Apt upgrade fails
I did unbox my brand-new Zed Box mini Orin NX 16GB.
I tried apt update, apt upgrade and apt dist-upgrade as described in the setup guide.
After the dist-upgrade something failed and the apt update is not working anymore.
This is the output:
udo apt upgrade
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
  python2.7-minimal qt5-qmake-bin libzvbi-common qtbase5-dev-tools
  libqt5core5a libzbar0 libiperf0 libjs-jquery-ui libqt5network5
  libqt5concurrent5 libqt5dbus5 libopenexr25 libqt5test5 libqt5widgets5
  python3-scipy libpostproc55 libopencv-core4.5d libqt5gui5
  libqt5printsupport5 libavcodec58 libqt5xml5 libgstreamer-plugins-bad1.0-0
  libqt5opengl5 iperf3 libpython2.7 qtbase5-dev libavutil56 libqt5sql5
  libswscale5 freeglut3 gir1.2-gst-plugins-bad-1.0 libswresample3 qt5-qmake
  libavformat58 libzvbi0 gstreamer1.0-plugins-bad libgstreamer-opencv1.0-0
  python2.7 libde265-0 libpython2.7-minimal freeglut3-dev libpython2.7-stdlib
  libgstreamer-plugins-bad1.0-dev libavfilter7
Learn more about Ubuntu Pro at https://ubuntu.com/pro
The following packages have been kept back:
  libnss-systemd libpam-systemd libsystemd0 libudev-dev libudev1 systemd systemd-oomd systemd-sysv udev
0 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
7 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up nvidia-l4t-bootloader (36.4.7-20250918154033) ...
Warning: Cannot get compatible board name.
3767-000-0000--1--p3509-a02-p3767-0000-
TNSPEC 3767-303-0000-B.1-1-1-p3509-a02-p3767-0000-
COMPATIBLE_SPEC 3767-000-0000--1--p3509-a02-p3767-0000-
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3767-000-0000--1--p3509-a02-p3767-0000-.
Info: The esp is already mounted to /boot/efi.
INFO. Dump slots info:
Current version: 36.4.4
Capsule update status: 0
Current bootloader slot: A
Active bootloader slot: A
num_slots: 2
slot: 0,             status: normal
slot: 1,             status: normal
INFO. Dump nv_boot_control.conf:
TEGRA_CHIPID 0x23
ERROR. 3767-000-0000--1--p3509-a02-p3767-0000- does not match any known boards.
dpkg: error processing package nvidia-l4t-bootloader (--configure):
 installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
Setting up nvidia-l4t-kernel (5.15.148-tegra-36.4.7-20250918154033) ...
Using the existing boot entry 'primary'
TEGRA_CHIPID 0x23
Starting kernel post-install procedure.
Rootfs AB is not enabled.
ERROR. Procedure for A_kernel update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-kernel (--configure):
 installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
 nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.7-20250918154033); however:
  Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
        No apport report written because MaxReports is reached already
                                                 dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-oot-modules:
 nvidia-l4t-kernel-oot-modules depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.7-20250918154033); however:
dpkg: error processing package nvidia-l4t-kernel-oot-modules (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
 nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.7-20250918154033); however:
dpkg: error processing package nvidia-l4t-display-kernel (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-oot-headers:
 nvidia-l4t-kernel-oot-headers depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.7-20250918154033); however:
dNo apport report written because MaxReports is reached already
        pkg: error processing package nvidia-l4t-kernel-oot-headers (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
 nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.7-20250918154033); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (--configure):
Processing triggers for nvidia-l4t-initrd (36.4.7-20250918154033) ...
Include /etc/nv-update-initrd/list.d/binlist
Include /etc/nv-update-initrd/list.d/modules
nv-update-initrd: Updating /boot/initrd from /etc/nv-update-initrd/list.d for kernel version 5.15.148-tegra..
Add /usr/sbin/nvluks-srv-app
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8126/r8126.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8168/r8168.ko
Add /lib/modules/5.15.148-tegra/modules*
Add /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme-core.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/thermal/tegra/tegra-bpmp-thermal.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/pwm/pwm-tegra.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/hwmon/pwm-fan.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/pci/controller/dwc/pcie-tegra194.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/phy/tegra/phy-tegra194-p2u.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/udc/tegra-xudc.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/ucsi/typec_ucsi.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/ucsi/ucsi_ccg.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/typec.ko
Updating modprobe.d configuration directories for modprobe..
Add config /etc/modprobe.d/alsa-base.conf
Add config /etc/modprobe.d/bcmdhd.conf
Add config /etc/modprobe.d/blacklist-ath_pci.conf
Add config /etc/modprobe.d/blacklist.conf
Add config /etc/modprobe.d/blacklist-firewire.conf
Add config /etc/modprobe.d/blacklist-framebuffer.conf
Add config /etc/modprobe.d/blacklist-modem.conf
Add config-link /etc/modprobe.d/blacklist-oss.conf
Add config /etc/modprobe.d/blacklist-rare-network.conf
Add config /etc/modprobe.d/denylist-nouveau.conf
Add config /etc/modprobe.d/denylist-oot-modules-audio.conf
Add config /etc/modprobe.d/denylist-ramoops.conf
Add config /etc/modprobe.d/denylist-tegra-safety.conf
Add config /etc/modprobe.d/denylist-tpm-ftpm-tee.conf
Add config /etc/modprobe.d/iwlwifi.conf
Add config /etc/modprobe.d/nvgpu.conf
Add config /etc/modprobe.d/nvidia-display.conf
Add config /etc/modprobe.d/tegra-udrm.conf
Add config /lib/modprobe.d/aliases.conf
Add config /lib/modprobe.d/fbdev-blacklist.conf
Add config /lib/modprobe.d/systemd.conf
Cleaning up the temporary directory for updating the initrd..
 nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
Is there any way to fix this?
I seem to have been able to fix the issue.
sudo apt-get autoclean
sudo mv /var/lib/dpkg/info/ /var/lib/dpkg/backup/
sudo mkdir /var/lib/dpkg/info/
sudo apt-get update
sudo apt-get -f install
Afterwards apt update && apt upgrade runs again.
Hi @MM10
The fix that you applied is discussed here:
What version of the ZED X Driver are you using? Normally, the new driver v1.3.2 should not cause this problem.
The installed version of the driver:
rc stereolabs-zedbox-mini 1.3.1-SL-MAX9296-all-ZEDBOX-MINI-L4T36.4.0 arm64        NVIDIA Kernel DTB Modified Package by Stereolabs
I confirm that an upgrade to the latest v1.3.2 will completely remove the problem.
