Environment:
- Camera: ZED X
- Host: ZED Box Orin NX 16 GB (JetPack 6.0, MAXN/jetson_clocks)
- Depth Mode: NEURAL_LIGHT, SVGA@60
- Display: HDMI output active during execution
Code (C++):
#include "m3t/zed_camera.h"
ZedCamera::~ZedCamera() {
if (initial_set_up_) zed_.close();
ZedCamera &ZedCamera::GetInstance() {
static ZedCamera zed;
return zed;
void ZedCamera::UseColorCamera() { use_color_camera_ = true; }
void ZedCamera::UseDepthCamera() { use_depth_camera_ = true; }
bool ZedCamera::GrabFrame() {
if (!is_opened_) return false;
if (zed_.grab(runtime_params_) != sl::ERROR_CODE::SUCCESS) return false;
int ZedCamera::RegisterID() {
const std::lock_guard<std::mutex> lock{mutex_};
update_capture_ids_.insert({next_id_, true});
return next_id_++;
bool ZedCamera::UnregisterID(int id) {
return update_capture_ids_.erase(id);
bool ZedCamera::SetUp(bool svo_mode, const std::string &svo_path) {
if (!initial_set_up_) {
init_params_.depth_mode = sl::DEPTH_MODE::NEURAL_LIGHT;
init_params_.coordinate_units = sl::UNIT::METER;
init_params_.camera_resolution = sl::RESOLUTION::SVGA;
//init_params_.depth_minimum_distance = 0.5 ; // Set the minimum depth perception distance to 15cm
init_params_.depth_maximum_distance = 20 ; // Set the minimum depth perception distance to 15cm
init_params_.camera_fps = 60;
if (svo_mode) init_params_.input.setFromSVOFile(svo_path.c_str());
if (zed_.open(init_params_) != sl::ERROR_CODE::SUCCESS) return false;
runtime_params_.confidence_threshold = 100;
runtime_params_.enable_fill_mode = true;
runtime_params_.texture_confidence_threshold = 100;
if (use_color_camera_) {
zed_.retrieveImage(color_image_, sl::VIEW::LEFT, sl::MEM::CPU);
color_intrinsics_ = zed_.getCameraInformation().camera_configuration.calibration_parameters.left_cam;
if (use_depth_camera_) {
zed_.retrieveMeasure(depth_image_, sl::MEASURE::DEPTH, sl::MEM::CPU);
depth_intrinsics_ = zed_.getCameraInformation().camera_configuration.calibration_parameters.left_cam;
initial_set_up_ = true;
return true;
bool ZedCamera::UpdateCapture(int id, bool type) {
if (!initial_set_up_) return false;
if (update_capture_ids_.at(id)) {
if (type){
//std::cout << type << "valore type";
if (use_color_camera_) zed_.retrieveImage(color_image_, sl::VIEW::LEFT, sl::MEM::CPU);
if (use_depth_camera_) zed_.retrieveMeasure(depth_image_, sl::MEASURE::DEPTH, sl::MEM::CPU);
for (auto &[_, v] : update_capture_ids_) v = false;
update_capture_ids_.at(id) = true;
return true;
bool ZedCamera::use_color_camera() const { return use_color_camera_; }
bool ZedCamera::use_depth_camera() const { return use_depth_camera_; }
const sl::Mat &ZedCamera::color_image() const { return color_image_; }
const sl::Mat &ZedCamera::depth_image() const { return depth_image_; }
const sl::CameraParameters &ZedCamera::color_intrinsics() const { return color_intrinsics_; }
const sl::CameraParameters &ZedCamera::depth_intrinsics() const { return depth_intrinsics_; }
float ZedCamera::depth_scale() const { return depth_scale_; }
float ZedCamera::get_image_fps() {
// versione senza argomenti: restituisce gli FPS misurati
return zed_.getCurrentFPS();
ZedColorCamera::ZedColorCamera(const std::string &name, float image_scale)
: ColorCamera{name}, image_scale_{image_scale}, zed_{ZedCamera::GetInstance()} {
zed_.UseColorCamera();
zed_id_ = zed_.RegisterID();
ZedColorCamera::ZedColorCamera(const std::string &name, const std::filesystem::path &metafile_path)
: ColorCamera{name, metafile_path}, zed_{ZedCamera::GetInstance()} {
ZedColorCamera::~ZedColorCamera() {
zed_.UnregisterID(zed_id_);
bool ZedColorCamera::SetUp() {
set_up_ = false;
if (!metafile_path_.empty()) if (!LoadMetaData()) return false;
if (!initial_set_up_ && !zed_.SetUp()) return false;
GetIntrinsics();
// 1) leggi i parametri raw dalla ZED
const sl::CameraParameters &p = zed_.color_intrinsics();
// 2) la camera matrix non rettificata
cv::Mat1f K(3,3);
K << p.fx, 0.f, p.cx,
0.f, p.fy, p.cy,
0.f, 0.f, 1.f;
// 3) il vettore di distorsione completo
cv::Mat1f D(1,12);
for (int i = 0; i < 12; ++i)
D(0,i) = static_cast<float>(p.disto[i]);
// 4) la camera matrix rettificata (eventualmente scalata)
cv::Mat1f Kn(3,3);
Kn << intrinsics_.fu, 0.f, intrinsics_.ppu,
0.f, intrinsics_.fv, intrinsics_.ppv,
0.f, 0.f, 1.f;
// 5) costruisci le mappe di remap
cv::initUndistortRectifyMap(
K, D, cv::Mat(), // no R
Kn,
cv::Size{intrinsics_.width, intrinsics_.height},
CV_32FC1,
distortion_map1_, // membro cv::Mat
distortion_map2_ // membro cv::Mat
set_camera2world_pose(Transform3fA::Identity());
SaveMetaDataIfDesired();
set_up_ = true;
return UpdateImage(true);
bool ZedColorCamera::UpdateImage(bool synchronized) {
using Clock = std::chrono::high_resolution_clock;
auto t0 = Clock::now();
if (!set_up_) return false;
zed_.UpdateCapture(zed_id_, true);
const sl::Mat &zed_image = zed_.color_image();
cv::Mat rgba(
zed_image.getHeight(),
zed_image.getWidth(),
CV_8UC4,
zed_image.getPtr<sl::uchar1>(sl::MEM::CPU),
zed_image.getStepBytes(sl::MEM::CPU)
//cv::Mat rgb;
cv::cvtColor(rgba, image_, cv::COLOR_RGBA2RGB);
auto t1 = Clock::now();
//std::cout << "[TIMING UPDATE COLOR]" << std::chrono::duration_cast<std::chrono::milliseconds>(t1 - t0).count() << "ms";
//std::cerr << "Update image color";
// 2) undistort
//cv::remap(rgb, image_, distortion_map1_, distortion_map2_,
// cv::INTER_LINEAR, cv::BORDER_CONSTANT);
return true;
void ZedColorCamera::set_image_scale(float image_scale) {
image_scale_ = image_scale;
set_up_ = false;
float ZedColorCamera::image_scale() const { return image_scale_; }
bool ZedColorCamera::LoadMetaData() {
cv::FileStorage fs;
if (!OpenYamlFileStorage(metafile_path_, &fs)) return false;
ReadOptionalValueFromYaml(fs, "camera2world_pose", &camera2world_pose_);
ReadOptionalValueFromYaml(fs, "save_directory", &save_directory_);
ReadOptionalValueFromYaml(fs, "save_index", &save_index_);
ReadOptionalValueFromYaml(fs, "save_image_type", &save_image_type_);
ReadOptionalValueFromYaml(fs, "save_images", &save_images_);
ReadOptionalValueFromYaml(fs, "image_scale", &image_scale_);
fs.release();
if (save_directory_.is_relative())
save_directory_ = metafile_path_.parent_path() / save_directory_;
world2camera_pose_ = camera2world_pose_.inverse();
return true;
void ZedColorCamera::GetIntrinsics() {
const sl::CameraParameters ¶m = zed_.color_intrinsics();
intrinsics_.fu = param.fx * image_scale_;
intrinsics_.fv = param.fy * image_scale_;
intrinsics_.ppu = param.cx;
intrinsics_.ppv = param.cy;
intrinsics_.width = param.image_size.width;
intrinsics_.height = param.image_size.height;
ZedDepthCamera::ZedDepthCamera(const std::string &name, float image_scale, float depth_offset)
: DepthCamera{name}, image_scale_{image_scale}, depth_offset_{depth_offset}, zed_{ZedCamera::GetInstance()} {
zed_.UseDepthCamera();
ZedDepthCamera::ZedDepthCamera(const std::string &name, const std::filesystem::path &metafile_path)
: DepthCamera{name, metafile_path}, zed_{ZedCamera::GetInstance()} {
ZedDepthCamera::~ZedDepthCamera() {
bool ZedDepthCamera::SetUp() {
set_up_ = false;
GetIntrinsics();
cv::Mat1f K(3,3);
0.f, p.fy, p.cy,
0.f, 0.f, 1.f;
cv::Mat1f D(1,12);
cv::Mat1f Kn(3,3);
0.f, 0.f, 1.f;
Kn,
CV_32FC1,
set_up_ = true;
bool ZedDepthCamera::UpdateImage(bool synchronized) {
zed_.UpdateCapture(zed_id_, false);
const sl::Mat &zed_depth = zed_.depth_image();
cv::Mat depth_mat(
zed_depth.getHeight(),
zed_depth.getWidth(),
CV_32FC1,
zed_depth.getPtr<sl::float1>(sl::MEM::CPU),
zed_depth.getStepBytes(sl::MEM::CPU)
image_ = depth_mat.clone();
// 2) Applica offset in float
if (depth_offset_ != 0.0f) {
image_ += (depth_offset_ / depth_scale_);
//std::cout << "[TIMING UPDATE DEPTH]" << std::chrono::duration_cast<std::chrono::milliseconds>(t1 - t0).count() << "ms";
//std::cerr << "Update image depth";
// 3) *** Conserva il float puro ***
/*cv::remap(
image_,
image_, // CV_32FC1
distortion_map1_,
distortion_map2_,
cv::INTER_NEAREST,
cv::BORDER_CONSTANT,
std::numeric_limits<float>::quiet_NaN() // o 0 come preferisci
return true;
void ZedDepthCamera::set_image_scale(float image_scale) {
set_up_ = false;
void ZedDepthCamera::set_depth_offset(float depth_offset) {
depth_offset_ = depth_offset;
float ZedDepthCamera::image_scale() const { return image_scale_; }
float ZedDepthCamera::depth_offset() const { return depth_offset_; }
bool ZedDepthCamera::LoadMetaData() {
cv::FileStorage fs;
ReadOptionalValueFromYaml(fs, "depth_offset", &depth_offset_);
fs.release();
return true;
void ZedDepthCamera::GetIntrinsics() {
const sl::CameraParameters ¶m = zed_.depth_intrinsics();
Observed:
grab()consistently takes 18–22 ms → ~45 FPS theoretical.- Full pipeline (grab + retrieveImage + cv::imshow) tops out at ≈ 35 FPS.
- ZED Depth Viewer on the same hardware shows RGB 60 FPS + depth 30 FPS in “Neural” mode, but custom C++ can’t reproduce better than ~35 FPS.
Question for StereoLabs / community:
Is there any way to further accelerate the ZED SDK’s Neural Light (or Neural) depth path on Orin NX (e.g. TensorRT/DLA flags, compile‐time options), or is the ≈ 20 ms grab latency a hard hardware limit on the ZED Box?
