how to solve “[ZED ][Init][Info] Camera opening timeout reached, CAMERA FAILED TO SETUP”.
@machineFPGA have you solved your issue?
If not, please send an email to support@stereolabs.com attaching the report file generated by the ZED Diagnostic tool
I get the same error
@sttamtron the original problem was different.
The connection problems that you are facing in the last few days are generated by an upgrade of the V4L2 kernel driver in Ubuntu.
To fix the problem you must update the ZED SDK to v3.6.5:
