Hi @adujardin,
I’m sorry I wasn’t clear in the description of my problem. I’m first using a computer with an NVIDIA RTX 4070 and 12th Gen Intel(R) Core™ i5-12600KF to learn how to use the tool before trying it out in the Jetson Orin Nano, but based on your answer I assume I cannot use the ZED_SVO_Editor in the Jetson Orin Nano to change the compression mode after the video is recorded in LOSSLESS.
That being said, I just made a test in the desktop computer that consisted in recording using the ZED_Explorer tool (zed_explorer.svo2) and also with the python API using a script (script.svo and script.svo2). The three files where recorded in LOSSLESS_MODE and script.svo and script.svo2 are both of 3 min, whereas the zed_explorer.svo2 is about 17 seconds long.
In the next sequence of commands I tried to get the info of the three files, only being successful with the script.svo. Then, I ran the -repair command on both .svo2 (which yesterday failed but today worked), and finally, I tried to run the -cpr option which was successful only with the zed_explorer_repaired.svo2 file of 17 seconds and failed with the script_repaired.svo2 .
wildsense@dev-server:~/rov_recordings$ ls
script.svo script.svo2 zed_explorer.svo2
wildsense@dev-server:~/rov_recordings$ ZED_SVO_Editor -inf script.svo
-inf option detected
SVO Infos : SVO v 1
Image Size : [ 1920 x 1080 ]
Framerate : 15
Number of Frames : 2593
ZED Serial Number : 36848014
Compression mode : "Lossless compression (png)"
Product : ZED2i
Sensors Fw version : 777
Camera Fw version : 1523
wildsense@dev-server:~/rov_recordings$ ZED_SVO_Editor -inf script.svo2
*FAIL : failed to get infos from "script.svo2"
You can try the -repair option to repair the SVO file
wildsense@dev-server:~/rov_recordings$ ZED_SVO_Editor -inf zed_explorer.svo2
*FAIL : failed to get infos from "zed_explorer.svo2"
wildsense@dev-server:~/rov_recordings$ ZED_SVO_Editor -repair zed_explorer.svo2 -repair option detected
* Repair in progress... Please wait *
** SUCCESS : SVO file has been repaired under the name : "zed_explorer_repaired.svo2"
wildsense@dev-server:~/rov_recordings$ ZED_SVO_Editor -inf zed_explorer_repaired.svo2
SVO Infos : SVO v 2
Image Size : [ 2208 x 1242 ]
Framerate : 15
Number of Frames : 247
Product : ZED2i
wildsense@dev-server:~/rov_recordings$ ZED_SVO_Editor -cpr zed_explorer_repaired.svo2 -m 6 zed_explorer_H265.svo2
-compress option detected
** Start to compress in undef
99% [================================================= ]
New SVO File created!
wildsense@dev-server:~/rov_recordings$ ZED_SVO_Editor -repair script.svo2
** SUCCESS : SVO file has been repaired under the name : "script_repaired.svo2"
wildsense@dev-server:~/rov_recordings$ ZED_SVO_Editor -cpr script_repaired.svo2 -m 6 script_H265.svo2
Killed
wildsense@dev-server:~/rov_recordings$ ZED_SVO_Editor -cpr script.svo2 -m 6 script_o_H265.svo2
*FAIL : failed to open "script.svo2"
Trying to open one of the original .svo2 files with the ZED_Explorer tool will result in the termination of the tool and display of the next error message:
wildsense@dev-server:~/rov_recordings$ ZED_Explorer
#31 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7e2ed8cb9e39, in QCoreApplication::notifyInternal2(QObject*, QEvent*)
#30 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed996c712, in QApplicationPrivate::notify_helper(QObject*, QEvent*)
#29 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7e2ed8ce733e, in QObject::event(QEvent*)
#28 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7e2ed8cf57fd, in QTimer::timeout(QTimer::QPrivateSignal)
#27 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7e2ed8cf17c7, in
#26 Object "ZED_Explorer", at 0x4e4b33, in
#25 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7e2ed8d13111, in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#24 Object "/lib/x86_64-linux-gnu/libglib-2.0.so.0", at 0x7e2ed7b1e3e2, in g_main_context_iteration
#23 Object "/lib/x86_64-linux-gnu/libglib-2.0.so.0", at 0x7e2ed7b76257, in
#22 Object "/lib/x86_64-linux-gnu/libglib-2.0.so.0", at 0x7e2ed7b20d3a, in g_main_context_dispatch
#21 Object "/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5", at 0x7e2ed52c8d6d, in
#20 Object "/lib/x86_64-linux-gnu/libQt5Gui.so.5", at 0x7e2ed9116a2b, in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#19 Object "/lib/x86_64-linux-gnu/libQt5Gui.so.5", at 0x7e2ed9141306, in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*)
#18 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7e2ed8cb9e39, in QCoreApplication::notifyInternal2(QObject*, QEvent*)
#17 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed996c712, in QApplicationPrivate::notify_helper(QObject*, QEvent*)
#16 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed99cbfd4, in
#15 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed99c8d3f, in
#14 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed9972e46, in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool)
#13 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7e2ed8cb9e39, in QCoreApplication::notifyInternal2(QObject*, QEvent*)
#12 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed9974363, in QApplication::notify(QObject*, QEvent*)
#11 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed996c712, in QApplicationPrivate::notify_helper(QObject*, QEvent*)
#10 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed99af4ed, in QWidget::event(QEvent*)
#9 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed9b60d9d, in QToolButton::mouseReleaseEvent(QMouseEvent*)
#8 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed9a641e6, in QAbstractButton::mouseReleaseEvent(QMouseEvent*)
#7 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed9a63fc3, in
#6 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed9a6239d, in
#5 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed9a62115, in QAbstractButton::clicked(bool)
#4 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7e2ed8cf17c7, in
#3 Object "ZED_Explorer", at 0x4e36f3, in
#2 Object "ZED_Explorer", at 0x4e0e75, in
#1 Object "/lib/x86_64-linux-gnu/libQt5Widgets.so.5", at 0x7e2ed99a035a, in QWidget::setStyleSheet(QString const&)
#0 Object "/lib/x86_64-linux-gnu/libQt5Core.so.5", at 0x7e2ed8b50300, in QString::operator=(QString const&)
Segmentation fault (Invalid permissions for mapped object [0x7e2ed8a0aa40])
I also recorded one file with the python API script in H265 compression mode and the file didn’t present any problems with the ZED_SVO_Editor -inf command.
The complexity of the problem is that the project I’m working now requires to use the Orin Nano, so the only viable option is to record in LOSSLESS mode, which afterwards ideally should be converted to H265 for storage reasons.
