When I install ZED SDK on Ubuntu (by VMware), it doesn’t working. So I have to install Ubuntu with dual boot, haven’t I?
Hi @bao
The ZED SDK requires CUDA and a GPU to run. You must verify if it is possible to enable GPU passthrough in VMware.
Otherwise, I suggest you use Docker instead:
https://www.stereolabs.com/docs/docker/
