Hi all,
My Zed X and Mono Capture card worked great up until today. My setup hasn’t changed at all since 2-3 days ago when it worked as expected. I’ve checked multiple times the connection of the orange ribbon cable, have tested that the card has the right voltage, current draw, that it’s not shortcircuited etc. The problem isn’t software as nothing has been updated, reinstalled/changed etc. Most recent sdk and capture card drivers versions.
When trying to run the ROS2 Zed Node I get the following:
[component_container_isolated-2] [WARN] [1768249712.045207187] [zed.zed_node]: Error opening camera: CAMERA STREAM FAILED TO START
[component_container_isolated-2] [INFO] [1768249712.045235893] [zed.zed_node]: Please verify the camera connection
The Zed Diagnostic can’t detect both the Camera and the Capture Card. Here is the sudo dmesg log:
dmesg.log (10.5 KB)
Would appreciate any help!
