Area Memory ROS2
This is a good guess, but in “2D mode” the data size is the same.
The ZED ROS2 Wrapper forces the 2D mode simply by setting the Z coordinate to a fixed value; the data format is not changed.
That makes sense, Thank you so much for the info!
Hi @Myzhar,
Is there any update/ new findings for this issue? Any updates/workarounds are appreciated. Let me know if more info is needed
Hi @hey_you
We are still working on the code.
Thanks for the update! I will share some new data for debugging over email.
Hi @Myzhar,
I’m hitting persistent Area Memory issues with the latest ZED ROS2 wrapper on an NVIDIA Jetson (L4T 36.4.0 / Ubuntu 22.04 / ROS2 Humble). Running inside Docker, built from the official zed-ros2-wrapper/docker guide.
What’s happening:
  • Save warning:
    When Area Memory is enabled with a save path, I get “Failed to save area memory: FILE ERROR” on exit — but a valid .area file (~60 MB) is still created. For Gen‑3 this can apparently be ignored; does that also apply to Gen‑1 / Gen‑2?
  • Segfault on re-runs:
    On the second (or later) run with the saved .area file present, the node crashes after a bit with “Unhandled internal exception (slutils)” and segfault (-11). No issues on the first run or if no .area file is used.
I used to get solid odometry from the ZED2i, but lately it fails to lock even after adjusting params. My goal is to fuse wheel odom + ZED odom + ZED IMU in an EKF, but right now the ZED odom itself is unstable.
Any suggestions or docs on improving odom fusion or troubleshooting this behavior would be greatly appreciated.
