Hi when i am trying to run ```python “body_tracking.py” , its running i am getting the coordinates but nothing is displaying , can you please help me how to display live body tracking , i have zed cameras.
Hello and thank you for contacting us,
Can you give me a little more information about your setup ? Which ZED SDK version are you using ? Also, what happens when you run basic tools like ZED Depth Viewer ?
Antoine
Hi antoine,
Thanks for your reply
its working now , but i have small issue that how to track person with a id associated to that person . i am able to track the positional and body but my requirements is to track a person with a ID
for example i have a small store , in that i want to track a person with a ID .how to do it
Kind Regards
Siddharth Rana
Sent from my iPhone
The ObjectData structure contains an id. You need to enable the tracking to keep the ids between the frames :
detection_parameters.enable_tracking = true; // Objects will keep the same ID between frames
Antoine Lassagne
Senior Developer - ZED SDK
i tried to find this detect.parameters but i couldn’t, could you please tell me on which line and python file it’s available
Sent from my iPhone
Hi ,
where i will find
Sent from my iPhone
Sent from my iPhone
On Mar 22, 2023, at 10:37 AM, Antoine Lassagne (Stereolabs) support@stereolabs.com wrote:
hi,
please find the attached screenshot
already have done obj_param.enable_tracking = True ,
but still not getting the id
Sent from my iPhone
You get the id in the ObjectData structure. You should follow this tutorial :
https://www.stereolabs.com/docs/object-detection/using-object-detection/
And here is a partial code that retrieves the id :
objects = sl.Objects() # Structure containing all the detected objectsif zed.grab() == sl.ERROR_CODE.SUCCESS : zed.retrieve_objects(objects, obj_runtime_param) # Retrieve the detected objects for object in objects.object_list: print("{} {}".format(object.id, object.position))
Antoine Lassagne
please find the attached code, i am trying to access id like this
HI,
Copyright (c) 2022, STEREOLABS.
All rights reserved.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
“AS IS” AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
This sample shows how to detect a human bodies and draw their
modelised skeleton in an OpenGL window
import cv2
import sys
import pyzed.sl as sl
import ogl_viewer.viewer as gl
import cv_viewer.tracking_viewer as cv_viewer
import numpy as np
if name == “main”:
print(“Running Body Tracking sample … Press ‘q’ to quit”)
Create a Camera object
zed = sl.Camera()
Create a InitParameters object and set configuration parameters
#init_params.enable_tracking = true
init_params.camera_resolution = sl.RESOLUTION.HD1080 # Use HD1080 video mode
init_params.coordinate_units = sl.UNIT.METER # Set coordinate units
init_params.depth_mode = sl.DEPTH_MODE.ULTRA
If applicable, use the SVO given as parameter
Otherwise use ZED live stream
if len(sys.argv) == 2:
filepath = sys.argv[1]
print(“Using SVO file: {0}”.format(filepath))
init_params.svo_real_time_mode = True
init_params.set_from_svo_file(filepath)
Open the camera
err = zed.open(init_params)
exit(1)
#sl.PositionalTrackingParameters()
Set initialization parameters
#detection_parameters = sl.detection_parameters()
detection_parameters = sl.ObjectDetectionParameters()
detection_parameters.detection_model = sl.DETECTION_MODEL.HUMAN_BODY_ACCURATE
#detection_parameters = sl.ObjectDetectionParameters()
detection_parameters.enable_tracking = True
detection_parameters.enable_body_fitting = True
Set runtime parameters
detection_parameters_rt = sl.ObjectDetectionRuntimeParameters()
detection_parameters_rt.detection_confidence_threshold = 40
Enable Positional tracking (mandatory for object detection)
if detection_parameters.enable_tracking :
zed.enable_positional_tracking(positional_tracking_parameters)
If the camera is static, uncomment the following line to have better performances and boxes sticked to the ground.
positional_tracking_parameters.set_as_static = True
#zed.enable_positional_tracking(positional_tracking_parameters)
obj_param.enable_body_fitting = True # Smooth skeleton move
obj_param.enable_tracking = True # Track people across images flow
obj_param.detection_model = sl.DETECTION_MODEL.HUMAN_BODY_FAST
obj_param.body_format = sl.BODY_FORMAT.POSE_18 # Choose the BODY_FORMAT you wish to use
Enable Object Detection module
zed.enable_object_detection(obj_param)
obj_runtime_param.detection_confidence_threshold = 40
objects = sl.Objects() # Structure containing all the detected objects# grab runtime parameters
runtime_params.measure3D_reference_frame = sl.REFERENCE_FRAME.WORLD
if zed.grab(runtime_params) == sl.ERROR_CODE.SUCCESS :
print(“{} {}”.format(object.position))
Get ZED camera information
camera_info = zed.get_camera_information()
2D viewer utilities
display_resolution = sl.Resolution(min(camera_info.camera_resolution.width, 1280), min(camera_info.camera_resolution.height, 720))
image_scale = [display_resolution.width / camera_info.camera_resolution.width
, display_resolution.height / camera_info.camera_resolution.height]
Create OpenGL viewer
viewer = gl.GLViewer()
viewer.init(camera_info.calibration_parameters.left_cam, obj_param.enable_tracking,obj_param.body_format)
Create ZED objects filled in the main loop
bodies = sl.Objects()
image = sl.Mat()
while viewer.is_available():
Grab an image
Retrieve left image
zed.retrieve_image(image, sl.VIEW.LEFT, sl.MEM.CPU, display_resolution)
Retrieve objects
zed.retrieve_objects(bodies, obj_runtime_param)
Update GL view
viewer.update_view(image, bodies)
Update OCV view
image_left_ocv = image.get_data()
cv_viewer.render_2D(image_left_ocv,image_scale,bodies.object_list, obj_param.enable_tracking, obj_param.body_format)
cv2.imshow(“ZED | 2D View”, image_left_ocv)
cv2.waitKey(10)
viewer.exit()
image.free(sl.MEM.CPU)
Disable modules and close camera
zed.disable_object_detection()
zed.disable_positional_tracking()
zed.close()
Sent from my iPhone
On Mar 23, 2023, at 7:32 AM, Antoine Lassagne (Stereolabs) support@stereolabs.com wrote:
Did you add my sample ?
Antoine Lassagne
yes i am using sample body_tracking.py and in that i have added whatevee you have said, please tell me what more changes and where to do so that i can get person id .
please
Sent from my iPhone
yes i have added your sample , for the same i am attaching the code file
Hi again. You did not add my code to the sample. Please add it right after “zed.retrieve_objects(bodies, obj_runtime_param)”.
Regards,
Antoine Lassagne
Actually in body_tracking.py file we have zed.enable_object_detection(obj_param),
we dont have zed.retrieve(obj_params)
can you please explain me on which puthon file i have to your code
Sent from my iPhone
I can see the line zed.retrieveobjects(bodies, objruntime_param) in the file you sent. Just copy paste my code after it.
Regards,
Antoine Lassagne
Hi anitone ,
where i have to add your code
Sent from my iPhone
I strongly advise that you learn a bit of python. There are good tutorials on the internet. Stereolab’s tutorial are also very easy to understand. One hour or two should be enough if you’re a fast learner. Without that, you will not be able to go much further with your project.
Antoine Lassagne
could you please send me your code again.
Sent from my iPhone
Here is the code :
Antoine Lassagne
