I have been using ZED360 to calibrate a couple of ZED2i cameras and use Fusion over a space. I have tested it using the local workflow, and was able to successfully calibrate the cameras, and use the config file in some of the multi-camera samples provided in the ZED SDK. However, for my intended use case of the cameras, I will be having the cameras overlooking a much wider space and ideally connected to separate machines, and would like to calibrate over the network. I have tried various methods of getting this to work, but to no success. What exactly would I need to do for this to work? I assume I need some sort of client publisher that is running on these machines that allows ZED360 to subscribe to said data? Would it be possible to get a working baseline for this, or some sort of feedback on how I can get this working?
Yes you are right, you need to run a sample on each machine to send the skeleton data to the main server that will perform the fusion.
You can find a code example here : Fusion - Stereolabs
