I recently purchased a ZED Box and a ZED X Nano and connected them, but the camera is not being detected.
The ZED X Mini, which we purchased at the same time, is working normally.
When we first received the ZED Box, ZED SDK version 5.2.3 was pre-installed. However, since we found that the ZED X Nano is supported starting from SDK version 5.3, we updated the SDK to the latest version. Unfortunately, the same issue persists.
The following error message appears:
Error: CAMERA MOTION SENSORS NOT DETECTED (Code 6)
Could you please advise us on how to resolve this issue?
We would appreciate your assistance in identifying the cause of this problem and finding a solution.
The ZED X Nano needs ZED SDK v5.3 or newer and ZED X Driver v1.4.2 or newer. Updating the ZED SDK does not update the ZED X Driver. The driver that came installed with ZED SDK v5.2.3 is most likely older than v1.4.2, so it supports the ZED X Mini but not the ZED X Nano. That would explain the CAMERA MOTION SENSORS NOT DETECTED error.
Please update the driver to the latest version (v1.5.0):
Check your L4T version: cat /etc/nv_tegra_release
Find the name of the ZED X Driver package that is installed now: dpkg -l | grep stereolabs
Uninstall it: sudo dpkg -r <package_name>
Download the v1.5.0 package that matches your ZED Box model and L4T version from the ZED X Drivers page, then install it: sudo dpkg -i <downloaded_file>.deb
Reboot the ZED Box.
If the camera is still not detected after that, please run sudo ZED_Diagnostic --dmesg and attach the generated report to this thread.
