ZED Quadlink not being detected
I’m using Jetson AGX Orin with 6.2.1 and Zed Quad Link Driver Ver 1.4. I powered the quadlink with 12volt but still can’t be found by the driver. Here is the ZED_Diagnostic_Results.json
“AI Models”: {
“info”: \[
“NEURAL LIGHT DEPTH is not optimized”,
“NEURAL DEPTH is not optimized”,
“NEURAL PLUS DEPTH is not optimized”
“CUDA Operations”: {
“cudaDeviceCount”: 1,
“cudaDriverVersion”: 12060,
“cudaDriverVersionString”: “12.6”,
“cudaGetDeviceCountResult”: 0,
“cudaRuntimeLoaded”: true,
“cudaRuntimeVersion”: 12060,
“cudaRuntimeVersionString”: “12.6”,
“cudaTestVersion”: “1.0”,
“gpuTests”: \[
“clockRateMHz”: 1300,
“computeCapability”: “8.7”,
“computeCapabilityMajor”: 8,
“computeCapabilityMinor”: 7,
“freeResult”: 0,
“freeSuccess”: true,
“gpuId”: 0,
“gpuName”: “Orin”,
“mallocResult”: 0,
“mallocSuccess”: true,
“memcpyD2HResult”: 0,
“memcpyD2HSuccess”: true,
“memcpyH2DResult”: 0,
“memcpyH2DSuccess”: true,
“memoryBusWidthBits”: 256,
“memoryClockRateMHz”: 1300,
“memsetResult”: 0,
“memsetSuccess”: true,
“multiProcessorCount”: 16,
“pciBusId”: 0,
“pciDeviceId”: 0,
“pciDomainId”: 0,
“setDeviceResult”: 0,
“testElements”: 1048576,
“testPassed”: true,
“testSizeBytes”: 4194304,
“totalGlobalMemMB”: 62841,
“validationPassed”: true
“testSizeMB”: 1,
“valid”: \[
“**GPU 0 (Orin):** CUDA operations working correctly”
“GMSL DRIVER”: {
“GMSL driver”: “ii  stereolabs-zedlink-quad                           1.4.0-SL-MAX96712-L4T36.4.0                 arm64        NVIDIA Kernel DTB Modified Package by Stereolabs\\n”,
“error”: \[
“**The Capture card is not plugged or wrong driver installed.** ”
“Graphics Card”: {
“deviceCount”: 1,
“deviceDriverVersion”: 12060,
“devices”: \[
“arch”: “Ampere”,
“cores”: 2048,
“name”: “Orin”,
“totalMemoryBytes”: “65894395904”,
“totalMemoryMB”: 62841.79296875
“glx_info”: “OpenGL vendor string: NVIDIA Corporation\\nOpenGL renderer string: NVIDIA Tegra Orin (nvgpu)/integrated\\nOpenGL core profile version string: 4.6.0 NVIDIA 540.4.0\\nOpenGL core profile shading language version string: 4.60 NVIDIA\\nOpenGL core profile context flags: (none)\\nOpenGL core profile profile mask: core profile\\nOpenGL core profile extensions:\\nOpenGL version string: 4.6.0 NVIDIA 540.4.0\\nOpenGL shading language version string: 4.60 NVIDIA\\nOpenGL context flags: (none)\\nOpenGL profile mask: (none)\\nOpenGL extensions:\\nOpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 540.4.0\\nOpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20\\nOpenGL ES profile extensions:\\n”,
“initResult”: 0,
“valid”: \[
“**Graphics card:**  Orin”
“Log Kernel Trace (for ZED X)”: {
“dmesg”: {
"DMESG \[DTS\] LOG ": \[
“DMESG \[MAX9x\] LOG”: \[
"DMESG \[PCA\] LOG “: \[
“DMESG \[ZEDX\] LOG”: \[
“DTB list SLabs”: \[
“board.py”,
“extlinux.py”,
“fio.py”,
“Headers”,
“Jetson”,
“Linux”,
“**pycache**”,
“Utils”,
“zlconfig”
“DTB list original”: \[
“/boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv.dtb”
“Dpkg list Stereolabs”: \[
“ii  stereolabs-zedlink-quad                           1.4.0-SL-MAX96712-L4T36.4.0                 arm64        NVIDIA Kernel DTB Modified Package by Stereolabs”
“Dpkg list zed”: \[
“Driver list”: {
“/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9295/sl_max9295.ko”: “exists”,
“/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9296/max9296.ko”: “not found”,
“/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9296/sl_max9296.ko”: “not found”,
“/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max96712/max96712.ko”: “not found”,
“/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max96712/sl_max96712.ko”: “exists”,
“/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedone4k/sl_zedxone_uhd.ko”: “exists”,
“/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedx/max96712.ko”: “not found”,
“/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedx/sl_zedx.ko”: “exists”,
“/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedxpro/sl_zedxpro.ko”: “not found”
“EXTlinux file”: \[
“TIMEOUT 30”,
“DEFAULT Stereolabs”,
“MENU TITLE L4T boot options”,
“LABEL primary”,
“\\tMENU LABEL primary kernel”,
“\\tLINUX /boot/Image”,
“\\tFDT /boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv.dtb”,
“\\tINITRD /boot/initrd”,
“\\tAPPEND ${cbootargs} root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0”,
“LABEL Stereolabs”,
“\\tMENU LABEL Stereolabs kernel”,
“\\tFDT /mnt/APP/boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv.dtb”,
“\\tOVERLAYS /boot/tegra234-p3737-camera-zedlink-quad-sl-overlay.dtbo”
“I2C Trace list”: {
“I2C Trace /dev/i2C-0”: \[
"     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f”,
"00:                         – – – – – – – – ",
"10: – – – – – – – – – – – – – – – – ",
"20: – – – – – – – – – – – – – – – – ",
"30: – – – – – – – – – – – – – – – – ",
"40: – – – – – – – – – – – – – – – – ",
"50: UU – – – – – – – – – – – – – – – ",
"60: – – – – – – – – – – – – – – – – ",
“70: – – – – – – – –                         "
“I2C Trace /dev/i2C-1”: \[
"30: – – – – – – – – UU – – – – – – – ",
"40: UU UU – – – – – – – – – – – – – – ",
"50: – – – – – – – – – – – – – – – – ",
“I2C Trace /dev/i2C-2”: \[
“70: 70 – – – – – – –                         "
“I2C Trace /dev/i2C-3”: \[
“I2C Trace /dev/i2C-6”: \[
“I2C Trace /dev/i2C-7”: \[
"40: – – – – – – – – – UU – – – – – – ",
“I2C Trace /dev/i2C-8”: \[
"30: – – – – – – – – – – – – – – – – “,
“40: – – – – – – – – – – – – – – – – “,
“50: – – – – – – – – – – – – – – – – “,
“60: – – – – – – – – – – – – – – – – “,
“Jetpack”: \[
“# R36 (release), REVISION: 4.4, GCID: 41062509, BOARD: generic, EABI: aarch64, DATE: Mon Jun 16 16:07:13 UTC 2025”,
“# KERNEL_VARIANT: oot”,
“TARGET_USERSPACE_LIB_DIR=nvidia”,
“TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia”
“Linux_uname”: \[
“Linux forecr-desktop 5.15.148-tegra #1 SMP PREEMPT Mon Jul 7 10:43:06 +03 2025 aarch64 aarch64 aarch64 GNU/Linux”
“ZED SDK Version”: {
“Diag”: “5.2.0”,
“RT”: “5.2.0”
“ZEDX Daemon Status LS”: \[
“● zed_x_daemon.service - ZED-X Daemon service”,
"     Loaded: loaded (/etc/systemd/system/zed_x_daemon.service; enabled; vendor preset: enabled)”,
"     Active: active (running) since Wed 2026-02-25 20:56:26 UTC; 6min ago”,
"   Main PID: 1356 (ZEDX_Daemon)”,
"      Tasks: 5 (limit: 74768)”,
"     Memory: 1.1M”,
"        CPU: 1.283s”,
"     CGroup: /system.slice/zed_x_daemon.service”,
"             └─1356 /usr/sbin/ZEDX_Daemon”,
“Feb 25 20:56:26 forecr-desktop systemd\[1\]: Started ZED-X Daemon service.”
“ZEDX Driver State”: \[
“sl_zedxone_uhd         36864  0”,
“sl_zedx                28672  0”,
“sl_zedxhdr             20480  0”,
“sl_max9295             16384  3 sl_zedxhdr,sl_zedxone_uhd,sl_zedx”,
“sl_max96712            32768  4 sl_zedxhdr,sl_zedxone_uhd,sl_max9295,sl_zedx”,
“tegra_camera          217088  6 nvhost_isp5,nvhost_nvcsi_t194,sl_zedxhdr,sl_zedxone_uhd,nvhost_vi5,sl_zedx”,
“videodev              270336  7 v4l2_async,sl_zedxhdr,videobuf2_v4l2,tegra_camera,sl_zedxone_uhd,videobuf2_common,sl_zedx”
“i2C Trace”: \[
“i2c-0\\ti2c       \\t3160000.i2c                     \\tI2C adapter”,
“i2c-1\\ti2c       \\tc240000.i2c                     \\tI2C adapter”,
“i2c-2\\ti2c       \\t3180000.i2c                     \\tI2C adapter”,
“i2c-3\\ti2c       \\t3190000.i2c                     \\tI2C adapter”,
“i2c-4\\ti2c       \\tTegra BPMP I2C adapter          \\tI2C adapter”,
“i2c-5\\ti2c       \\t31b0000.i2c                     \\tI2C adapter”,
“i2c-6\\ti2c       \\t31c0000.i2c                     \\tI2C adapter”,
“i2c-7\\ti2c       \\tc250000.i2c                     \\tI2C adapter”,
“i2c-8\\ti2c       \\t31e0000.i2c                     \\tI2C adapter”
“Processor”: {
“L4T version”: “36.4.4”,
“OS”: “Ubuntu 22.04.5 LTS “,
“avxSupported”: false,
“coreCount”: “12”,
“cpu”: " ARMv8 Processor rev 1 (v8l)”,
“datetime”: “2026-02-25 09:03:06 PM”,
“hyperThreading”: “0”,
“motherboard”: “Jetson, NVIDIA”,
“ramCapacity”: “65.894396”,
“ramUsage”: “”,
“ramUsed”: “3.877077”,
“threadCount”: “12”,
“valid”: \[
“**Processor:**   ARMv8 Processor rev 1 (v8l)”,
“**Motherboard:**  Jetson, NVIDIA”
“USB Camera”: {
“CorruptedFirmware”: \[
“GMSL driver”: \[
“GMSLList”: \[
“InternalDevicesCount (GMSL)”: \[
“InternalDevicesCount (USB)”: \[
“USBList”: \[
“ZEDCount”: \[
“ZEDDetected”: \[
“ZEDs”: \[
“error”: \[
“**No Camera detected**  Make sure the camera is plugged in.”,
“notTested”: \[
“Please connect a camera to test the USB connection.”,
“ZED SDK”: {
“CUDA Toolkit version”: “V12.6.68 -->located in /usr/local/cuda-12.6/bin/nvcc”,
“CUDA loading”: false,
“GPU Driver Version”: “Driver Version                            : 540.4.0”,
“GPU Performance”: "    Performance State                     : N/A”,
“ZED SDK Version (Diag)”: “5.2.0”,
“ZED SDK Version (RT)”: “5.2.0”,
“ai”: {
“checkAI”: true,
“cudaVersion”: 12060,
“tensorVersion”: 100300
“binFiles”: \[
“libsl_ai.so”,
“libsl_zed.so”
“resourcesFiles”: \[
“neural_depth_5.3.model”,
“neural_depth_light_5.2.model”,
“objects_accurate_3.2.model”,
“objects_medium_3.2.model”,
“objects_performance_3.2.model”,
“person_head_accurate_2.6.model”,
“person_head_performance_2.6.model”,
“person_reid_1.4.model”,
“skeleton_body18_3.2.model”,
“skeleton_body38_3.5.model”
“resourcesFilesExpected”: \[
“objects_performance_3.2”
“valid”: \[
“**ZED SDK version:** 5.2.0”,
“**CUDA version:** V12.6.68”
Hi @vav395
Are you using a Jetson AGX Orin devkit?
Please send pictures of the capture card installed on the carrier board to allow me to detect any anomalies.
