hi! i was previously using a Just-A-Jetson as my main compute, and had a 15pin - 22pin CSI connector between them, this worked well! I transitioned to a slightly different carrier board, which is still a Jetson Orin NX but now only has 15pin CSI ports. Will the ZED capture card + drivers still work with a 15pin to 15pin connection to a jetson?
Hi @adinesh
ARK Electronics is not a partner of Stereolabs, so we cannot guarantee that their devices are compatible with our capture cards and drivers.
I know that other customers used our capture cards with ARK Electronics boards, but we have not received details on the models and the version of the software they used.
Some customers asked to access the ZED X Driver source code to customize it if required.
If this works for you, you ask to sign a mutual NDA by writing a request to support@stereolabs.com
