Hi, The existing ZED python driver has high GPU utilization even with the depth inference turned off, so we want to switch to OpenCV and use just the left eye as a UVC camera. However, it does not work. The following code gives a green image:
To run:
pip install vuer==0.0.15rc3
# import the opencv library
import asyncio
import cv2
from vuer import Vuer, VuerSession
from vuer.schemas import Scene, ImageBackground
from vuer.serdes import jpg
# define a video capture object
vid = cv2.VideoCapture(-1)
# vid.set(cv2.CAP_PROP_FPS, 120)
app = Vuer(port=8112, uri="ws://localhost:8112")
@app.spawn(start=True)
async def main(session: VuerSession):
print("session started")
session.set @ Scene()
while True:
try:
# Capture the video frame
# by frame
ret, frame = vid.read()
if not ret:
print("failed to read frame")
frame = cv2.cvtColor(frame, cv2.COLOR_BGR2RGB)
session.upsert(
ImageBackground(
src=jpg(frame, 95),
key="image",
to="bgChildren",
await asyncio.sleep(0.01)
except KeyboardInterrupt:
break
# After the loop release the cap object
vid.release()
