ZED X One S incorrectly labelled as the GS model in ZED_Explorer
Running ZED_Explorer --a provides the following output:
## Cam  0  ##
 Model :  "ZED XOne UHD"
 S/N :  314450192
 State :  "AVAILABLE"
 Path :  /dev/i2c-13
 Port :  2
 Type :  "GMSL"
## Cam  1  ##
 Model :  "ZED X Mini"
 S/N :  57570010
 State :  "AVAILABLE"
 Path :  /dev/i2c-13
 Port :  3
 Type :  "GMSL"
## Cam  2  ##
 Model :  "ZED XOne GS"
 S/N :  302077685
 State :  "AVAILABLE"
 Path :  /dev/i2c-9
 Port :  4
 Type :  "GMSL"
The reported “ZED XOne GS” is actually a “ZED XOne S”. I’ve attached the factory calibrations so that you can see the distortion matches that of a wide angle ZED X One S. The current workaround is to look at the conf files.
Is this intended/ a known issue?
Information for repro below:
  • Jetson AGX Orin, JetPack 6.2.1 (L4T 36.4.4)
  • ZED SDK 5.5.1
  • ZED Link Quad driver stereolabs-zedlink-quad_1.4.4-SL-MAX96712-L4T36.4.0
  • ZED x One S (port 4), ZED X Mini (port 0) and a ZED X One 4K (port 1)
Factory Calib file:
[CAM_FHD1200]
fx=459.1515889785598
fy=459.121726585473
cx=958.81073051658
cy=603.6656314455588
[CAM_FHD]
fy=459.121726585473
cx=958.81073051658
cy=543.66563144556
[CAM_SVGA]
fx=229.57579448928
fy=229.56086329274
cx=479.40536525829
cy=301.83281572278
[DISTO]
k1=0.07025877298616764
k2=0.007032183875637834
k3=-0.0022965599263144788
k4=-0.00028069517501942
k5=0
k6=0
p1=0
p2=0
[MISC]
Sensor_ID=1
Diagnostic file:
"AI Models": {
"info": [
"NEURAL LIGHT DEPTH is not optimized",
"NEURAL PLUS DEPTH is not optimized",
"NEURAL DEPTH INT8 is not optimized"
"CUDA Operations": {
"cudaDeviceCount": 1,
"cudaDriverVersion": 12060,
"cudaDriverVersionString": "12.6",
"cudaGetDeviceCountResult": 0,
"cudaRuntimeLoaded": true,
"cudaRuntimeVersion": 12060,
"cudaRuntimeVersionString": "12.6",
"cudaTestVersion": "1.0",
"gpuTests": [
"clockRateMHz": 1300,
"computeCapability": "8.7",
"computeCapabilityMajor": 8,
"computeCapabilityMinor": 7,
"freeResult": 0,
"freeSuccess": true,
"gpuId": 0,
"gpuName": "Orin",
"mallocResult": 0,
"mallocSuccess": true,
"memcpyD2HResult": 0,
"memcpyD2HSuccess": true,
"memcpyH2DResult": 0,
"memcpyH2DSuccess": true,
"memoryBusWidthBits": 256,
"memoryClockRateMHz": 1300,
"memsetResult": 0,
"memsetSuccess": true,
"multiProcessorCount": 16,
"pciBusId": 0,
"pciDeviceId": 0,
"pciDomainId": 0,
"setDeviceResult": 0,
"testElements": 1048576,
"testPassed": true,
"testSizeBytes": 4194304,
"totalGlobalMemMB": 62839,
"validationPassed": true
"testSizeMB": 1,
"valid": [
"GPU 0 (Orin): CUDA operations working correctly"
"GMSL DRIVER": {
"GMSL driver": "ii  stereolabs-zedlink-quad                      1.4.4-SL-MAX96712-L4T36.4.0                 arm64        NVIDIA Kernel DTB Modified Package by Stereolabs\n"
"Graphics Card": {
"deviceCount": 1,
"deviceDriverVersion": 12060,
"devices": [
"arch": "Ampere",
"cores": 2048,
"name": "Orin",
"totalMemoryBytes": "65891651584",
"totalMemoryMB": 62839.17578125
"glx_info": "",
"initResult": 0,
"valid": [
"Graphics card:  Orin"
"Log Kernel Trace (for ZED X)": {
"dmesg": {
"DMESG [DTS] LOG ": [
"dmesg: read kernel buffer failed: Operation not permitted"
"DMESG [MAX9x] LOG": [
"DMESG [PCA] LOG ": [
"DMESG [ZEDX] LOG": [
"DTB list SLabs": [
"board.py",
"extlinux.py",
"fio.py",
"Headers",
"Jetson",
"Linux",
"pycache",
"Utils",
"zlconfig"
"DTB list original": [
"/boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv.dtb"
"Dpkg list Stereolabs": [
"ii  stereolabs-zedlink-quad                      1.4.4-SL-MAX96712-L4T36.4.0                 arm64        NVIDIA Kernel DTB Modified Package by Stereolabs"
"Dpkg list zed": [
"Driver list": {
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9295/sl_max9295.ko": "exists",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9296/max9296.ko": "not found",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9296/sl_max9296.ko": "not found",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max96712/max96712.ko": "not found",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max96712/sl_max96712.ko": "exists",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedone4k/sl_zedxone_uhd.ko": "exists",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedx/max96712.ko": "not found",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedx/sl_zedx.ko": "exists",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedxpro/sl_zedxpro.ko": "not found"
"EXTlinux file": [
"TIMEOUT 30",
"DEFAULT Stereolabs",
"MENU TITLE L4T boot options",
"LABEL primary",
"      MENU LABEL primary kernel",
"      LINUX /boot/Image",
"      INITRD /boot/initrd",
"      APPEND ${cbootargs} root=PARTUUID=ef05a66d-bdb8-4a82-aebb-a826d50e69d8 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0 ",
"# When testing a custom kernel, it is recommended that you create a backup of",
"# the original kernel and add a new entry to this file so that the device can",
"# fallback to the original kernel. To do this:",
"# 1, Make a backup of the original kernel",
"#      sudo cp /boot/Image /boot/Image.backup",
"# 2, Copy your custom kernel into /boot/Image",
"# 3, Uncomment below menu setting lines for the original kernel",
"# 4, Reboot",
"# LABEL backup",
"#    MENU LABEL backup kernel",
"#    LINUX /boot/Image.backup",
"#    INITRD /boot/initrd",
"#    APPEND ${cbootargs}",
"LABEL Stereolabs",
"\tMENU LABEL Stereolabs kernel",
"\tLINUX /boot/Image",
"\tFDT /boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv.dtb",
"\tINITRD /boot/initrd",
"\tAPPEND ${cbootargs} root=PARTUUID=ef05a66d-bdb8-4a82-aebb-a826d50e69d8 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0",
"\tOVERLAYS /boot/tegra234-p3737-camera-zedlink-quad-sl-overlay.dtbo"
"I2C Trace list": {
"I2C Trace /dev/i2C-0": [
"     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f",
"00:                         -- -- -- -- -- -- -- -- ",
"10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"50: UU -- -- -- -- -- UU -- -- -- -- -- -- -- -- -- ",
"60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"70: -- -- -- -- -- -- -- --                         "
"I2C Trace /dev/i2C-1": [
"00:                         UU -- -- -- -- -- -- -- ",
"40: UU UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"I2C Trace /dev/i2C-10": [
"20: -- -- -- -- -- -- -- -- -- 29 -- -- -- -- -- -- ",
"70: UU -- -- -- -- -- -- --                         "
"I2C Trace /dev/i2C-11": [
"I2C Trace /dev/i2C-12": [
"20: -- -- -- -- -- -- -- -- 28 -- -- -- -- -- -- -- ",
"I2C Trace /dev/i2C-13": [
"10: -- -- -- -- -- -- -- -- 18 19 UU -- UU -- -- -- ",
"20: -- -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- ",
"30: UU -- -- -- -- -- -- -- UU -- -- UU 3c -- -- -- ",
"40: -- -- -- -- UU -- -- -- -- 49 -- UU 4c -- -- -- ",
"50: -- -- -- -- 54 55 -- -- -- -- -- -- -- -- -- -- ",
"60: -- -- -- UU -- -- -- -- 68 69 -- -- -- -- -- -- ",
"I2C Trace /dev/i2C-14": [
"10: -- -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- ",
"I2C Trace /dev/i2C-15": [
"I2C Trace /dev/i2C-16": [
"I2C Trace /dev/i2C-2": [
"10: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"30: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- -- ",
"60: -- -- -- -- -- -- UU -- -- -- -- -- -- -- -- -- ",
"I2C Trace /dev/i2C-3": [
"I2C Trace /dev/i2C-6": [
"I2C Trace /dev/i2C-7": [
"I2C Trace /dev/i2C-8": [
"10: -- -- -- -- -- -- -- -- -- -- UU -- UU -- -- -- ",
"30: UU -- -- -- -- -- -- -- UU -- -- UU -- -- -- -- ",
"40: -- -- -- -- UU -- -- -- -- -- -- UU -- -- -- -- ",
"60: -- -- -- UU -- -- -- -- -- -- -- -- -- -- -- -- ",
"I2C Trace /dev/i2C-9": [
"10: UU -- -- -- -- -- -- -- 18 -- -- -- -- -- -- -- ",
"30: -- -- -- -- -- -- -- -- -- -- -- UU 3c -- -- -- ",
"50: -- -- -- -- -- -- 56 57 -- -- -- -- -- -- -- -- ",
"60: -- -- -- -- -- -- UU -- 68 -- -- -- -- -- -- -- ",
"Jetpack": [
"# R36 (release), REVISION: 4.4, GCID: 41062509, BOARD: generic, EABI: aarch64, DATE: Mon Jun 16 16:07:13 UTC 2025",
"# KERNEL_VARIANT: oot",
"TARGET_USERSPACE_LIB_DIR=nvidia",
"TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia"
"Linux_uname": [
"Linux walle-orin 5.15.148-tegra #1 SMP PREEMPT Mon Jun 16 08:24:48 PDT 2025 aarch64 aarch64 aarch64 GNU/Linux"
"ZED SDK Version": {
"Diag": "5.5.1",
"RT": "5.5.1"
"ZEDX Daemon Status LS": [
"● zed_x_daemon.service - ZED-X Daemon service",
"     Loaded: loaded (/etc/systemd/system/zed_x_daemon.service; enabled; vendor preset: enabled)",
"     Active: active (running) since Thu 1970-01-01 00:00:56 UTC; 56 years 9 months ago",
"   Main PID: 3246 (ZEDX_Daemon)",
"      Tasks: 5 (limit: 74765)",
"     Memory: 1.3M",
"        CPU: 4.614s",
"     CGroup: /system.slice/zed_x_daemon.service",
"             └─3246 /usr/sbin/ZEDX_Daemon",
"Jan 01 00:00:56 walle-orin systemd[1]: Started ZED-X Daemon service."
"ZEDX Driver State": [
"sl_zedxone_uhd         40960  0",
"sl_zedx                36864  1",
"sl_zedxhdr             24576  0",
"sl_max9295             16384  3 sl_zedxhdr,sl_zedxone_uhd,sl_zedx",
"sl_max96712            36864  4 sl_zedxhdr,sl_zedxone_uhd,sl_max9295,sl_zedx",
"tegra_camera          217088  13 nvhost_isp5,nvhost_nvcsi_t194,sl_zedxhdr,sl_zedxone_uhd,nv_hawk_owl,nvhost_vi5,sl_zedx",
"videodev              249856  11 v4l2_async,sl_zedxhdr,videobuf2_v4l2,tegra_camera,sl_zedxone_uhd,videobuf2_common,sl_zedx"
"i2C Trace": [
"i2c-0\ti2c       \t3160000.i2c                     \tI2C adapter",
"i2c-1\ti2c       \tc240000.i2c                     \tI2C adapter",
"i2c-2\ti2c       \t3180000.i2c                     \tI2C adapter",
"i2c-3\ti2c       \t3190000.i2c                     \tI2C adapter",
"i2c-4\ti2c       \tTegra BPMP I2C adapter          \tI2C adapter",
"i2c-5\ti2c       \t31b0000.i2c                     \tI2C adapter",
"i2c-6\ti2c       \t31c0000.i2c                     \tI2C adapter",
"i2c-7\ti2c       \tc250000.i2c                     \tI2C adapter",
"i2c-8\ti2c       \t31e0000.i2c                     \tI2C adapter",
"i2c-9\ti2c       \ti2c-2-mux (chan_id 0)           \tI2C adapter",
"i2c-10\ti2c       \ti2c-2-mux (chan_id 1)           \tI2C adapter",
"i2c-11\ti2c       \ti2c-2-mux (chan_id 2)           \tI2C adapter",
"i2c-12\ti2c       \ti2c-2-mux (chan_id 3)           \tI2C adapter",
"i2c-13\ti2c       \ti2c-8-mux (chan_id 0)           \tI2C adapter",
"i2c-14\ti2c       \ti2c-8-mux (chan_id 1)           \tI2C adapter",
"i2c-15\ti2c       \ti2c-8-mux (chan_id 2)           \tI2C adapter",
"i2c-16\ti2c       \ti2c-8-mux (chan_id 3)           \tI2C adapter",
"i2c-17\ti2c       \tNVIDIA SOC i2c adapter 0        \tI2C adapter"
"Processor": {
"L4T version": "36.4.4",
"OS": "Ubuntu 22.04.5 LTS ",
"avxSupported": false,
"coreCount": "12",
"cpu": " ARMv8 Processor rev 1 (v8l)",
"datetime": "2026-10-26 11:09:17 PM",
"hyperThreading": "0",
"motherboard": "Jetson, NVIDIA",
"platform": "NVIDIA Jetson (L4T)",
"ramCapacity": "65.891652",
"ramUsage": "",
"ramUsed": "18.709217",
"threadCount": "12",
"valid": [
"Processor:   ARMv8 Processor rev 1 (v8l)",
"Motherboard:  Jetson, NVIDIA"
"USB Camera": {
"CorruptedFirmware": [
"GMSL driver": [
"GMSLList": [
"Serial": "302077685",
"id": 0,
"path": "/dev/i2c-9",
"state": "Available"
"Serial": "57570010",
"Sub Model": "ZED-XG Mini",
"id": 1,
"path": "/dev/i2c-13",
"Serial": "314450192",
"id": 2,
"id": 1,
"id": 2,
"InternalDevicesCount (GMSL)": [
"InternalDevicesCount (USB)": [
"USBList": [
"USB_path": "/3",
"idProduct": "0x0420",
"idVendor": "0x0bda"
"USB_path": "/4/3",
"idProduct": "0x9091",
"idVendor": "0x1199"
"USB_path": "/4/1",
"idProduct": "0xea70",
"idVendor": "0x10c4"
"USB_path": "/4",
"idProduct": "0x5420",
"USB_path": "/3",
"idProduct": "0x3549",
"idVendor": "0x13d3"
"ZEDCount": [
"ZEDs": [
"ZED SDK": {
"CUDA Toolkit version": "V12.6.68 -->located in /usr/local/cuda-12.6/bin/nvcc",
"CUDA loading": false,
"GPU Driver Version": "Driver Version                            : 540.4.0",
"GPU Performance": "    Performance State                     : N/A",
"ZED SDK Version (Diag)": "5.5.1",
"ZED SDK Version (RT)": "5.5.1",
"ai": {
"checkAI": true,
"cudaVersion": 12060,
"tensorVersion": 100300
"binFiles": [
"libsl_ai.so",
"libsl_zed.so"
"resourcesFiles": [
"neural_depth_5.3.model",
"neural_depth_5.3.model2",
"neural_depth_light_5.2.model",
"neural_depth_light_5.3.model2"
"resourcesFilesExpected": [
"objects_performance_3.2"
"valid": [
"ZED SDK version: 5.5.1",
"CUDA version: V12.6.68"
Hi @s.ven
Cam 2 ## Model : “ZED XOne GS”
This is the expected behavior and not an error.
The ZED X One S and the ZED X One GS are practically the same camera; the only difference is the size, as the ZED X One S has a more compact and lightweight form factor.
For this reason, the ZED SDK uses the ZED X One GS model name for the ZED X One S too, and you can use your camera with all the ZED SDK features available for the ZED X One GS, including the virtual stereo camera configuration.
Thank you for the clarification @Myzhar !
