ZED Link Mono on Auvidea JNX42-M2 / JetPack 6.2.2 – missing Auvidea camera overlay?
I’m trying to set up ZED Link Mono capture cards on an Auvidea JNX42-M2 (PCB 38556-4.1 / 70784-M2) with an Orin NX 16GB.
My current setup is:
  • JetPack 6.2.2 / L4T 36.5
  • ZED SDK 5.2.3
  • stereolabs-zedlink-mono 1.5.0-SL-MAX9296-L4T36.5.0
  • Auvidea JNX42-M2
  • ZED Link Mono capture cards
I have followed auvidea flash guide and installed the Jetpack 6.2.2. After that, I installed the Stereolabs driver and held back the nvidia packages. Right after came the SDK installation.
After rebooting, no ZED cameras are detected.
I noticed that the installation added the following to /boot/extlinux/extlinux.conf:
FDT /boot/dtb/kernel_tegra234-auvidea-jnx42+p3767-0000-nv.dtb
OVERLAYS /boot/tegra234-auvidea-camera-zedlink-mono-sl-overlay.dtbo
The Auvidea DTB exists, but the referenced overlay does not:
$ ls -l /boot/tegra234-auvidea-camera-zedlink-mono-sl-overlay.dtbo
ls: cannot access ...: No such file or directory
I also searched the filesystem:
$ sudo find / -type f -name '*auvidea*zedlink*' 2>/dev/null
<no results>
$ sudo find / -type f -name '*zedlink*mono*.dtbo' 2>/dev/null
/boot/tegra234-p3768-camera-zedlink-mono-sl-overlay.dtbo
The ZED kernel modules are loaded:
sl_zedx
sl_zedxone_uhd
sl_zedxhdr
sl_max9295
sl_max9296
However, there are no ZED nodes in the running device tree:
$ find /proc/device-tree -iname '*zed*'
<no results>
and I don’t see any zedx, max9295, or max9296 probe messages in dmesg.
Could someone please confirm whether an Auvidea/JNX42-specific ZED Link Mono overlay for L4T 36.5 should be included with this driver package, or whether there is an additional installation step/package required for the JNX42?
I don’t want to substitute the available p3768 overlay manually, since the CSI/I²C configuration may be different.
Thanks for any guidance.
Hi @csongor.horvath,
Should an Auvidea/JNX42-specific ZED Link Mono overlay for L4T 36.5 ship with the driver package, or does it need a separate install step?
The Auvidea JNX42 is not among the carrier boards supported by the ZED Link driver, so the package does not include a device tree overlay for it. You are right not to use the p3768 overlay: it is made for the NVIDIA Orin Nano/NX devkit carrier, and the CSI and I²C configuration of the JNX42 may be different.
For a compatible configuration, please contact Auvidea support. Alternatively, we can give you access to the GitHub repository with the ZED X Driver source code, together with all the relevant documentation, after a mutual NDA is signed. Would this work for you?
