I’m using the Zed2 camera for a robotics task, and I’m trying to set up the camera parameters in a simulator.
Zed2 says the FOV is 110deg (H) x 70deg (V).
I’m assuming this FOV is for the full stereo setup. The simulator requires me to describe the h-FOV and v-FOV of each mono camera, how would I calculate/retrieve that? I measured the two sensors to be 12cm apart.
