ZED X One GS Narrow at 20–40 cm?
I am evaluating the ZED X One GS for a close-range industrial inspection setup.
My working distance is 20–40 cm, and I need to inspect small plastic pins/components of about 4 cm height and 1 cm diameter on a conveyor. I want to detect whether each one is present, deformed, or missing.
My main question is about the optics:
  1. For this distance, would you recommend the 4 mm narrow version?
  2. Can the standard ZED X One GS lens achieve sharp focus at 20 cm, or is a custom / lensless S-mount setup better?
I plan to use this with Ultralytics YOLO on a ZED Box Orin NX.
Thanks.
Out of both available lenses ( narrow/wide), the wide lense provides the shortest focus distance which sits at around 28 cms.
Best
