ZZED 2i Not Detected and Blue LED Not Turning On
Hello everyone,
I have been using a ZED 2i camera with a Jetson AGX Orin for a few months without any major issues. However, one day the ZED 2i was suddenly no longer detected by the system, and the blue LED on the camera did not light up as usual.
I have already tried several troubleshooting steps, including:
  • Tightening and reconnecting the USB cable
  • Changing to another USB cable
  • Connecting the camera to a USB 3.0 port on another computer
Unfortunately, the camera is still not working, and the blue LED still does not turn on.
Has anyone experienced a similar issue before? I would really appreciate any suggestions or guidance on what I should check next.
Thank you very much.
Hi @Unn-Phakapol-S
We need more details about your device’s status and system configuration to gain a clearer insight into the cause of your issue.
Could you connect the camera to the USB3 port, launch the ZED Diagnostic tool, and send the contents of the report file it produces?
Have you tried opening the camera with a Webcam application to verify if the video stream is available?
Thank you for your response. I connected the ZED 2i camera to a USB 3.0 port and ran the ZED Diagnostic tool as requested. I tried to attach the ZED Diagnostic report file, but I am currently unable to attach files because my account is still a new member on the forum.
I have also tried opening the camera with a webcam application to check whether the video stream is available. However, the ZED camera was not detected in the webcam application either.
Thank you very much for your help.
You can copy and paste the content of the file to this thread.
This is important information. Please send the content of the diagnostic file to proceed further.
Thank you for your reply.
As requested, I have copied and pasted the content of the ZED Diagnostic report into this thread below. Please find the diagnostic report content below:
"AI Models": {
    "info": \[
    "valid": \[
        "NEURAL LIGHT DEPTH is optimized"
"Camera Test": {
    "CorruptedFirmware": \[
    "GMSL driver": \[
    "GMSLList": \[
    "InternalDevicesCount (GMSL)": \[
    "InternalDevicesCount (USB)": \[
    "USBList": \[
            "USB_path": "/4",
            "idProduct": "0x0a2b",
            "idVendor": "0x8087"
            "USB_path": "/3",
            "idProduct": "0x3000",
            "idVendor": "0x3151"
            "USB_path": "/2",
            "idProduct": "0x2514",
            "idVendor": "0x0424"
    "ZEDCount": \[
    "ZEDDetected": \[
    "ZEDs": \[
    "error": \[
        "<b>No Camera detected</b> <br/> Make sure the camera is plugged in.",
    "warning": \[
        "<b>No GMSL driver found.</b><br/> USB camera are not impacted by this.",
"Data collection": {
    "dmesg": {
        "DMESG \[DTS\] LOG ": \[
            "dmesg: read kernel buffer failed: Operation not permitted"
        "DMESG \[MAX9x\] LOG": \[
        "DMESG \[PCA\] LOG ": \[
        "DMESG \[ZEDX\] LOG": \[
        "DTB list SLabs": \[
            "ls: cannot access '/boot/stereolabs/\*': No such file or directory"
        "DTB list original": \[
            "/boot/dtb/kernel_tegra234-p3737-0000+p3701-0004-nv.dtb"
        "Dpkg list Stereolabs": \[
        "Dpkg list zed": \[
        "Driver list": {
            "/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9295/sl_max9295.ko": "not found",
            "/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9296/max9296.ko": "not found",
            "/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9296/sl_max9296.ko": "not found",
            "/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max96712/max96712.ko": "not found",
            "/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max96712/sl_max96712.ko": "not found",
            "/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedone4k/sl_zedxone_uhd.ko": "not found",
            "/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedx/max96712.ko": "not found",
            "/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedx/sl_zedx.ko": "not found",
            "/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedxpro/sl_zedxpro.ko": "not found"
        "EXTlinux file": \[
            "TIMEOUT 30",
            "DEFAULT primary",
            "MENU TITLE L4T boot options",
            "LABEL primary",
            "      MENU LABEL primary kernel",
            "      LINUX /boot/Image",
            "      INITRD /boot/initrd",
            "      APPEND ${cbootargs} root=PARTUUID=54d2da42-2c6a-406e-a3b2-91d3f3c5ca53 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0",
            "# When testing a custom kernel, it is recommended that you create a backup of",
            "# the original kernel and add a new entry to this file so that the device can",
            "# fallback to the original kernel. To do this:",
            "# 1, Make a backup of the original kernel",
            "#      sudo cp /boot/Image /boot/Image.backup",
            "# 2, Copy your custom kernel into /boot/Image",
            "# 3, Uncomment below menu setting lines for the original kernel",
            "# 4, Reboot",
            "# LABEL backup",
            "#    MENU LABEL backup kernel",
            "#    LINUX /boot/Image.backup",
            "#    INITRD /boot/initrd",
            "#    APPEND ${cbootargs}"
        "I2C Trace list": {
            "I2C Trace /dev/i2C-0": \[
                "     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f",
                "00:                         -- -- -- -- -- -- -- -- ",
                "10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
                "20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
                "30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
                "40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
                "50: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
                "60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
                "70: -- -- -- -- -- -- -- --                         "
            "I2C Trace /dev/i2C-1": \[
                "10: -- -- -- -- -- -- -- -- -- -- -- -- -- 1d -- -- ",
                "40: UU UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
                "50: -- -- -- 53 -- -- -- -- -- -- -- -- -- -- -- -- ",
                "60: -- -- -- -- -- -- -- -- -- -- 6a -- -- -- -- -- ",
            "I2C Trace /dev/i2C-2": \[
                "50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
            "I2C Trace /dev/i2C-3": \[
            "I2C Trace /dev/i2C-6": \[
            "I2C Trace /dev/i2C-7": \[
            "I2C Trace /dev/i2C-8": \[
                "10: -- -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- ",
            "I2C Trace /dev/i2C-9": \[
                "Error: Bus doesn't support detection commands"
        "Jetpack": \[
            "# R36 (release), REVISION: 4.7, GCID: 42132812, BOARD: generic, EABI: aarch64, DATE: Thu Sep 18 22:54:44 UTC 2025",
            "# KERNEL_VARIANT: oot",
            "TARGET_USERSPACE_LIB_DIR=nvidia",
            "TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia"
        "Linux_uname": \[
            "Linux augo 5.15.148-tegra #1 SMP PREEMPT Thu Sep 18 15:08:33 PDT 2025 aarch64 aarch64 aarch64 GNU/Linux"
        "ZED SDK Version": {
            "Diag": "5.1.2",
            "RT": "5.1.2"
        "ZEDX Daemon Status LS": \[
            "Unit zed_x_daemon.service could not be found."
        "ZEDX Driver State": \[
        "i2C Trace": \[
            "i2c-0\\ti2c       \\t3160000.i2c                     \\tI2C adapter",
            "i2c-1\\ti2c       \\tc240000.i2c                     \\tI2C adapter",
            "i2c-2\\ti2c       \\t3180000.i2c                     \\tI2C adapter",
            "i2c-3\\ti2c       \\t3190000.i2c                     \\tI2C adapter",
            "i2c-4\\ti2c       \\tTegra BPMP I2C adapter          \\tI2C adapter",
            "i2c-5\\ti2c       \\t31b0000.i2c                     \\tI2C adapter",
            "i2c-6\\ti2c       \\t31c0000.i2c                     \\tI2C adapter",
            "i2c-7\\ti2c       \\tc250000.i2c                     \\tI2C adapter",
            "i2c-8\\ti2c       \\t31e0000.i2c                     \\tI2C adapter",
            "i2c-9\\ti2c       \\tNVIDIA SOC i2c adapter 0        \\tI2C adapter"
"GMSL DRIVER": {
    "GMSL driver": "",
    "error": \[
        "<b>No GMSL driver detected or not a Stereolabs board.</b>"
"Graphics Card": {
    "deviceCount": 1,
    "deviceDriverVersion": 12060,
    "devices": \[
            "arch": "Ampere",
            "computeCapability": "8.7",
            "cores": 1792,
            "name": "Orin",
            "totalMemoryBytes": "32188510208",
            "totalMemoryMB": 30697.35546875
    "glx_info": "OpenGL vendor string: NVIDIA Corporation\\nOpenGL renderer string: NVIDIA Tegra Orin (nvgpu)/integrated\\nOpenGL core profile version string: 4.6.0 NVIDIA 540.4.0\\nOpenGL core profile shading language version string: 4.60 NVIDIA\\nOpenGL core profile context flags: (none)\\nOpenGL core profile profile mask: core profile\\nOpenGL core profile extensions:\\nOpenGL version string: 4.6.0 NVIDIA 540.4.0\\nOpenGL shading language version string: 4.60 NVIDIA\\nOpenGL context flags: (none)\\nOpenGL profile mask: (none)\\nOpenGL extensions:\\nOpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 540.4.0\\nOpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20\\nOpenGL ES profile extensions:\\n",
    "initResult": 0,
    "valid": \[
        "<b>Graphics card: </b> Orin"
"Processor": {
    "L4T version": "36.4.7",
    "OS": "Ubuntu 22.04.5 LTS ",
    "avxSupported": false,
    "coreCount": "8",
    "cpu": " ARMv8 Processor rev 1 (v8l)",
    "datetime": "2026-06-12 10:22:15 AM",
    "hyperThreading": "0",
    "motherboard": "Jetson, NVIDIA",
    "ramCapacity": "32.188510",
    "ramUsage": "",
    "ramUsed": "6.181974",
    "threadCount": "8",
    "valid": \[
        "<b>Processor: </b>  ARMv8 Processor rev 1 (v8l)",
        "<b>Motherboard: </b> Jetson, NVIDIA"
"ZED SDK": {
    "CUDA Toolkit version": "V12.6.68 -->located in /usr/local/cuda-12.6/bin/nvcc",
    "CUDA loading": false,
    "GPU Driver Version": "Driver Version                            : 540.4.0",
    "GPU Performance": "    Performance State                     : N/A",
    "ZED SDK Version (Diag)": "5.1.2",
    "ZED SDK Version (RT)": "5.1.2",
    "ai": {
        "checkAI": true,
        "cudaVersion": 12060,
        "tensorVersion": 100300
    "binFiles": \[
        "libsl_ai.so",
        "libsl_zed.so"
    "resourcesFiles": \[
        "neural_depth_5.3.model",
        "neural_depth_light_5.2.model",
        "objects_accurate_3.2.model",
        "objects_medium_3.2.model",
        "objects_performance_3.2.model",
        "person_head_accurate_2.6.model",
        "person_head_performance_2.6.model",
        "person_reid_1.4.model",
        "positional_tracking_2.2.model",
        "skeleton_body18_3.2.model",
        "skeleton_body38_3.5.model"
    "resourcesFilesExpected": \[
        "objects_performance_3.2"
    "valid": \[
        "<b>ZED SDK version:</b> 5.1.2",
        "<b>CUDA version:</b> V12.6.68"
Please advise us on the next steps. Thank you so much.
Please write to support@stereolabs.com to request an RMA if the camera is still covered by warranty.
