Hi all,
Is it possible to use ZED360 fusion with networked cameras (ZED+Jetson) without using ZED HUB login, is there a way just to add cameras to 360 configurator?
Thanks,
Hi all,
Thanks,
Right now, it is not possible to use networked fusion without ZED Hub. But you can use ZED Hub for free.
It’s possible, with the new update , I just checked and it detect cameras and you can make calibration .
One issue is about the latency and make the calibration not good . I don’t know if with HUB it’s better ? I need to try, keep in touch . ![]()
