Zed Link Driver cannot be detected after reflashing
My device is the Zed Box Orin NX 16 GB
The driver I installed was
dpkg -l |grep stereolabs
ii stereolabs-zedbox-duo 1.4.3-LI-MAX96712-ZEDBOX-L4T36.4.0 arm64 NVIDIA Kernel DTB Modified Package by Stereolabs
The output of dmesg
sudo dmesg | grep zedx
[sudo] password for exergame:
[ 3.222328] i2c i2c-9: of_i2c: modalias failure on /bus@0/i2c@3180000/tca9546@70/i2c@0/zedxone_uhd_ser@44
[ 3.222340] i2c i2c-9: Failed to create I2C device for /bus@0/i2c@3180000/tca9546@70/i2c@0/zedxone_uhd_ser@44
[ 3.222348] i2c i2c-9: of_i2c: modalias failure on /bus@0/i2c@3180000/tca9546@70/i2c@0/zedxone_uhd@1a
[ 3.222352] i2c i2c-9: Failed to create I2C device for /bus@0/i2c@3180000/tca9546@70/i2c@0/zedxone_uhd@1a
The output of
sudo ZED_Diagnostic --dmesg
** Please wait for completion… This might take up to 1 minute **
Running GMSL DRIVER Diagnostic : Failed
The Capture card is not plugged or wrong driver installed.
Running Log Kernel Trace (for ZED X) Diagnostic : OK
I have already rebooted my device via sudo reboot and have run sudo systemctl restart zed_x_daemon
Hi Ethan,
Thank you for contacting us.
sudo ZED_Diagnostic -c
