0x00007FFC3DE24FD9 处(位于 ZED_Tutorial_8.exe 中)有未经处理的异常: Microsoft C++ 异常: std::length_error,位于内存位置 0x0000006E7490F170 处。
Hi @lt613
please provide more information about this problem, starting from the configuration of your system.
@lt613 have you modified the source code of the tutorial?
我没有修改过,完全是按照例子来的,
---- 回复的原邮件 ----
| 发件人 | Walter Lucetti (Stereolabs)support@stereolabs.com |
| 日期 | 2022年05月20日 18:00 |
| 收件人 | Lt613lt00613@163.com |
| 抄送至 | |
| 主题 | Re: 关于ZED_Tutorial_8.exe 的异常 |
@lt613 please use the English language on the Forum, so the messages are accessible for everyone.
Regarding your problem, please write an email to support@stereolabs.com adding the report file generated by the ZED Diagnostic tool as an attachment.
try to put GLEW library GLEW: The OpenGL Extension Wrangler Library
also try to make sure that your Cmake configuration all correct
mine got working fine
here is my Cmake
mine is not work yet,
thanks for your sharing
在 2022-05-22 23:39:31,“Calonpintar (Stereolabs)” support@stereolabs.com 写道:
