ZED X connection issues
I’m trying to use ZED X camera on ZED Box Orin NX 16GB. When I open ZED Explorer, it starts streaming video from it, which stops after about 10-30, showing this error in the terminal after few more seconds:
(Argus) Error Timeout:  (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Restarting ZED Explorer doesn’t restart the streaming - to do so, I need to restart both nvargus-daemon and zed_x_daemon, but after that the whole process repeats - streams freeze after 10-30s. Problem is not limited to ZED Explorer - nearly the same issues happen with ROS2 wrapper - I’m able to start it and receive data for some time, then it stops.
There is a lot of happening in the logs:
  • dmesg show some I2C issues related to ZED X: Failed to register i2c client eeprom_zedxone_uhd at 0x54 (-16)
  • journalctl shows hundreds of nvargus-daemon errors and warnings
I’ve also tried updating the ZED X drivers (currently, I’m using 1.2.0-LI-MAX96712-all-ZEDBOX-L4T36.3.0), but it didn’t help.
Just to mention - I have the second set of hardware (ZED X + ZED Box), on which everything works without similar issues.
ZED_Diagnostic dmesg output:
Created: Wed Nov 27 2024
[   13.361160] sl_max96712 9-0029: sl_max96712_get_camera_model: zedx camera connected to this port
[   13.375828] sl_max96712 9-0029: print_sensor_info: camera zedx
[   13.390630] sl_max96712 9-0029: print_sensor_info: camera zedx
[   13.862478] sl_max9295 9-0062: probe_serializer: Serializer for zedx detect success
[   13.862690] sl_max9295 9-0044: sl_max9295_probe: zedx-uhd-id 0 found in dts
[   13.983362] sl_max9295 10-0062: probe_serializer: Serializer for zedx detect error
[   13.983616] sl_max9295 10-0044: sl_max9295_probe: zedx-uhd-id 1 found in dts
[   14.063579] zedx 9-0010: Driver Version : v1.2.0
[   14.063586] zedx 9-0010: Probing v4l2 sensor.
[   14.063731] zedx 9-0010: tegracam sensor driver:video4_v2.0.6
[   14.115656] zedx 9-0010: ZED-X detect error
[   14.115708] zedx 9-0010: zedx_probe: ar0234 initialization failed
[   14.115766] zedx: probe of 9-0010 failed with error -1
[   14.115841] zedx 9-0020: Driver Version : v1.2.0
[   14.115844] zedx 9-0020: Probing v4l2 sensor.
[   14.115993] zedx 9-0020: tegracam sensor driver:video1_v2.0.6
[   14.234700] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 9-0020 bound
[   14.238482] zedx 9-0020: Detected ZED-X sensor
[   14.238491] zedx 9-0020: zedx_probe: Serial Number : 44183026
[   14.243896] zedx 9-0028: Driver Version : v1.2.0
[   14.243906] zedx 9-0028: Probing v4l2 sensor.
[   14.244128] zedx 9-0028: tegracam sensor driver:video0_v2.0.6
[   14.246181] zedx 9-0020: zedx_open: Accessing the camera
[   14.330503] i2c i2c-9: Failed to register i2c client eeprom_zedx at 0x54 (-16)
[   14.330518] zedx 9-0028: zedx_eeprom_device_init: Failed to probe EEPORM at addr = 0x54
[   14.330521] zedx 9-0028: Failed to allocate eeprom reg map: -19
[   14.330746] zedx 9-0028: zedx_probe_ar0234: use serial number of the first sensor
[   14.338542] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 9-0028 bound
[   14.339471] zedx 9-0028: Detected ZED-X sensor
[   14.339477] zedx 9-0028: zedx_probe: Serial Number : 44183026
[   14.340223] zedx 10-0010: Driver Version : v1.2.0
[   14.340229] zedx 10-0010: Probing v4l2 sensor.
[   14.340472] zedx 10-0010: tegracam sensor driver:video5_v2.0.6
[   14.344635] zedx 9-0028: zedx_open: Accessing the camera
[   14.387241] zedx 10-0010: ZED-X detect error
[   14.387284] zedx 10-0010: zedx_probe: ar0234 initialization failed
[   14.387338] zedx: probe of 10-0010 failed with error -1
[   14.387410] zedx 10-0020: Driver Version : v1.2.0
[   14.387413] zedx 10-0020: Probing v4l2 sensor.
[   14.387546] zedx 10-0020: tegracam sensor driver:video3_v2.0.6
[   14.439231] zedx 10-0020: ZED-X detect error
[   14.439271] zedx 10-0020: zedx_probe: ar0234 initialization failed
[   14.439325] zedx: probe of 10-0020 failed with error -1
[   14.439396] zedx 10-0028: Driver Version : v1.2.0
[   14.439399] zedx 10-0028: Probing v4l2 sensor.
[   14.439526] zedx 10-0028: tegracam sensor driver:video2_v2.0.6
[   14.495012] zedx 10-0028: ZED-X detect error
[   14.495072] zedx 10-0028: zedx_probe: ar0234 initialization failed
[   14.495161] zedx: probe of 10-0028 failed with error -1
[   14.500511] zedxone_uhd 9-001a: tegracam sensor driver:video6_v2.0.6
[   14.500533] i2c i2c-9: Failed to register i2c client eeprom_zedxone_uhd at 0x54 (-16)
[   14.500536] zedxone_uhd 9-001a: Failed to allocate eeprom reg map: -19
[   14.500719] zedxone_uhd 9-001a: imx678_probe: You need an EEPROM for your first device entry
[   14.500721] zedxone_uhd 9-001a: imx678_probe: This might also happen because a ZED X was probbed first for this i2c bus
[   14.501996] zedxone_uhd 9-001a: imx678_probe: ZED-X One UHD detect error
[   14.502023] zedxone_uhd: probe of 9-001a failed with error -1
[   14.502206] zedxone_uhd 10-001a: tegracam sensor driver:video7_v2.0.6
[   14.503491] zedxone_uhd 10-001a: imx678_probe: ZED One UHD detection error
[   14.503522] zedxone_uhd: probe of 10-001a failed with error -1
[   18.670099] zedx 9-0020: zedx_open: Accessing the camera
[   18.670201] zedx 9-0028: zedx_open: Accessing the camera
[  130.258125] zedx 9-0028: zedx_set_mode: setting the device mode
[  130.991905] zedx 9-0020: zedx_set_mode: setting the device mode
############ DMESG [MAX9x] LOG #############
[   12.611383] sl_max96712 9-0029: sl_max96712_probe: enter
[   12.611443] sl_max96712 9-0029: sl_max96712_parse_dt: Using CSI port b
[   12.611446] sl_max96712 9-0029: sl_max96712_parse_dt: Number of declared cameras with this dts 6
[   12.839068] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: No camera connected to GMSL port 0
[   12.946987] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: No camera connected to GMSL port 1
[   13.055005] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: No camera connected to GMSL port 2
[   13.163221] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: Camera connected to GMSL port 3
[   13.375824] sl_max96712 9-0029: print_sensor_info: following comes from dts
[   13.375830] sl_max96712 9-0029: print_sensor_info: model id 0
[   13.375832] sl_max96712 9-0029: print_sensor_info: dts id 2
[   13.375833] sl_max96712 9-0029: print_sensor_info: n_lanes 2
[   13.375834] sl_max96712 9-0029: print_sensor_info: serial port 0
[   13.375835] sl_max96712 9-0029: print_sensor_info: vc-id 0
[   13.375836] sl_max96712 9-0029: print_sensor_info: i2c bus 0
[   13.375837] sl_max96712 9-0029: print_sensor_info: following comes from port parsing
[   13.375838] sl_max96712 9-0029: print_sensor_info: detection id  0
[   13.375839] sl_max96712 9-0029: print_sensor_info: pipe 0 = 0
[   13.375840] sl_max96712 9-0029: print_sensor_info: pipe 1 = -1
[   13.375841] sl_max96712 9-0029: print_sensor_info: pipe 2 = -1
[   13.375842] sl_max96712 9-0029: print_sensor_info: pipe 3 = -1
[   13.390626] sl_max96712 9-0029: print_sensor_info: following comes from dts
[   13.390633] sl_max96712 9-0029: print_sensor_info: model id 0
[   13.390636] sl_max96712 9-0029: print_sensor_info: dts id 2
[   13.390638] sl_max96712 9-0029: print_sensor_info: n_lanes 2
[   13.390641] sl_max96712 9-0029: print_sensor_info: serial port 0
[   13.390643] sl_max96712 9-0029: print_sensor_info: vc-id 1
[   13.390645] sl_max96712 9-0029: print_sensor_info: i2c bus 0
[   13.390647] sl_max96712 9-0029: print_sensor_info: following comes from port parsing
[   13.390650] sl_max96712 9-0029: print_sensor_info: detection id  0
[   13.390652] sl_max96712 9-0029: print_sensor_info: pipe 0 = -1
[   13.390655] sl_max96712 9-0029: print_sensor_info: pipe 1 = -1
[   13.390657] sl_max96712 9-0029: print_sensor_info: pipe 2 = 1
[   13.390660] sl_max96712 9-0029: print_sensor_info: pipe 3 = -1
[   13.390663] sl_max96712 9-0029: sl_max96712_pipes_setup: camera pipeline operational
[   13.607245] sl_max96712 9-0029: sl_max96712_probe: success
[   13.643883] sl_max9295 9-0062: sl_max9295_probe: driver version v1.2.0
[   13.862625] sl_max9295 9-0044: sl_max9295_probe: driver version v1.2.0
[   13.903655] sl_max9295 9-0044: probe_serializer: Serializer for zedone4k detect error
[   13.903724] sl_max9295: probe of 9-0044 failed with error -1
[   13.903791] sl_max9295 9-0042: sl_max9295_probe: driver version v1.2.0
[   13.943319] sl_max9295 9-0042: probe_serializer: Serializer for zedonegs detect error
[   13.943402] sl_max9295: probe of 9-0042 failed with error -1
[   13.943490] sl_max9295 10-0062: sl_max9295_probe: driver version v1.2.0
[   13.983450] sl_max9295: probe of 10-0062 failed with error -1
[   13.983553] sl_max9295 10-0044: sl_max9295_probe: driver version v1.2.0
[   14.023032] sl_max9295 10-0044: probe_serializer: Serializer for zedone4k detect error
[   14.023103] sl_max9295: probe of 10-0044 failed with error -1
[   14.023174] sl_max9295 10-0042: sl_max9295_probe: driver version v1.2.0
[   14.059098] sl_max9295 10-0042: probe_serializer: Serializer for zedonegs detect error
[   14.059184] sl_max9295: probe of 10-0042 failed with error -1
############ DMESG [PCA] LOG #############
[    1.781354] pca954x 2-0070: registered 4 multiplexed busses for I2C switch pca9546
############ DTB list original  ###########
/boot/dtb/kernel_tegra234-p3768-0000+p3767-0000-nv.dtb
############ DTB list SLabs     ###########
board.py
extlinux.py
fio.py
Headers
Jetson
Linux
__pycache__
Utils
zlconfig
############ EXTlinux file      ###########
TIMEOUT 30
DEFAULT Stereolabs
MENU TITLE L4T boot options
LABEL primary
      MENU LABEL primary kernel
      LINUX /boot/Image
      INITRD /boot/initrd
      APPEND ${cbootargs} root=PARTUUID=8b5e394d-87dc-4637-a005-bcb3af3b88a9 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0
# When testing a custom kernel, it is recommended that you create a backup of
# the original kernel and add a new entry to this file so that the device can
# fallback to the original kernel. To do this:
# 1, Make a backup of the original kernel
#      sudo cp /boot/Image /boot/Image.backup
# 2, Copy your custom kernel into /boot/Image
# 3, Uncomment below menu setting lines for the original kernel
# 4, Reboot
# LABEL backup
#    MENU LABEL backup kernel
#    LINUX /boot/Image.backup
#    INITRD /boot/initrd
#    APPEND ${cbootargs}
LABEL Stereolabs
	MENU LABEL Stereolabs kernel
	LINUX /boot/Image
	FDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0000-nv.dtb
	INITRD /boot/initrd
	OVERLAYS /boot/tegra234-p3768-camera-zedbox-onx16-sl-overlay.dtbo
############ Jetpack      ###########
# R36 (release), REVISION: 3.0, GCID: 36923193, BOARD: generic, EABI: aarch64, DATE: Fri Jul 19 23:24:25 UTC 2024
# KERNEL_VARIANT: oot
############ Dpkg list      ###########
/usr/lib/modules/5.15.136-tegra/kernel/drivers/stereolabs/max96712/sl_max96712.ko==> exists
/usr/lib/modules/5.15.136-tegra/kernel/drivers/stereolabs/zedx/sl_zedx.ko ==> exists
/usr/lib/modules/5.15.136-tegra/kernel/drivers/stereolabs/zedone4k/sl_zedxone_uhd.ko ==> exists
     Active: active (running) since Wed 2024-11-27 08:13:29 CET; 27min ago
   Main PID: 1111 (ZEDX_Daemon)
      Tasks: 5 (limit: 18457)
     Memory: 10.1M
        CPU: 2.034s
             └─1111 /usr/sbin/ZEDX_Daemon
Nov 27 08:13:30 GTW-ONX2-ubuntu ZEDX_Daemon[1111]: [ "Wed Nov 27 08:13:30 2024" ]   Process  "rmmod sl_zedxone_uhd" outputs  "rmmod: ERROR: Module sl_zedxone_uhd is not currently loaded\n"
Nov 27 08:13:30 GTW-ONX2-ubuntu ZEDX_Daemon[1111]: [ "Wed Nov 27 08:13:30 2024" ]   Process  "rmmod sl_zedx" outputs  "rmmod: ERROR: Module sl_zedx is not currently loaded\n"
Nov 27 08:13:30 GTW-ONX2-ubuntu ZEDX_Daemon[1111]: [ "Wed Nov 27 08:13:30 2024" ]   Process  "rmmod sl_max9295" outputs  "rmmod: ERROR: Module sl_max9295 is not currently loaded\n"
Nov 27 08:13:30 GTW-ONX2-ubuntu ZEDX_Daemon[1111]: [ "Wed Nov 27 08:13:30 2024" ]   Process  "rmmod sl_max96712" outputs  "rmmod: ERROR: Module sl_max96712 is not currently loaded\n"
Nov 27 08:13:32 GTW-ONX2-ubuntu ZEDX_Daemon[1111]: ** ZED-X Driver loaded
Nov 27 08:13:32 GTW-ONX2-ubuntu ZEDX_Daemon[1111]: [ "Wed Nov 27 08:13:32 2024" ]  ** Searching for Postload file  "/etc/systemd/system/zed_x_daemon.postload"  :  false
Nov 27 08:13:32 GTW-ONX2-ubuntu ZEDX_Daemon[1111]: [ "Wed Nov 27 08:13:32 2024" ]  ** Created Endpoint  "tcp://127.0.0.1:20026"
Nov 27 08:15:27 GTW-ONX2-ubuntu ZEDX_Daemon[1111]: [ "Wed Nov 27 08:15:27 2024" ]  >> Port  0  Opening for ModeliD  8
Nov 27 08:15:29 GTW-ONX2-ubuntu ZEDX_Daemon[1111]: [ "Wed Nov 27 08:15:29 2024" ]  >> Port  0  Running for ModeliD  8
Nov 27 08:18:35 GTW-ONX2-ubuntu ZEDX_Daemon[1111]: [ "Wed Nov 27 08:18:35 2024" ]  >> Port  0  Closing for ModeliD  8
############ I2C Trace  [-l]       #############
i2c-0	i2c       	3160000.i2c                     	I2C adapter
i2c-1	i2c       	c240000.i2c                     	I2C adapter
i2c-2	i2c       	3180000.i2c                     	I2C adapter
i2c-4	i2c       	Tegra BPMP I2C adapter          	I2C adapter
i2c-5	i2c       	31b0000.i2c                     	I2C adapter
i2c-7	i2c       	c250000.i2c                     	I2C adapter
i2c-9	i2c       	i2c-2-mux (chan_id 0)           	I2C adapter
i2c-10	i2c       	i2c-2-mux (chan_id 1)           	I2C adapter
i2c-11	i2c       	i2c-2-mux (chan_id 2)           	I2C adapter
i2c-12	i2c       	i2c-2-mux (chan_id 3)           	I2C adapter
############ I2C Trace /dev/i2C-0 #############
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
############ I2C Trace /dev/i2C-1 #############
40: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
############ I2C Trace /dev/i2C-2 #############
20: UU -- -- -- -- -- -- -- UU UU -- -- -- -- -- --
60: -- -- UU -- -- -- -- -- -- -- -- -- -- -- -- --
70: UU -- -- -- -- -- -- --
############ I2C Trace /dev/i2C-3 #############
Error: Could not open file `/dev/i2c-3' or `/dev/i2c/3': No such file or directory
############ I2C Trace /dev/i2C-4 #############
30: -- -- -- -- -- -- -- -- -- -- -- -- UU -- -- --
############ I2C Trace /dev/i2C-5 #############
############ I2C Trace /dev/i2C-6 #############
Error: Could not open file `/dev/i2c-6' or `/dev/i2c/6': No such file or directory
############ I2C Trace /dev/i2C-7 #############
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
############ I2C Trace /dev/i2C-8 #############
Error: Could not open file `/dev/i2c-8' or `/dev/i2c/8': No such file or directory
############ I2C Trace /dev/i2C-9 #############
10: -- -- -- -- -- -- -- -- -- 19 -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- 49 -- -- -- -- -- --
50: -- -- -- -- 54 55 -- -- 58 59 -- -- -- -- -- --
60: -- -- UU -- -- -- -- -- -- 69 -- -- -- -- -- --
############ I2C Trace /dev/i2C-10 #############
20: -- -- -- -- -- -- -- -- -- 29 -- -- -- -- -- --
Error: Could not open file `/dev/i2c-30' or `/dev/i2c/30': No such file or directory
Error: Could not open file `/dev/i2c-31' or `/dev/i2c/31': No such file or directory
Error: Could not open file `/dev/i2c-32' or `/dev/i2c/32': No such file or directory
Error: Could not open file `/dev/i2c-33' or `/dev/i2c/33': No such file or directory
Hi @mbryla
What’s the length of the GMSL2 cables?
Hello @Myzhar,
I’m using SDK version: 4.1.2, camera is connected via a four way splitter and a 5 m cable - it’s the same as on the other set of the hardware that is working without issues.
Please update to:
I’ve just done it - the problem still happens, without any changes
Please run a new diagnostic test and send me the new diagnostic report
Current ZED_Diagnostic dmesg output:
Created: Fri Dec 6 2024
[   15.868766] sl_max96712 9-0029: sl_max96712_get_camera_model: zedx camera connected to this port
[   15.883560] sl_max96712 9-0029: print_sensor_info: camera zedx
[   15.898247] sl_max96712 9-0029: print_sensor_info: camera zedx
[   16.345936] sl_max9295 9-0062: probe_serializer: Serializer for zedx detect success
[   16.346257] sl_max9295 9-0044: sl_max9295_probe: zedx-uhd-id 0 found in dts
[   16.466647] sl_max9295 9-0060: probe_serializer: Serializer for zedxpro detect error
[   16.538312] sl_max9295 10-0062: probe_serializer: Serializer for zedx detect error
[   16.538432] sl_max9295 10-0044: sl_max9295_probe: zedx-uhd-id 1 found in dts
[   16.651028] sl_max9295 10-0060: probe_serializer: Serializer for zedxpro detect error
[   16.691759] zedxpro 9-004e: probing v4l2 sensor.
[   16.691892] zedxpro 9-004e: tegracam sensor driver:video12_v2.0.6
[   16.693631] zedxpro 9-004e: zedxpro_probe: Start streaming fail
[   16.693709] zedxpro 9-002e: probing v4l2 sensor.
[   16.693780] zedxpro 9-002e: tegracam sensor driver:video10_v2.0.6
[   16.695195] zedxpro 9-002e: zedxpro_probe: Start streaming fail
[   16.695242] zedxpro 9-003e: probing v4l2 sensor.
[   16.695333] zedxpro 9-003e: tegracam sensor driver:video8_v2.0.6
[   16.695992] zedxpro 9-003e: zedxpro_probe: Start streaming fail
[   16.696044] zedxpro 10-004e: probing v4l2 sensor.
[   16.696120] zedxpro 10-004e: tegracam sensor driver:video13_v2.0.6
[   16.697246] zedxpro 10-004e: zedxpro_probe: Start streaming fail
[   16.697301] zedxpro 10-002e: probing v4l2 sensor.
[   16.697360] zedxpro 10-002e: tegracam sensor driver:video11_v2.0.6
[   16.697773] zedxpro 10-002e: zedxpro_probe: Start streaming fail
[   16.697824] zedxpro 10-003e: probing v4l2 sensor.
[   16.697929] zedxpro 10-003e: tegracam sensor driver:video9_v2.0.6
[   16.698449] zedxpro 10-003e: zedxpro_probe: Start streaming fail
[   16.702156] zedx 9-0010: Driver Version : v1.2.1
[   16.702161] zedx 9-0010: Probing v4l2 sensor.
[   16.702290] zedx 9-0010: tegracam sensor driver:video4_v2.0.6
[   16.754617] zedx 9-0010: ZED-X detect error
[   16.754665] zedx 9-0010: zedx_probe: ar0234 initialization failed
[   16.754732] zedx: probe of 9-0010 failed with error -1
[   16.754835] zedx 9-0020: Driver Version : v1.2.1
[   16.754838] zedx 9-0020: Probing v4l2 sensor.
[   16.755003] zedx 9-0020: tegracam sensor driver:video2_v2.0.6
[   16.863827] Modules linked in: xt_addrtype iptable_filter nvidia_modeset(O) sl_zedx(OE+) sl_zedxpro(OE) sl_max9295(OE) algif_hash algif_skcipher af_alg sl_max96712(OE) snd_soc_tegra210_admaif(O) snd_soc_tegra_pcm snd_soc_tegra210_mixer(O) snd_soc_tegra210_afc(O) snd_soc_tegra186_asrc(O) snd_soc_tegra186_dspk(O) snd_soc_tegra210_dmic(O) snd_soc_tegra210_ope(O) snd_soc_tegra186_arad(O) snd_soc_tegra210_mvc(O) snd_soc_tegra210_amx(O) snd_soc_tegra210_adx(O) snd_soc_tegra210_sfc(O) snd_soc_tegra210_i2s(O) iwlmvm(E) mac80211 libarc4 snd_soc_tegra210_ahub(O) tegra210_adma spidev nvvrs_pseq_rtc(O) cdc_acm ftdi_sio usbserial btusb btrtl btintel btbcm bluetooth ecdh_generic ecc fusb301(O) lzo_rle snd_soc_tegra_machine_driver(O) lzo_compress snd_soc_tegra_utils(O) crct10dif_ce snd_soc_simple_card_utils tegra234_oc_event(O) nvpmodel_clk_cap(O) cam_cdi_tsc(O) nv_hawk_owl(O) max96712(O) thermal_trip_event(O) tegra_cactmon_mc_all(O) mttcan(O) nvpps(O) can_dev zram zsmalloc tegra_aconnect bmi088(O)
[   16.864022]  zedx_fill_eeprom+0xa0/0x170 [sl_zedx]
[   16.864063]  zedx_probe+0x610/0x908 [sl_zedx]
[   16.864105]  zedx_i2c_driver_init+0x30/0x1000 [sl_zedx]
[   17.472427] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 9-0020 bound
[   17.475173] zedx 9-0020: Detected ZED-X sensor
[   17.475180] zedx 9-0020: zedx_probe: Serial Number : 44183026
[   17.475353] zedx 9-0028: Driver Version : v1.2.1
[   17.475356] zedx 9-0028: Probing v4l2 sensor.
[   17.475488] zedx 9-0028: tegracam sensor driver:video0_v2.0.6
[   17.483229] zedx 9-0020: zedx_open: Accessing the camera
[   17.566013] i2c i2c-9: Failed to register i2c client eeprom_zedx at 0x54 (-16)
[   17.566026] zedx 9-0028: zedx_eeprom_device_init: Failed to probe EEPORM at addr = 0x54
[   17.566030] zedx 9-0028: Failed to allocate eeprom reg map: -19
[   17.566281] zedx 9-0028: zedx_probe_ar0234: use serial number of the first sensor
[   17.573370] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 9-0028 bound
[   17.574008] zedx 9-0028: Detected ZED-X sensor
[   17.574013] zedx 9-0028: zedx_probe: Serial Number : 44183026
[   17.574342] zedx 10-0010: Driver Version : v1.2.1
[   17.574345] zedx 10-0010: Probing v4l2 sensor.
[   17.574496] zedx 10-0010: tegracam sensor driver:video5_v2.0.6
[   17.578147] zedx 9-0028: zedx_open: Accessing the camera
[   17.627007] zedx 10-0010: ZED-X detect error
[   17.627055] zedx 10-0010: zedx_probe: ar0234 initialization failed
[   17.627122] zedx: probe of 10-0010 failed with error -1
[   17.627202] zedx 10-0020: Driver Version : v1.2.1
[   17.627206] zedx 10-0020: Probing v4l2 sensor.
[   17.627408] zedx 10-0020: tegracam sensor driver:video3_v2.0.6
[   17.678925] zedx 10-0020: ZED-X detect error
[   17.678970] zedx 10-0020: zedx_probe: ar0234 initialization failed
[   17.679028] zedx: probe of 10-0020 failed with error -1
[   17.679116] zedx 10-0028: Driver Version : v1.2.1
[   17.679118] zedx 10-0028: Probing v4l2 sensor.
[   17.679240] zedx 10-0028: tegracam sensor driver:video1_v2.0.6
[   17.726870] zedx 10-0028: ZED-X detect error
[   17.726914] zedx 10-0028: zedx_probe: ar0234 initialization failed
[   17.726978] zedx: probe of 10-0028 failed with error -1
[   17.731853] zedxone_uhd 9-001a: tegracam sensor driver:video6_v2.0.6
[   17.731877] i2c i2c-9: Failed to register i2c client eeprom_zedxone_uhd at 0x54 (-16)
[   17.731881] zedxone_uhd 9-001a: Failed to allocate eeprom reg map: -19
[   17.732072] zedxone_uhd 9-001a: imx678_probe: You need an EEPROM for your first device entry
[   17.732073] zedxone_uhd 9-001a: imx678_probe: This might also happen because a ZED X was probbed first for this i2c bus
[   17.733586] zedxone_uhd 9-001a: imx678_probe: ZED-X One UHD detect error
[   17.733624] zedxone_uhd: probe of 9-001a failed with error -1
[   17.733828] zedxone_uhd 10-001a: tegracam sensor driver:video7_v2.0.6
[   17.735009] zedxone_uhd 10-001a: imx678_probe: ZED One UHD detection error
[   17.735040] zedxone_uhd: probe of 10-001a failed with error -1
[   21.254364] zedx 9-0020: zedx_open: Accessing the camera
[   21.254453] zedx 9-0028: zedx_open: Accessing the camera
[   15.115517] sl_max96712 9-0029: sl_max96712_probe: enter
[   15.115590] sl_max96712 9-0029: sl_max96712_parse_dt: Using CSI port b
[   15.115593] sl_max96712 9-0029: sl_max96712_parse_dt: Number of declared cameras with this dts 10
[   15.342337] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: No camera connected to GMSL port 0
[   15.450545] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: No camera connected to GMSL port 1
[   15.558430] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: No camera connected to GMSL port 2
[   15.670487] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: Camera connected to GMSL port 3
[   15.883556] sl_max96712 9-0029: print_sensor_info: following comes from dts
[   15.883562] sl_max96712 9-0029: print_sensor_info: model id 0
[   15.883564] sl_max96712 9-0029: print_sensor_info: dts id 4
[   15.883565] sl_max96712 9-0029: print_sensor_info: n_lanes 2
[   15.883566] sl_max96712 9-0029: print_sensor_info: serial port 0
[   15.883567] sl_max96712 9-0029: print_sensor_info: vc-id 0
[   15.883568] sl_max96712 9-0029: print_sensor_info: i2c bus 0
[   15.883569] sl_max96712 9-0029: print_sensor_info: following comes from port parsing
[   15.883570] sl_max96712 9-0029: print_sensor_info: detection id  0
[   15.883571] sl_max96712 9-0029: print_sensor_info: pipe 0 = 0
[   15.883572] sl_max96712 9-0029: print_sensor_info: pipe 1 = -1
[   15.883573] sl_max96712 9-0029: print_sensor_info: pipe 2 = -1
[   15.883574] sl_max96712 9-0029: print_sensor_info: pipe 3 = -1
[   15.898242] sl_max96712 9-0029: print_sensor_info: following comes from dts
[   15.898249] sl_max96712 9-0029: print_sensor_info: model id 0
[   15.898252] sl_max96712 9-0029: print_sensor_info: dts id 4
[   15.898255] sl_max96712 9-0029: print_sensor_info: n_lanes 2
[   15.898257] sl_max96712 9-0029: print_sensor_info: serial port 0
[   15.898260] sl_max96712 9-0029: print_sensor_info: vc-id 1
[   15.898262] sl_max96712 9-0029: print_sensor_info: i2c bus 0
[   15.898264] sl_max96712 9-0029: print_sensor_info: following comes from port parsing
[   15.898266] sl_max96712 9-0029: print_sensor_info: detection id  0
[   15.898269] sl_max96712 9-0029: print_sensor_info: pipe 0 = -1
[   15.898271] sl_max96712 9-0029: print_sensor_info: pipe 1 = -1
[   15.898274] sl_max96712 9-0029: print_sensor_info: pipe 2 = 1
[   15.898276] sl_max96712 9-0029: print_sensor_info: pipe 3 = -1
[   15.898279] sl_max96712 9-0029: sl_max96712_pipes_setup: camera pipeline operational
[   16.114366] sl_max96712 9-0029: sl_max96712_probe: success
[   16.127654] sl_max9295 9-0062: sl_max9295_probe: driver version v1.2.1
[   16.346155] sl_max9295 9-0044: sl_max9295_probe: driver version v1.2.1
[   16.386622] sl_max9295 9-0044: probe_serializer: Serializer for zedone4k detect error
[   16.386705] sl_max9295: probe of 9-0044 failed with error -1
[   16.386787] sl_max9295 9-0042: sl_max9295_probe: driver version v1.2.1
[   16.426688] sl_max9295 9-0042: probe_serializer: Serializer for zedonegs detect error
[   16.426765] sl_max9295: probe of 9-0042 failed with error -1
[   16.426832] sl_max9295 9-0060: sl_max9295_probe: driver version v1.2.1
[   16.466736] sl_max9295: probe of 9-0060 failed with error -1
[   16.466885] sl_max9295 9-0040: sl_max9295_probe: driver version v1.2.1
[   16.502714] sl_max9295 9-0040: probe_serializer: Serializer for zedonepro detect error
[   16.502784] sl_max9295: probe of 9-0040 failed with error -1
[   16.502860] sl_max9295 10-0062: sl_max9295_probe: driver version v1.2.1
[   16.538359] sl_max9295: probe of 10-0062 failed with error -1
[   16.538399] sl_max9295 10-0044: sl_max9295_probe: driver version v1.2.1
[   16.578368] sl_max9295 10-0044: probe_serializer: Serializer for zedone4k detect error
[   16.578442] sl_max9295: probe of 10-0044 failed with error -1
[   16.578543] sl_max9295 10-0042: sl_max9295_probe: driver version v1.2.1
[   16.614401] sl_max9295 10-0042: probe_serializer: Serializer for zedonegs detect error
[   16.614470] sl_max9295: probe of 10-0042 failed with error -1
[   16.614541] sl_max9295 10-0060: sl_max9295_probe: driver version v1.2.1
[   16.651097] sl_max9295: probe of 10-0060 failed with error -1
[   16.651171] sl_max9295 10-0040: sl_max9295_probe: driver version v1.2.1
[   16.686418] sl_max9295 10-0040: probe_serializer: Serializer for zedonepro detect error
[   16.686501] sl_max9295: probe of 10-0040 failed with error -1
[    3.861253] pca954x 2-0070: registered 4 multiplexed busses for I2C switch pca9546
board.py
extlinux.py
fio.py
Headers
Jetson
Linux
__pycache__
Utils
zlconfig
TIMEOUT 30
DEFAULT Stereolabs
LABEL primary
      LINUX /boot/Image
      INITRD /boot/initrd
# 4, Reboot
# LABEL backup
LABEL Stereolabs
	LINUX /boot/Image
	INITRD /boot/initrd
     Active: active (running) since Thu 2024-09-26 16:29:51 CEST; 2 months 9 days ago
   Main PID: 901 (ZEDX_Daemon)
     Memory: 6.3M
        CPU: 1.122s
             └─901 /usr/sbin/ZEDX_Daemon
Dec 06 09:40:02 GTW-ONX2-ubuntu ZEDX_Daemon[901]: [ "Fri Dec 6 09:40:02 2024" ][ZED-X Daemon] Process  "rmmod sl_zedxpro" outputs  "rmmod: ERROR: Module sl_zedxpro is not currently loaded\n"
Dec 06 09:40:02 GTW-ONX2-ubuntu ZEDX_Daemon[901]: [ "Fri Dec 6 09:40:02 2024" ][ZED-X Daemon] Process  "rmmod sl_max9295" outputs  "rmmod: ERROR: Module sl_max9295 is not currently loaded\n"
Dec 06 09:40:02 GTW-ONX2-ubuntu ZEDX_Daemon[901]: [ "Fri Dec 6 09:40:02 2024" ][ZED-X Daemon] Process  "rmmod sl_max96712" outputs  "rmmod: ERROR: Module sl_max96712 is not currently loaded\n"
Dec 06 09:40:02 GTW-ONX2-ubuntu ZEDX_Daemon[901]: [ "Fri Dec 6 09:40:02 2024" ][ZED-X Daemon] ZED-X Driver removed
Dec 06 09:40:04 GTW-ONX2-ubuntu ZEDX_Daemon[901]: [ "Fri Dec 6 09:40:04 2024" ][ZED-X Daemon] ZED-X Driver loaded
Dec 06 09:40:04 GTW-ONX2-ubuntu ZEDX_Daemon[901]: [ "Fri Dec 6 09:40:04 2024" ][ZED-X Daemon] Using TCP port (Read/Write):  20026  and  20027
Dec 06 09:40:04 GTW-ONX2-ubuntu ZEDX_Daemon[901]: [ "Fri Dec 6 09:40:04 2024" ][ZED-X Daemon] Searching for Postload file  "/etc/systemd/system/zed_x_daemon.postload" , Found=   false
Dec 06 09:40:04 GTW-ONX2-ubuntu ZEDX_Daemon[901]: [ "Fri Dec 6 09:40:04 2024" ][ZED-X Daemon] Restarting NVArgus
Dec 06 09:40:05 GTW-ONX2-ubuntu ZEDX_Daemon[901]: [ "Fri Dec 6 09:40:05 2024" ]  ** Created Sub Endpoint  "tcp://127.0.0.1:20026"
Dec 06 09:40:05 GTW-ONX2-ubuntu ZEDX_Daemon[901]: [ "Fri Dec 6 09:40:05 2024" ]  ** Created Pub Endpoint  "tcp://127.0.0.1:20027"
>> No bus available at index 3
>> No bus available at index 6
>> No bus available at index 8
############ I2C Trace /dev/i2C-11 #############
############ I2C Trace /dev/i2C-12 #############
>> No bus available at index 13
>> No bus available at index 14
>> No bus available at index 15
>> No bus available at index 16
>> No bus available at index 30
>> No bus available at index 31
>> No bus available at index 32
>> No bus available at index 33
>> No bus available at index 34
>> No bus available at index 35
>> No bus available at index 36
>> No bus available at index 37
>> No bus available at index 38
>> No bus available at index 39
>> No bus available at index 40
Hi @mbryla
the log does not show any problem.
Can you please post the full log of the ZED ROS2 Wrapperwhile running?
What is the precise FULL error message that you get?
Hello @Myzhar,
I’ve just build the newest version of the ROS2 wrapper and tried to launch it - two times in the row, as it’s behavior changes:
user@vand_mgv:~$ source ros2_ws/install/setup.bash
user@vand_mgv:~$ ros2 launch zed_wrapper zed_camera.launch.py camera_model:=zedx
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2024-12-09-14-10-44-233163-GTW-ONX2-ubuntu-3903
Using common configuration file: /home/user/ros2_ws/install/zed_wrapper/share/zed_wrapper/config/common_stereo.yaml
[INFO] [robot_state_publisher-1]: process started with pid [3916]
[INFO] [component_container_isolated-2]: process started with pid [3918]
[robot_state_publisher-1] [INFO] [1733749844.771054496] [zed.zed_state_publisher]: got segment zed_camera_center
[robot_state_publisher-1] [INFO] [1733749844.771245984] [zed.zed_state_publisher]: got segment zed_camera_link
[robot_state_publisher-1] [INFO] [1733749844.771263040] [zed.zed_state_publisher]: got segment zed_left_camera_frame
[robot_state_publisher-1] [INFO] [1733749844.771272672] [zed.zed_state_publisher]: got segment zed_left_camera_optical_frame
[robot_state_publisher-1] [INFO] [1733749844.771280064] [zed.zed_state_publisher]: got segment zed_right_camera_frame
[robot_state_publisher-1] [INFO] [1733749844.771286816] [zed.zed_state_publisher]: got segment zed_right_camera_optical_frame
[component_container_isolated-2] [INFO] [1733749845.000408800] [zed.zed_container]: Load Library: /home/user/ros2_ws/install/zed_components/lib/libzed_camera_component.so
[component_container_isolated-2] [INFO] [1733749845.115871200] [zed.zed_container]: Found class: rclcpp_components::NodeFactoryTemplate<stereolabs::ZedCamera>
[component_container_isolated-2] [INFO] [1733749845.116030752] [zed.zed_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<stereolabs::ZedCamera>
[component_container_isolated-2] [INFO] [1733749845.285900256] [zed.zed_node]: ********************************
[component_container_isolated-2] [INFO] [1733749845.285991968] [zed.zed_node]:       ZED Camera Component
[component_container_isolated-2] [INFO] [1733749845.286003904] [zed.zed_node]: ********************************
[component_container_isolated-2] [INFO] [1733749845.286014208] [zed.zed_node]:  * namespace: /zed
[component_container_isolated-2] [INFO] [1733749845.286023904] [zed.zed_node]:  * node name: zed_node
[component_container_isolated-2] [INFO] [1733749845.286030720] [zed.zed_node]: ********************************
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/zed/zed_node' in container '/zed/zed_container'
[component_container_isolated-2] [INFO] [1733749845.337150560] [zed.zed_node]: *** DEBUG parameters ***
[component_container_isolated-2] [INFO] [1733749845.337679680] [zed.zed_node]:  * SDK Verbose: 1
[component_container_isolated-2] [INFO] [1733749845.337892992] [zed.zed_node]:  * Debug Common: FALSE
[component_container_isolated-2] [INFO] [1733749845.338015008] [zed.zed_node]:  * Debug Simulation: FALSE
[component_container_isolated-2] [INFO] [1733749845.338114496] [zed.zed_node]:  * Debug Video/Depth: FALSE
[component_container_isolated-2] [INFO] [1733749845.338267744] [zed.zed_node]:  * Debug Control settings: FALSE
[component_container_isolated-2] [INFO] [1733749845.338378080] [zed.zed_node]:  * Debug Point Cloud: FALSE
[component_container_isolated-2] [INFO] [1733749845.338481536] [zed.zed_node]:  * Debug GNSS: FALSE
[component_container_isolated-2] [INFO] [1733749845.338574304] [zed.zed_node]:  * Debug Positional Tracking: FALSE
[component_container_isolated-2] [INFO] [1733749845.338675488] [zed.zed_node]:  * Debug sensors: FALSE
[component_container_isolated-2] [INFO] [1733749845.338766048] [zed.zed_node]:  * Debug Mapping: FALSE
[component_container_isolated-2] [INFO] [1733749845.338872832] [zed.zed_node]:  * Debug Object Detection: FALSE
[component_container_isolated-2] [INFO] [1733749845.338976416] [zed.zed_node]:  * Debug Body Tracking: FALSE
[component_container_isolated-2] [INFO] [1733749845.339068352] [zed.zed_node]:  * Debug Streaming: FALSE
[component_container_isolated-2] [INFO] [1733749845.339156864] [zed.zed_node]:  * Debug ROI: FALSE
[component_container_isolated-2] [INFO] [1733749845.339252288] [zed.zed_node]:  * Debug Advanced: FALSE
[component_container_isolated-2] [INFO] [1733749845.339428000] [zed.zed_node]: *** GENERAL parameters ***
[component_container_isolated-2] [INFO] [1733749845.339867872] [zed.zed_node]:  * Camera model: zedx - ZED X
[component_container_isolated-2] [INFO] [1733749845.340029504] [zed.zed_node]:  * Camera name: zed
[component_container_isolated-2] [INFO] [1733749845.340155200] [zed.zed_node]:  * Camera SN: 0
[component_container_isolated-2] [INFO] [1733749845.340268288] [zed.zed_node]:  * Camera timeout [sec]: 5
[component_container_isolated-2] [INFO] [1733749845.340369760] [zed.zed_node]:  * Camera reconnection temptatives: 5
[component_container_isolated-2] [INFO] [1733749845.340495360] [zed.zed_node]:  * Camera framerate: 30
[component_container_isolated-2] [INFO] [1733749845.340610752] [zed.zed_node]:  * GPU ID: -1
[component_container_isolated-2] [INFO] [1733749845.341219808] [zed.zed_node]:  * Camera resolution: HD1080
[component_container_isolated-2] [INFO] [1733749845.341406016] [zed.zed_node]:  * Publishing resolution: NATIVE
[component_container_isolated-2] [INFO] [1733749845.341545472] [zed.zed_node]:  * OpenCV custom calibration:
[component_container_isolated-2] [INFO] [1733749845.341664704] [zed.zed_node]:  * Camera self calibration: TRUE
[component_container_isolated-2] [INFO] [1733749845.341779520] [zed.zed_node]:  * Camera flip: FALSE
[component_container_isolated-2] [INFO] [1733749845.341940288] [zed.zed_node]:  * [DYN] Publish framerate [Hz]:  15
[component_container_isolated-2] [INFO] [1733749845.341982080] [zed.zed_node]: *** VIDEO parameters ***
[component_container_isolated-2] [INFO] [1733749845.342097440] [zed.zed_node]:  * [DYN] Saturation: 4
[component_container_isolated-2] [INFO] [1733749845.342223200] [zed.zed_node]:  * [DYN] Sharpness: 4
[component_container_isolated-2] [INFO] [1733749845.342337152] [zed.zed_node]:  * [DYN] Gamma: 8
[component_container_isolated-2] [INFO] [1733749845.342448736] [zed.zed_node]:  * [DYN] Auto Exposure/Gain: TRUE
[component_container_isolated-2] [INFO] [1733749845.342556800] [zed.zed_node]:  * [DYN] Exposure: 80
[component_container_isolated-2] [INFO] [1733749845.342667904] [zed.zed_node]:  * [DYN] Gain: 80
[component_container_isolated-2] [INFO] [1733749845.342772384] [zed.zed_node]:  * [DYN] Auto White Balance: TRUE
[component_container_isolated-2] [INFO] [1733749845.342873824] [zed.zed_node]:  * [DYN] White Balance Temperature: 42
[component_container_isolated-2] [INFO] [1733749845.343050528] [zed.zed_node]:  * [DYN] ZED X Exposure time: 16000
[component_container_isolated-2] [INFO] [1733749845.343159360] [zed.zed_node]:  * [DYN] ZED X Auto Exp. time range min: 28
[component_container_isolated-2] [INFO] [1733749845.343290688] [zed.zed_node]:  * [DYN] ZED X Auto Exp. time range max: 30000
[component_container_isolated-2] [INFO] [1733749845.343401344] [zed.zed_node]:  * [DYN] ZED X Exposure comp.: 50
[component_container_isolated-2] [INFO] [1733749845.343509600] [zed.zed_node]:  * [DYN] ZED X Analog Gain: 1255
[component_container_isolated-2] [INFO] [1733749845.343623584] [zed.zed_node]:  * [DYN] ZED X Auto Analog Gain range min: 1000
[component_container_isolated-2] [INFO] [1733749845.343883040] [zed.zed_node]:  * [DYN] ZED X Auto Analog Gain range max: 16000
[component_container_isolated-2] [INFO] [1733749845.344008832] [zed.zed_node]:  * [DYN] ZED X Digital Gain: 1
[component_container_isolated-2] [INFO] [1733749845.344121568] [zed.zed_node]:  * [DYN] ZED X Auto Digital Gain range min: 1
[component_container_isolated-2] [INFO] [1733749845.344232896] [zed.zed_node]:  * [DYN] ZED X Auto Digital Gain range max: 256
[component_container_isolated-2] [INFO] [1733749845.344303872] [zed.zed_node]:  * [DYN] ZED X Auto Digital Gain range max: 50
[component_container_isolated-2] [INFO] [1733749845.344328160] [zed.zed_node]: *** DEPTH parameters ***
[component_container_isolated-2] [INFO] [1733749845.344472576] [zed.zed_node]:  * Depth mode: NEURAL [4]
[component_container_isolated-2] [INFO] [1733749845.344561760] [zed.zed_node]:  * Min depth [m]: 0.3
[component_container_isolated-2] [INFO] [1733749845.344642624] [zed.zed_node]:  * Max depth [m]: 10
[component_container_isolated-2] [INFO] [1733749845.344712256] [zed.zed_node]:  * Depth Stabilization: 1
[component_container_isolated-2] [INFO] [1733749845.344760768] [zed.zed_node]:  * OpenNI mode (16bit point cloud): FALSE
[component_container_isolated-2] [INFO] [1733749845.344837312] [zed.zed_node]:  * [DYN] Point cloud rate [Hz]: 5
[component_container_isolated-2] [INFO] [1733749845.344888576] [zed.zed_node]:  * [DYN] Depth Confidence: 50
[component_container_isolated-2] [INFO] [1733749845.344942496] [zed.zed_node]:  * [DYN] Depth Texture Confidence: 100
[component_container_isolated-2] [INFO] [1733749845.344994944] [zed.zed_node]:  * [DYN] Remove saturated areas: TRUE
[component_container_isolated-2] [INFO] [1733749845.345015200] [zed.zed_node]: *** GNSS FUSION parameters ***
[component_container_isolated-2] [INFO] [1733749845.345086944] [zed.zed_node]:  * GNSS fusion enabled: FALSE
[component_container_isolated-2] [INFO] [1733749845.345107840] [zed.zed_node]: *** POSITIONAL TRACKING parameters ***
[component_container_isolated-2] [INFO] [1733749845.345161280] [zed.zed_node]:  * Positional tracking enabled: TRUE
[component_container_isolated-2] [INFO] [1733749845.345225984] [zed.zed_node]:  * Positional tracking mode: GEN 2
[component_container_isolated-2] [INFO] [1733749845.345289760] [zed.zed_node]:  * Map frame id: map
[component_container_isolated-2] [INFO] [1733749845.345335232] [zed.zed_node]:  * Odometry frame id: odom
[component_container_isolated-2] [INFO] [1733749845.345387648] [zed.zed_node]:  * Broadcast Odometry TF: TRUE
[component_container_isolated-2] [INFO] [1733749845.345436256] [zed.zed_node]:  * Broadcast Pose TF: TRUE
[component_container_isolated-2] [INFO] [1733749845.345510016] [zed.zed_node]:  * [DYN] Depth minimum range: 0
[component_container_isolated-2] [INFO] [1733749845.345571616] [zed.zed_node]:  * [DYN] TF timestamp offset: 0
[component_container_isolated-2] [INFO] [1733749845.345622528] [zed.zed_node]:  * [DYN] Path publishing rate: 2
[component_container_isolated-2] [INFO] [1733749845.345670720] [zed.zed_node]:  * Path history lenght: -1
[component_container_isolated-2] [INFO] [1733749845.345759872] [zed.zed_node]:  * Initial pose: [0,0,0,0,0,0,]
[component_container_isolated-2] [INFO] [1733749845.345825312] [zed.zed_node]:  * Area Memory: TRUE
[component_container_isolated-2] [INFO] [1733749845.345909408] [zed.zed_node]:  * Area Memory DB:
[component_container_isolated-2] [INFO] [1733749845.345991296] [zed.zed_node]:  * Camera is static: FALSE
[component_container_isolated-2] [INFO] [1733749845.346079616] [zed.zed_node]:  * Gravity as origin [not for ZED]: TRUE
[component_container_isolated-2] [INFO] [1733749845.346158976] [zed.zed_node]:  * IMU Fusion [not for ZED]: TRUE
[component_container_isolated-2] [INFO] [1733749845.346207200] [zed.zed_node]:  * Floor Alignment: FALSE
[component_container_isolated-2] [INFO] [1733749845.346319520] [zed.zed_node]:  * Reset Odometry with Loop Closure: TRUE
[component_container_isolated-2] [INFO] [1733749845.346464192] [zed.zed_node]:  * 2D mode: FALSE
[component_container_isolated-2] [INFO] [1733749845.346510624] [zed.zed_node]: *** Region of Interest parameters ***
[component_container_isolated-2] [INFO] [1733749845.346635488] [zed.zed_node]:  * Automatic ROI generation: FALSE
[component_container_isolated-2] [INFO] [1733749845.346828864] [zed.zed_node]:  * Manual ROI polygon: []
[component_container_isolated-2] [INFO] [1733749845.346870176] [zed.zed_node]: *** SENSORS STACK parameters ***
[component_container_isolated-2] [INFO] [1733749845.347012160] [zed.zed_node]:  * Broadcast IMU TF [not for ZED]: TRUE
[component_container_isolated-2] [INFO] [1733749845.347115840] [zed.zed_node]:  * Sensors Camera Sync: FALSE
[component_container_isolated-2] [INFO] [1733749845.347230048] [zed.zed_node]:  * Sensors publishing rate: 200 Hz
[component_container_isolated-2] [INFO] [1733749845.347292992] [zed.zed_node]: *** Spatial Mapping parameters ***
[component_container_isolated-2] [INFO] [1733749845.347413024] [zed.zed_node]:  * Spatial Mapping Enabled: FALSE
[component_container_isolated-2] [INFO] [1733749845.347568064] [zed.zed_node]:  * Spatial Mapping resolution [m]: 0.05
[component_container_isolated-2] [INFO] [1733749845.347724000] [zed.zed_node]:  * 3D Max Mapping range [m]: 5
[component_container_isolated-2] [INFO] [1733749845.347864224] [zed.zed_node]:  * Map publishing rate [Hz]: 1
[component_container_isolated-2] [INFO] [1733749845.347978432] [zed.zed_node]:  * Clicked point topic: /clicked_point
[component_container_isolated-2] [INFO] [1733749845.348111200] [zed.zed_node]:  * Plane Det. Max Dist. Thresh.: 0.15
[component_container_isolated-2] [INFO] [1733749845.348361088] [zed.zed_node]:  * Plane Det. Normals Sim. Thresh.: 15
[component_container_isolated-2] [INFO] [1733749845.348416032] [zed.zed_node]: *** Object Det. parameters ***
[component_container_isolated-2] [INFO] [1733749845.348537984] [zed.zed_node]:  * Object Det. enabled: FALSE
[component_container_isolated-2] [INFO] [1733749845.348724000] [zed.zed_node]:  * Object Det. model: MULTI CLASS BOX FAST
[component_container_isolated-2] [INFO] [1733749845.348877920] [zed.zed_node]:  * Object Det. allow reduced precision: TRUE
[component_container_isolated-2] [INFO] [1733749845.349007488] [zed.zed_node]:  * Object Det. maximum range [m]: 20
[component_container_isolated-2] [INFO] [1733749845.349131456] [zed.zed_node]:  * Object Det. min. confidence: 75
[component_container_isolated-2] [INFO] [1733749845.349280192] [zed.zed_node]:  * Object Det. prediction timeout [sec]: 0.5
[component_container_isolated-2] [INFO] [1733749845.349411456] [zed.zed_node]:  * Object Det. tracking: TRUE
[component_container_isolated-2] [INFO] [1733749845.349584928] [zed.zed_node]:  * Object Filtering mode: 1 - NMS3D
[component_container_isolated-2] [INFO] [1733749845.349782048] [zed.zed_node]:  * MultiClassBox people: TRUE
[component_container_isolated-2] [INFO] [1733749845.349928640] [zed.zed_node]:  * MultiClassBox vehicles: TRUE
[component_container_isolated-2] [INFO] [1733749845.350091200] [zed.zed_node]:  * MultiClassBox bags: TRUE
[component_container_isolated-2] [INFO] [1733749845.350236032] [zed.zed_node]:  * MultiClassBox animals: TRUE
[component_container_isolated-2] [INFO] [1733749845.350356672] [zed.zed_node]:  * MultiClassBox electronics: TRUE
[component_container_isolated-2] [INFO] [1733749845.350481056] [zed.zed_node]:  * MultiClassBox fruits and vegetables: TRUE
[component_container_isolated-2] [INFO] [1733749845.350718496] [zed.zed_node]:  * MultiClassBox sport-related objects: TRUE
[component_container_isolated-2] [INFO] [1733749845.350754112] [zed.zed_node]: *** Body Track. parameters ***
[component_container_isolated-2] [INFO] [1733749845.350851328] [zed.zed_node]:  * Body Track. enabled: FALSE
[component_container_isolated-2] [INFO] [1733749845.350983744] [zed.zed_node]:  * Body Track. model: HUMAN BODY MEDIUM
[component_container_isolated-2] [INFO] [1733749845.351083616] [zed.zed_node]:  * Body Track. format: BODY 38
[component_container_isolated-2] [INFO] [1733749845.351181248] [zed.zed_node]:  * Body Track. allow reduced precision: TRUE
[component_container_isolated-2] [INFO] [1733749845.351247136] [zed.zed_node]:  * Body Track. maximum range [m]: 20
[component_container_isolated-2] [INFO] [1733749845.351298176] [zed.zed_node]:  * Body Track. KP selection: FULL
[component_container_isolated-2] [INFO] [1733749845.351360800] [zed.zed_node]:  * Body fitting: FALSE
[component_container_isolated-2] [INFO] [1733749845.351410304] [zed.zed_node]:  * Body joints tracking: TRUE
[component_container_isolated-2] [INFO] [1733749845.351461888] [zed.zed_node]:  * Body Track. prediction timeout [sec]: 0.5
[component_container_isolated-2] [INFO] [1733749845.351510304] [zed.zed_node]:  * Body Track. confidence thresh.: 50
[component_container_isolated-2] [INFO] [1733749845.351560224] [zed.zed_node]:  * Body Track. min. KP thresh.: 5
[component_container_isolated-2] [INFO] [1733749845.351582752] [zed.zed_node]: *** Streaming Server parameters ***
[component_container_isolated-2] [INFO] [1733749845.351648608] [zed.zed_node]:  * Streaming Server enabled: FALSE
[component_container_isolated-2] [INFO] [1733749845.351702784] [zed.zed_node]:  * Stream codec: H264
[component_container_isolated-2] [INFO] [1733749845.351754752] [zed.zed_node]:  * Stream port:30000
[component_container_isolated-2] [INFO] [1733749845.351806656] [zed.zed_node]:  * Stream bitrate: 12500
[component_container_isolated-2] [INFO] [1733749845.351864864] [zed.zed_node]:  * Stream GOP size: -1
[component_container_isolated-2] [INFO] [1733749845.351931776] [zed.zed_node]:  * Stream Chunk size: 16084
[component_container_isolated-2] [INFO] [1733749845.352024000] [zed.zed_node]:  * Adaptive bitrate: FALSE
[component_container_isolated-2] [INFO] [1733749845.352089216] [zed.zed_node]:  * Target frame rate:0
[component_container_isolated-2] [INFO] [1733749845.352111200] [zed.zed_node]: *** Advanced parameters ***
[component_container_isolated-2] [INFO] [1733749845.352169856] [zed.zed_node]:  * Thread sched. policy: SCHED_BATCH
[component_container_isolated-2] [INFO] [1733749845.352570304] [zed.zed_node]: *** SERVICES ***
[component_container_isolated-2] [INFO] [1733749845.356457120] [zed.zed_node]:  * '/zed/zed_node/reset_odometry'
[component_container_isolated-2] [INFO] [1733749845.357930176] [zed.zed_node]:  * '/zed/zed_node/reset_pos_tracking'
[component_container_isolated-2] [INFO] [1733749845.363118816] [zed.zed_node]:  * '/zed/zed_node/set_pose'
[component_container_isolated-2] [INFO] [1733749845.364062144] [zed.zed_node]:  * '/zed/zed_node/enable_obj_det'
[component_container_isolated-2] [INFO] [1733749845.365189600] [zed.zed_node]:  * '/zed/zed_node/enable_body_trk'
[component_container_isolated-2] [INFO] [1733749845.365954432] [zed.zed_node]:  * '/zed/zed_node/enable_mapping'
[component_container_isolated-2] [INFO] [1733749845.366630272] [zed.zed_node]:  * '/zed/zed_node/enable_streaming'
[component_container_isolated-2] [INFO] [1733749845.367844736] [zed.zed_node]:  * '/zed/zed_node/start_svo_rec'
[component_container_isolated-2] [INFO] [1733749845.368565120] [zed.zed_node]:  * '/zed/zed_node/stop_svo_rec'
[component_container_isolated-2] [INFO] [1733749845.370103712] [zed.zed_node]:  * '/zed/zed_node/set_roi'
[component_container_isolated-2] [INFO] [1733749845.371012224] [zed.zed_node]:  * '/zed/zed_node/reset_roi'
[component_container_isolated-2] [INFO] [1733749845.371803040] [zed.zed_node]: ***** STARTING CAMERA *****
[component_container_isolated-2] [INFO] [1733749845.505020352] [zed.zed_node]: ZED SDK Version: 4.2.2 - Build 95990_fb77e75e
[component_container_isolated-2] [2024-12-09 13:10:45 UTC][ZED][INFO] Logging level INFO
[component_container_isolated-2] [INFO] [1733749845.513149472] [zed.zed_node]: *** CAMERA OPENING ***
[component_container_isolated-2] [INFO] [1733749845.513229152] [zed.zed_node]: Disable async recovery for GMSL2 cameras
[component_container_isolated-2] [2024-12-09 13:10:46 UTC][ZED][INFO] Logging level INFO
[component_container_isolated-2] [2024-12-09 13:10:46 UTC][ZED][INFO] [Init]  Depth mode: NEURAL
[component_container_isolated-2] [2024-12-09 13:11:07 UTC][ZED][ERROR] [ZED] Cannot initialize the camera.
[component_container_isolated-2] (Argus) Error Timeout:  (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
[component_container_isolated-2] (Argus) Error Timeout:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
^C[WARNING] [launch]: user interrupted with ctrl-c (SIGINT)
[component_container_isolated-2] [INFO] [1733749914.251745984] [rclcpp]: signal_handler(signum=2)
[INFO] [robot_state_publisher-1]: process has finished cleanly [pid 3916]
[robot_state_publisher-1] [INFO] [1733749914.251747360] [rclcpp]: signal_handler(signum=2)
[ERROR] [component_container_isolated-2]: process[component_container_isolated-2] failed to terminate '5' seconds after receiving 'SIGINT', escalating to 'SIGTERM'
[INFO] [component_container_isolated-2]: sending signal 'SIGTERM' to process[component_container_isolated-2]
[component_container_isolated-2] [INFO] [1733749919.949748928] [rclcpp]: signal_handler(signum=15)
[ERROR] [component_container_isolated-2]: process[component_container_isolated-2] failed to terminate '10.0' seconds after receiving 'SIGTERM', escalating to 'SIGKILL'
[INFO] [component_container_isolated-2]: sending signal 'SIGKILL' to process[component_container_isolated-2]
[ERROR] [component_container_isolated-2]: process has died [pid 3918, exit code -9, cmd '/opt/ros/humble/lib/rclcpp_components/component_container_isolated --ros-args -r __node:=zed_container -r __ns:=/zed'].
Second run:
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2024-12-09-14-12-07-232141-GTW-ONX2-ubuntu-4463
[INFO] [robot_state_publisher-1]: process started with pid [4476]
[INFO] [component_container_isolated-2]: process started with pid [4478]
[robot_state_publisher-1] [INFO] [1733749927.656922624] [zed.zed_state_publisher]: got segment zed_camera_center
[robot_state_publisher-1] [INFO] [1733749927.657092800] [zed.zed_state_publisher]: got segment zed_camera_link
[robot_state_publisher-1] [INFO] [1733749927.657108256] [zed.zed_state_publisher]: got segment zed_left_camera_frame
[robot_state_publisher-1] [INFO] [1733749927.657117440] [zed.zed_state_publisher]: got segment zed_left_camera_optical_frame
[robot_state_publisher-1] [INFO] [1733749927.657125120] [zed.zed_state_publisher]: got segment zed_right_camera_frame
[robot_state_publisher-1] [INFO] [1733749927.657131680] [zed.zed_state_publisher]: got segment zed_right_camera_optical_frame
[component_container_isolated-2] [INFO] [1733749927.871584640] [zed.zed_container]: Load Library: /home/user/ros2_ws/install/zed_components/lib/libzed_camera_component.so
[component_container_isolated-2] [INFO] [1733749927.939856992] [zed.zed_container]: Found class: rclcpp_components::NodeFactoryTemplate<stereolabs::ZedCamera>
[component_container_isolated-2] [INFO] [1733749927.939960800] [zed.zed_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<stereolabs::ZedCamera>
[component_container_isolated-2] [INFO] [1733749928.836031840] [zed.zed_node]: ********************************
[component_container_isolated-2] [INFO] [1733749928.836100768] [zed.zed_node]:       ZED Camera Component
[component_container_isolated-2] [INFO] [1733749928.836112544] [zed.zed_node]: ********************************
[component_container_isolated-2] [INFO] [1733749928.836122272] [zed.zed_node]:  * namespace: /zed
[component_container_isolated-2] [INFO] [1733749928.836131200] [zed.zed_node]:  * node name: zed_node
[component_container_isolated-2] [INFO] [1733749928.836137856] [zed.zed_node]: ********************************
[component_container_isolated-2] [INFO] [1733749928.886377216] [zed.zed_node]: *** DEBUG parameters ***
[component_container_isolated-2] [INFO] [1733749928.886864704] [zed.zed_node]:  * SDK Verbose: 1
[component_container_isolated-2] [INFO] [1733749928.887028480] [zed.zed_node]:  * Debug Common: FALSE
[component_container_isolated-2] [INFO] [1733749928.887097856] [zed.zed_node]:  * Debug Simulation: FALSE
[component_container_isolated-2] [INFO] [1733749928.887141280] [zed.zed_node]:  * Debug Video/Depth: FALSE
[component_container_isolated-2] [INFO] [1733749928.887205568] [zed.zed_node]:  * Debug Control settings: FALSE
[component_container_isolated-2] [INFO] [1733749928.887246592] [zed.zed_node]:  * Debug Point Cloud: FALSE
[component_container_isolated-2] [INFO] [1733749928.887299616] [zed.zed_node]:  * Debug GNSS: FALSE
[component_container_isolated-2] [INFO] [1733749928.887342208] [zed.zed_node]:  * Debug Positional Tracking: FALSE
[component_container_isolated-2] [INFO] [1733749928.887385472] [zed.zed_node]:  * Debug sensors: FALSE
[component_container_isolated-2] [INFO] [1733749928.887426240] [zed.zed_node]:  * Debug Mapping: FALSE
[component_container_isolated-2] [INFO] [1733749928.887474496] [zed.zed_node]:  * Debug Object Detection: FALSE
[component_container_isolated-2] [INFO] [1733749928.887535168] [zed.zed_node]:  * Debug Body Tracking: FALSE
[component_container_isolated-2] [INFO] [1733749928.887584096] [zed.zed_node]:  * Debug Streaming: FALSE
[component_container_isolated-2] [INFO] [1733749928.887630944] [zed.zed_node]:  * Debug ROI: FALSE
[component_container_isolated-2] [INFO] [1733749928.887670336] [zed.zed_node]:  * Debug Advanced: FALSE
[component_container_isolated-2] [INFO] [1733749928.887759040] [zed.zed_node]: *** GENERAL parameters ***
[component_container_isolated-2] [INFO] [1733749928.887907936] [zed.zed_node]:  * Camera model: zedx - ZED X
[component_container_isolated-2] [INFO] [1733749928.887974976] [zed.zed_node]:  * Camera name: zed
[component_container_isolated-2] [INFO] [1733749928.888028352] [zed.zed_node]:  * Camera SN: 0
[component_container_isolated-2] [INFO] [1733749928.888072672] [zed.zed_node]:  * Camera timeout [sec]: 5
[component_container_isolated-2] [INFO] [1733749928.888115072] [zed.zed_node]:  * Camera reconnection temptatives: 5
[component_container_isolated-2] [INFO] [1733749928.888163872] [zed.zed_node]:  * Camera framerate: 30
[component_container_isolated-2] [INFO] [1733749928.888209056] [zed.zed_node]:  * GPU ID: -1
[component_container_isolated-2] [INFO] [1733749928.888298624] [zed.zed_node]:  * Camera resolution: HD1080
[component_container_isolated-2] [INFO] [1733749928.888352288] [zed.zed_node]:  * Publishing resolution: NATIVE
[component_container_isolated-2] [INFO] [1733749928.888406528] [zed.zed_node]:  * OpenCV custom calibration:
[component_container_isolated-2] [INFO] [1733749928.888454880] [zed.zed_node]:  * Camera self calibration: TRUE
[component_container_isolated-2] [INFO] [1733749928.888498720] [zed.zed_node]:  * Camera flip: FALSE
[component_container_isolated-2] [INFO] [1733749928.888601856] [zed.zed_node]:  * [DYN] Publish framerate [Hz]:  15
[component_container_isolated-2] [INFO] [1733749928.888623584] [zed.zed_node]: *** VIDEO parameters ***
[component_container_isolated-2] [INFO] [1733749928.888672896] [zed.zed_node]:  * [DYN] Saturation: 4
[component_container_isolated-2] [INFO] [1733749928.888727456] [zed.zed_node]:  * [DYN] Sharpness: 4
[component_container_isolated-2] [INFO] [1733749928.888772800] [zed.zed_node]:  * [DYN] Gamma: 8
[component_container_isolated-2] [INFO] [1733749928.888827456] [zed.zed_node]:  * [DYN] Auto Exposure/Gain: TRUE
[component_container_isolated-2] [INFO] [1733749928.888871744] [zed.zed_node]:  * [DYN] Exposure: 80
[component_container_isolated-2] [INFO] [1733749928.888915840] [zed.zed_node]:  * [DYN] Gain: 80
[component_container_isolated-2] [INFO] [1733749928.888969376] [zed.zed_node]:  * [DYN] Auto White Balance: TRUE
[component_container_isolated-2] [INFO] [1733749928.889013472] [zed.zed_node]:  * [DYN] White Balance Temperature: 42
[component_container_isolated-2] [INFO] [1733749928.889082880] [zed.zed_node]:  * [DYN] ZED X Exposure time: 16000
[component_container_isolated-2] [INFO] [1733749928.889143104] [zed.zed_node]:  * [DYN] ZED X Auto Exp. time range min: 28
[component_container_isolated-2] [INFO] [1733749928.889199360] [zed.zed_node]:  * [DYN] ZED X Auto Exp. time range max: 30000
[component_container_isolated-2] [INFO] [1733749928.889262944] [zed.zed_node]:  * [DYN] ZED X Exposure comp.: 50
[component_container_isolated-2] [INFO] [1733749928.889306304] [zed.zed_node]:  * [DYN] ZED X Analog Gain: 1255
[component_container_isolated-2] [INFO] [1733749928.889356160] [zed.zed_node]:  * [DYN] ZED X Auto Analog Gain range min: 1000
[component_container_isolated-2] [INFO] [1733749928.889765024] [zed.zed_node]:  * [DYN] ZED X Auto Analog Gain range max: 16000
[component_container_isolated-2] [INFO] [1733749928.889832480] [zed.zed_node]:  * [DYN] ZED X Digital Gain: 1
[component_container_isolated-2] [INFO] [1733749928.889892640] [zed.zed_node]:  * [DYN] ZED X Auto Digital Gain range min: 1
[component_container_isolated-2] [INFO] [1733749928.889946720] [zed.zed_node]:  * [DYN] ZED X Auto Digital Gain range max: 256
[component_container_isolated-2] [INFO] [1733749928.890092864] [zed.zed_node]:  * [DYN] ZED X Auto Digital Gain range max: 50
[component_container_isolated-2] [INFO] [1733749928.890130112] [zed.zed_node]: *** DEPTH parameters ***
[component_container_isolated-2] [INFO] [1733749928.890307648] [zed.zed_node]:  * Depth mode: NEURAL [4]
[component_container_isolated-2] [INFO] [1733749928.890456608] [zed.zed_node]:  * Min depth [m]: 0.3
[component_container_isolated-2] [INFO] [1733749928.890590848] [zed.zed_node]:  * Max depth [m]: 10
[component_container_isolated-2] [INFO] [1733749928.890785056] [zed.zed_node]:  * Depth Stabilization: 1
[component_container_isolated-2] [INFO] [1733749928.891468416] [zed.zed_node]:  * OpenNI mode (16bit point cloud): FALSE
[component_container_isolated-2] [INFO] [1733749928.891555104] [zed.zed_node]:  * [DYN] Point cloud rate [Hz]: 5
[component_container_isolated-2] [INFO] [1733749928.891604576] [zed.zed_node]:  * [DYN] Depth Confidence: 50
[component_container_isolated-2] [INFO] [1733749928.891646400] [zed.zed_node]:  * [DYN] Depth Texture Confidence: 100
[component_container_isolated-2] [INFO] [1733749928.891703168] [zed.zed_node]:  * [DYN] Remove saturated areas: TRUE
[component_container_isolated-2] [INFO] [1733749928.891726880] [zed.zed_node]: *** GNSS FUSION parameters ***
[component_container_isolated-2] [INFO] [1733749928.891770016] [zed.zed_node]:  * GNSS fusion enabled: FALSE
[component_container_isolated-2] [INFO] [1733749928.891787360] [zed.zed_node]: *** POSITIONAL TRACKING parameters ***
[component_container_isolated-2] [INFO] [1733749928.891824000] [zed.zed_node]:  * Positional tracking enabled: TRUE
[component_container_isolated-2] [INFO] [1733749928.891877568] [zed.zed_node]:  * Positional tracking mode: GEN 2
[component_container_isolated-2] [INFO] [1733749928.891934752] [zed.zed_node]:  * Map frame id: map
[component_container_isolated-2] [INFO] [1733749928.891973376] [zed.zed_node]:  * Odometry frame id: odom
[component_container_isolated-2] [INFO] [1733749928.892008160] [zed.zed_node]:  * Broadcast Odometry TF: TRUE
[component_container_isolated-2] [INFO] [1733749928.892042848] [zed.zed_node]:  * Broadcast Pose TF: TRUE
[component_container_isolated-2] [INFO] [1733749928.892092608] [zed.zed_node]:  * [DYN] Depth minimum range: 0
[component_container_isolated-2] [INFO] [1733749928.892133472] [zed.zed_node]:  * [DYN] TF timestamp offset: 0
[component_container_isolated-2] [INFO] [1733749928.892170912] [zed.zed_node]:  * [DYN] Path publishing rate: 2
[component_container_isolated-2] [INFO] [1733749928.892208192] [zed.zed_node]:  * Path history lenght: -1
[component_container_isolated-2] [INFO] [1733749928.892266432] [zed.zed_node]:  * Initial pose: [0,0,0,0,0,0,]
[component_container_isolated-2] [INFO] [1733749928.892323680] [zed.zed_node]:  * Area Memory: TRUE
[component_container_isolated-2] [INFO] [1733749928.892362176] [zed.zed_node]:  * Area Memory DB:
[component_container_isolated-2] [INFO] [1733749928.892397856] [zed.zed_node]:  * Camera is static: FALSE
[component_container_isolated-2] [INFO] [1733749928.892433600] [zed.zed_node]:  * Gravity as origin [not for ZED]: TRUE
[component_container_isolated-2] [INFO] [1733749928.892475680] [zed.zed_node]:  * IMU Fusion [not for ZED]: TRUE
[component_container_isolated-2] [INFO] [1733749928.892512288] [zed.zed_node]:  * Floor Alignment: FALSE
[component_container_isolated-2] [INFO] [1733749928.892550016] [zed.zed_node]:  * Reset Odometry with Loop Closure: TRUE
[component_container_isolated-2] [INFO] [1733749928.892594048] [zed.zed_node]:  * 2D mode: FALSE
[component_container_isolated-2] [INFO] [1733749928.892611328] [zed.zed_node]: *** Region of Interest parameters ***
[component_container_isolated-2] [INFO] [1733749928.892650304] [zed.zed_node]:  * Automatic ROI generation: FALSE
[component_container_isolated-2] [INFO] [1733749928.892726528] [zed.zed_node]:  * Manual ROI polygon: []
[component_container_isolated-2] [INFO] [1733749928.892744704] [zed.zed_node]: *** SENSORS STACK parameters ***
[component_container_isolated-2] [INFO] [1733749928.892787648] [zed.zed_node]:  * Broadcast IMU TF [not for ZED]: TRUE
[component_container_isolated-2] [INFO] [1733749928.892833376] [zed.zed_node]:  * Sensors Camera Sync: FALSE
[component_container_isolated-2] [INFO] [1733749928.892884512] [zed.zed_node]:  * Sensors publishing rate: 200 Hz
[component_container_isolated-2] [INFO] [1733749928.892902272] [zed.zed_node]: *** Spatial Mapping parameters ***
[component_container_isolated-2] [INFO] [1733749928.892943136] [zed.zed_node]:  * Spatial Mapping Enabled: FALSE
[component_container_isolated-2] [INFO] [1733749928.893002688] [zed.zed_node]:  * Spatial Mapping resolution [m]: 0.05
[component_container_isolated-2] [INFO] [1733749928.893056832] [zed.zed_node]:  * 3D Max Mapping range [m]: 5
[component_container_isolated-2] [INFO] [1733749928.893102912] [zed.zed_node]:  * Map publishing rate [Hz]: 1
[component_container_isolated-2] [INFO] [1733749928.893153600] [zed.zed_node]:  * Clicked point topic: /clicked_point
[component_container_isolated-2] [INFO] [1733749928.893201536] [zed.zed_node]:  * Plane Det. Max Dist. Thresh.: 0.15
[component_container_isolated-2] [INFO] [1733749928.893330112] [zed.zed_node]:  * Plane Det. Normals Sim. Thresh.: 15
[component_container_isolated-2] [INFO] [1733749928.893351360] [zed.zed_node]: *** Object Det. parameters ***
[component_container_isolated-2] [INFO] [1733749928.893394912] [zed.zed_node]:  * Object Det. enabled: FALSE
[component_container_isolated-2] [INFO] [1733749928.893475904] [zed.zed_node]:  * Object Det. model: MULTI CLASS BOX FAST
[component_container_isolated-2] [INFO] [1733749928.893529952] [zed.zed_node]:  * Object Det. allow reduced precision: TRUE
[component_container_isolated-2] [INFO] [1733749928.893579136] [zed.zed_node]:  * Object Det. maximum range [m]: 20
[component_container_isolated-2] [INFO] [1733749928.893625760] [zed.zed_node]:  * Object Det. min. confidence: 75
[component_container_isolated-2] [INFO] [1733749928.893677440] [zed.zed_node]:  * Object Det. prediction timeout [sec]: 0.5
[component_container_isolated-2] [INFO] [1733749928.893717120] [zed.zed_node]:  * Object Det. tracking: TRUE
[component_container_isolated-2] [INFO] [1733749928.893783968] [zed.zed_node]:  * Object Filtering mode: 1 - NMS3D
[component_container_isolated-2] [INFO] [1733749928.893872416] [zed.zed_node]:  * MultiClassBox people: TRUE
[component_container_isolated-2] [INFO] [1733749928.893930784] [zed.zed_node]:  * MultiClassBox vehicles: TRUE
[component_container_isolated-2] [INFO] [1733749928.893990784] [zed.zed_node]:  * MultiClassBox bags: TRUE
[component_container_isolated-2] [INFO] [1733749928.894052448] [zed.zed_node]:  * MultiClassBox animals: TRUE
[component_container_isolated-2] [INFO] [1733749928.894100832] [zed.zed_node]:  * MultiClassBox electronics: TRUE
[component_container_isolated-2] [INFO] [1733749928.894146880] [zed.zed_node]:  * MultiClassBox fruits and vegetables: TRUE
[component_container_isolated-2] [INFO] [1733749928.894191744] [zed.zed_node]:  * MultiClassBox sport-related objects: TRUE
[component_container_isolated-2] [INFO] [1733749928.894210112] [zed.zed_node]: *** Body Track. parameters ***
[component_container_isolated-2] [INFO] [1733749928.894265024] [zed.zed_node]:  * Body Track. enabled: FALSE
[component_container_isolated-2] [INFO] [1733749928.894338432] [zed.zed_node]:  * Body Track. model: HUMAN BODY MEDIUM
[component_container_isolated-2] [INFO] [1733749928.894418176] [zed.zed_node]:  * Body Track. format: BODY 38
[component_container_isolated-2] [INFO] [1733749928.894487936] [zed.zed_node]:  * Body Track. allow reduced precision: TRUE
[component_container_isolated-2] [INFO] [1733749928.894540512] [zed.zed_node]:  * Body Track. maximum range [m]: 20
[component_container_isolated-2] [INFO] [1733749928.894588896] [zed.zed_node]:  * Body Track. KP selection: FULL
[component_container_isolated-2] [INFO] [1733749928.894666784] [zed.zed_node]:  * Body fitting: FALSE
[component_container_isolated-2] [INFO] [1733749928.894716352] [zed.zed_node]:  * Body joints tracking: TRUE
[component_container_isolated-2] [INFO] [1733749928.894768864] [zed.zed_node]:  * Body Track. prediction timeout [sec]: 0.5
[component_container_isolated-2] [INFO] [1733749928.894817984] [zed.zed_node]:  * Body Track. confidence thresh.: 50
[component_container_isolated-2] [INFO] [1733749928.894864768] [zed.zed_node]:  * Body Track. min. KP thresh.: 5
[component_container_isolated-2] [INFO] [1733749928.894883232] [zed.zed_node]: *** Streaming Server parameters ***
[component_container_isolated-2] [INFO] [1733749928.894955552] [zed.zed_node]:  * Streaming Server enabled: FALSE
[component_container_isolated-2] [INFO] [1733749928.895011872] [zed.zed_node]:  * Stream codec: H264
[component_container_isolated-2] [INFO] [1733749928.895058880] [zed.zed_node]:  * Stream port:30000
[component_container_isolated-2] [INFO] [1733749928.895108480] [zed.zed_node]:  * Stream bitrate: 12500
[component_container_isolated-2] [INFO] [1733749928.895157152] [zed.zed_node]:  * Stream GOP size: -1
[component_container_isolated-2] [INFO] [1733749928.895216032] [zed.zed_node]:  * Stream Chunk size: 16084
[component_container_isolated-2] [INFO] [1733749928.895278880] [zed.zed_node]:  * Adaptive bitrate: FALSE
[component_container_isolated-2] [INFO] [1733749928.895338048] [zed.zed_node]:  * Target frame rate:0
[component_container_isolated-2] [INFO] [1733749928.895357824] [zed.zed_node]: *** Advanced parameters ***
[component_container_isolated-2] [INFO] [1733749928.895406304] [zed.zed_node]:  * Thread sched. policy: SCHED_BATCH
[component_container_isolated-2] [INFO] [1733749928.895496512] [zed.zed_node]: *** SERVICES ***
[component_container_isolated-2] [INFO] [1733749928.896709920] [zed.zed_node]:  * '/zed/zed_node/reset_odometry'
[component_container_isolated-2] [INFO] [1733749928.897235872] [zed.zed_node]:  * '/zed/zed_node/reset_pos_tracking'
[component_container_isolated-2] [INFO] [1733749928.898317920] [zed.zed_node]:  * '/zed/zed_node/set_pose'
[component_container_isolated-2] [INFO] [1733749928.898860800] [zed.zed_node]:  * '/zed/zed_node/enable_obj_det'
[component_container_isolated-2] [INFO] [1733749928.899326144] [zed.zed_node]:  * '/zed/zed_node/enable_body_trk'
[component_container_isolated-2] [INFO] [1733749928.899764128] [zed.zed_node]:  * '/zed/zed_node/enable_mapping'
[component_container_isolated-2] [INFO] [1733749928.900241600] [zed.zed_node]:  * '/zed/zed_node/enable_streaming'
[component_container_isolated-2] [INFO] [1733749928.900776640] [zed.zed_node]:  * '/zed/zed_node/start_svo_rec'
[component_container_isolated-2] [INFO] [1733749928.901236544] [zed.zed_node]:  * '/zed/zed_node/stop_svo_rec'
[component_container_isolated-2] [INFO] [1733749928.901744416] [zed.zed_node]:  * '/zed/zed_node/set_roi'
[component_container_isolated-2] [INFO] [1733749928.902183424] [zed.zed_node]:  * '/zed/zed_node/reset_roi'
[component_container_isolated-2] [INFO] [1733749928.902280128] [zed.zed_node]: ***** STARTING CAMERA *****
[component_container_isolated-2] [INFO] [1733749929.034243552] [zed.zed_node]: ZED SDK Version: 4.2.2 - Build 95990_fb77e75e
[component_container_isolated-2] [2024-12-09 13:12:09 UTC][ZED][INFO] Logging level INFO
[component_container_isolated-2] [INFO] [1733749929.043756704] [zed.zed_node]: *** CAMERA OPENING ***
[component_container_isolated-2] [INFO] [1733749929.043845440] [zed.zed_node]: Disable async recovery for GMSL2 cameras
[component_container_isolated-2] [WARN] [1733749929.581233408] [zed.zed_node]: Error opening camera: CAMERA NOT DETECTED
[component_container_isolated-2] [INFO] [1733749929.581334720] [zed.zed_node]: Please verify the camera connection
[component_container_isolated-2] [2024-12-09 13:12:09 UTC][ZED][WARNING] CAMERA NOT DETECTED in sl::ERROR_CODE sl::Camera::open(sl::InitParameters)
[component_container_isolated-2] [INFO] [1733749934.354727584] [rclcpp]: signal_handler(signum=2)
[INFO] [robot_state_publisher-1]: process has finished cleanly [pid 4476]
[robot_state_publisher-1] [INFO] [1733749934.354731008] [rclcpp]: signal_handler(signum=2)
[component_container_isolated-2] [2024-12-09 13:12:14 UTC][ZED][INFO] Logging level INFO
[component_container_isolated-2] [2024-12-09 13:12:14 UTC][ZED][ERROR] [ZED] sl::Camera::Open has not been called, no Camera instance running.
[component_container_isolated-2] [2024-12-09 13:12:14 UTC][ZED][WARNING] CAMERA NOT DETECTED in sl::ERROR_CODE sl::Camera::open(sl::InitParameters)
[component_container_isolated-2] [WARN] [1733749934.920422784] [zed.zed_node]: Error opening camera: CAMERA NOT DETECTED
[component_container_isolated-2] [INFO] [1733749934.920464384] [zed.zed_node]: Please verify the camera connection
[component_container_isolated-2] [INFO] [1733749934.920485344] [zed.zed_node]: ZED activation interrupted by user.
[ERROR] [component_container_isolated-2]: process has died [pid 4478, exit code 1, cmd '/opt/ros/humble/lib/rclcpp_components/component_container_isolated --ros-args -r __node:=zed_container -r __ns:=/zed'].
The issue doesn’t seem to be related to ROS2 wrapper, as similar issues happen with ZED Explorer - it can connect to the camera fresh after the restart, stream the video for few seconds before the freeze, on the next try it cannot even connect to it. In the meantime I’ve tried to connect the second ZED X camera that I have to this ZED Box - the same problem happened.
@mbryla please send an email to support@stereolabs.com with a link to this thread.
Any updates or solutions for this issue?
I encountered this issue suddenly… Tried downgrading to ZED SDK 4.2.3, but the problem persists.
I am encountering the same issue- ZEDXMini cameras run for a while and then disconnect, requiring a restart to get back up.
My logs look very similar to the ones provided in this thread.
Any updates on this issue?
I’m facing a similar issue.
+1 the same problem with X mini, looks like problem occur after updating the driver with sdk
@nyrjan please write an email to support@stereolabs.com and add all the relevant details.
