
[component_container_isolated-1] [WARN] [1748413267.703606676] [zed_multi.zed_back]: Error opening camera: CAMERA NOT DETECTED
[component_container_isolated-1] [INFO] [1748413267.703755115] [zed_multi.zed_back]: Please verify the camera connection
[component_container_isolated-1] [2025-05-28 06:21:08 UTC][ZED][INFO] Logging level INFO
[component_container_isolated-1] [2025-05-28 06:21:08 UTC][ZED][ERROR] [ZED] sl::Camera::Open has not been called, no Camera instance running.
[component_container_isolated-1] [2025-05-28 06:21:08 UTC][ZED][WARNING] CAMERA NOT DETECTED in sl::ERROR_CODE sl::Camera::open(sl::InitParameters)
[component_container_isolated-1] [WARN] [1748413268.712015176] [zed_multi.zed_left]: Error opening camera: CAMERA NOT DETECTED
[component_container_isolated-1] [INFO] [1748413268.712126273] [zed_multi.zed_left]: Please verify the camera connection
[component_container_isolated-1] [2025-05-28 06:21:09 UTC][ZED][INFO] Logging level INFO
[component_container_isolated-1] [2025-05-28 06:21:09 UTC][ZED][ERROR] [ZED] sl::Camera::Open has not been called, no Camera instance running.
[component_container_isolated-1] [WARN] [1748413269.719837233] [zed_multi.zed_right]: Error opening camera: CAMERA NOT DETECTED
[component_container_isolated-1] [INFO] [1748413269.719983080] [zed_multi.zed_right]: Please verify the camera connection
[component_container_isolated-1] [2025-05-28 06:21:09 UTC][ZED][WARNING] CAMERA NOT DETECTED in sl::ERROR_CODE sl::Camera::open(sl::InitParameters)
[component_container_isolated-1] [2025-05-28 06:21:10 UTC][ZED][INFO] Logging level INFO
[component_container_isolated-1] [2025-05-28 06:21:10 UTC][ZED][ERROR] [ZED] sl::Camera::Open has not been called, no Camera instance running.
