Zed360 skeletons not converging
We are on Zed 5.4.1 -
Our cameras are about 6 meters apart - both set at about 2 meters up with a lot of overlap in their coverage - they are two corners of a 6x6 meter room looking approximately into the center.
No matter how long and how slow we walk around in circles the skeletons will not converge -
they flicker about a lot and at best end up a couple of meters apart -
Lighting is fairly diffuse and bright though there is a bit of shadow about…
Just wondering if this is something that’s known with 5.4.1? - or i guess maybe one of the cameras is not working correctly - any hints about what we can do to track down the issue?
Thanks
Hi @Rosss
Please try to upgrade to ZED SDK v5.5 and verify if the problem is present also with the latest release.
If that’s the case, please record synchronized SVOs from both cameras and share them with us to try to replicate and fix the issue.
