ZED DUO cannot run Normal
I use a Jetson AGX Orin Platform ,And a ZEDX camera,use ZED DUO CAPTURE CARD,But I can't detect the Camera, seems like the device tree is not OK.
  1. Environment
    • JetPack 6.0
    • L4T 36.3.0
    • Ubuntu 22.04 (Jammy Jellyfish)
    • Kernel 5.15.136-tegra
  2. Driver
    • stereolabs-zedlink-duo_1.3.1-LI-MAX96712-all-L4T36.3.0_arm64
I can’t post files, so I post the content of the diagnostic_Results Here.
Hope to get a Reply , thanks.
“AI Models”: {
“info”: \[
“NEURAL LIGHT DEPTH is not optimized”,
“NEURAL DEPTH is not optimized”,
“NEURAL PLUS DEPTH is not optimized”
“Camera Test”: {
“InternalDevicesCount (GMSL)”: 0,
“InternalDevicesCount (USB)”: 0,
“ZEDCount”: 0,
“ZEDs”: \[
“error”: \[
“**Camera not detected**  Make sure the camera is plugged in or try another USB 3.0 port.”
“Devices”: {
“CorruptedFirmware”: false,
“GMSL driver”: “ii  stereolabs-zedlink-duo                       1.3.1-LI-MAX96712-all-L4T36.3.0             arm64        NVIDIA Kernel DTB Modified Package by Stereolabs\\n”,
“GMSLList”: \[
“USBList”: \[
“USB_path”: “/3”,
“idProduct”: “0x0420”,
“idVendor”: “0x0bda”
“USB_path”: “/4/2”,
“idProduct”: “0x6099”,
“idVendor”: “0x17ef”
“USB_path”: “/4/1”,
“idProduct”: “0x301a”,
“idVendor”: “0x413c”
“USB_path”: “/4”,
“idProduct”: “0x5420”,
“USB_path”: “/3”,
“idProduct”: “0x3549”,
“idVendor”: “0x13d3”
“ZEDDetected”: null,
“notTested”: \[
“Please connect a camera to test the USB connection.”
“GMSL Driver”: {
“dmesg”: {
"DMESG \[DTS\] LOG “: \[
“dmesg: read kernel buffer failed: Operation not permitted”
“DMESG \[MAX9x\] LOG”: \[
“DMESG \[PCA\] LOG “: \[
“DMESG \[ZEDX\] LOG”: \[
“DTB list SLabs”: \[
“board.py”,
“extlinux.py”,
“fio.py”,
“Headers”,
“Jetson”,
“Linux”,
“**pycache**”,
“Utils”,
“zlconfig”
“DTB list original”: \[
“/boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv.dtb”,
“/boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv.dtb.orig”
“Dpkg list Stereolabs”: \[
“ii  stereolabs-zedlink-duo                       1.3.1-LI-MAX96712-all-L4T36.3.0             arm64        NVIDIA Kernel DTB Modified Package by Stereolabs”
“Dpkg list zed”: \[
“Driver list”: {
“/usr/lib/modules/5.15.136-tegra/kernel/drivers/stereolabs/max9295/sl_max9295.ko”: “exists”,
“/usr/lib/modules/5.15.136-tegra/kernel/drivers/stereolabs/max9296/max9296.ko”: “not found”,
“/usr/lib/modules/5.15.136-tegra/kernel/drivers/stereolabs/max9296/sl_max9296.ko”: “not found”,
“/usr/lib/modules/5.15.136-tegra/kernel/drivers/stereolabs/max96712/max96712.ko”: “not found”,
“/usr/lib/modules/5.15.136-tegra/kernel/drivers/stereolabs/max96712/sl_max96712.ko”: “exists”,
“/usr/lib/modules/5.15.136-tegra/kernel/drivers/stereolabs/zedone4k/sl_zedxone_uhd.ko”: “exists”,
“/usr/lib/modules/5.15.136-tegra/kernel/drivers/stereolabs/zedx/max96712.ko”: “not found”,
“/usr/lib/modules/5.15.136-tegra/kernel/drivers/stereolabs/zedx/sl_zedx.ko”: “exists”,
“/usr/lib/modules/5.15.136-tegra/kernel/drivers/stereolabs/zedxpro/sl_zedxpro.ko”: “exists”
“EXTlinux file”: \[
“TIMEOUT 30”,
“DEFAULT Stereolabs”,
“MENU TITLE L4T boot options”,
“LABEL primary”,
"      MENU LABEL primary kernel”,
"      LINUX /boot/Image”,
"      INITRD /boot/initrd”,
"      APPEND ${cbootargs} root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 ",
“# When testing a custom kernel, it is recommended that you create a backup of”,
“# the original kernel and add a new entry to this file so that the device can”,
“# fallback to the original kernel. To do this:”,
“# 1, Make a backup of the original kernel”,
“#      sudo cp /boot/Image /boot/Image.backup”,
“# 2, Copy your custom kernel into /boot/Image”,
“# 3, Uncomment below menu setting lines for the original kernel”,
“# 4, Reboot”,
“# LABEL backup”,
“#    MENU LABEL backup kernel”,
“#    LINUX /boot/Image.backup”,
“#    INITRD /boot/initrd”,
“#    APPEND ${cbootargs}”,
        "LABEL Stereolabs",
        "\tMENU LABEL Stereolabs kernel",
        "\tLINUX /boot/Image",
        "\tFDT /boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv.dtb",
        "\tINITRD /boot/initrd",
        "\tAPPEND ${cbootargs} root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0",
        "\tOVERLAYS /boot/tegra234-camera-tegra234-p3737-sl-overlay.dtbo"
    "I2C Trace list": {
        "I2C Trace /dev/i2C-0": [
            "     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f",
            "00:                         -- -- -- -- -- -- -- -- ",
            "10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
            "20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
            "30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
            "40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
            "50: UU -- -- -- -- -- UU -- -- -- -- -- -- -- -- -- ",
            "60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
            "70: -- -- -- -- -- -- -- --                         "
        "I2C Trace /dev/i2C-1": [
            "00:                         UU -- -- -- -- -- -- -- ",
            "40: UU UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
            "50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
        "I2C Trace /dev/i2C-2": [
            "70: 70 -- -- -- -- -- -- --                         "
        "I2C Trace /dev/i2C-3": [
        "I2C Trace /dev/i2C-6": [
        "I2C Trace /dev/i2C-7": [
        "I2C Trace /dev/i2C-8": [
            "10: -- -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- ",
            "20: -- -- -- -- -- -- -- -- 28 -- -- -- -- -- -- -- ",
            "30: -- -- -- -- -- -- -- -- 38 -- -- -- -- -- -- -- ",
            "50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
        "I2C Trace /dev/i2C-9": [
            "Error: Bus doesn't support detection commands"
    "Jetpack": [
        "# R36 (release), REVISION: 3.0, GCID: 36923193, BOARD: generic, EABI: aarch64, DATE: Fri Jul 19 23:24:25 UTC 2024",
        "# KERNEL_VARIANT: oot",
        "TARGET_USERSPACE_LIB_DIR=nvidia",
        "TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia"
    "Linux_uname": [
        "Linux orbbec 5.15.136-tegra #1 SMP PREEMPT Mon May 6 09:56:39 PDT 2024 aarch64 aarch64 aarch64 GNU/Linux"
    "ZED SDK Version": {
        "Diag": "5.0.6",
        "RT": "5.0.6"
    "ZEDX Daemon Status LS": [
        "● zed_x_daemon.service - ZED-X Daemon service",
        "     Loaded: loaded (/etc/systemd/system/zed_x_daemon.service; enabled; vendor preset: enabled)",
        "     Active: active (running) since Thu 2025-09-18 15:24:55 CST; 42s ago",
        "   Main PID: 5052 (ZEDX_Daemon)",
        "      Tasks: 5 (limit: 74772)",
        "     Memory: 2.9M",
        "        CPU: 66ms",
        "     CGroup: /system.slice/zed_x_daemon.service",
        "             └─5052 /usr/sbin/ZEDX_Daemon",
        "9月 18 15:24:55 orbbec systemd[1]: Started ZED-X Daemon service.",
        "9月 18 15:24:55 orbbec ZEDX_Daemon[5052]: [ \"周四 9月 18 15:24:55 2025\" ][ZED-X Daemon] Using TCP port (Read/Write):  20206  and  20207",
        "9月 18 15:24:55 orbbec ZEDX_Daemon[5052]: [ \"周四 9月 18 15:24:55 2025\" ][ZED-X Daemon]  ** Created Sub Endpoint  \"tcp://127.0.0.1:20206\"",
        "9月 18 15:24:55 orbbec ZEDX_Daemon[5052]: [ \"周四 9月 18 15:24:55 2025\" ][ZED-X Daemon]  ** Created Pub Endpoint  \"tcp://127.0.0.1:20207\""
    "ZEDX Driver State": [
        "sl_zedxone_uhd         36864  0",
        "sl_zedx                28672  0",
        "sl_zedxpro             20480  0",
        "sl_max9295             16384  3 sl_zedxpro,sl_zedxone_uhd,sl_zedx",
        "sl_max96712            24576  4 sl_zedxpro,sl_zedxone_uhd,sl_max9295,sl_zedx",
        "tegra_camera          253952  8 sl_zedxpro,nvhost_isp5,nvhost_nvcsi_t194,sl_zedxone_uhd,nvhost_vi5,sl_zedx",
        "videodev              270336  7 v4l2_async,sl_zedxpro,videobuf2_v4l2,tegra_camera,sl_zedxone_uhd,videobuf2_common,sl_zedx"
    "i2C Trace": [
        "i2c-0\ti2c       \t3160000.i2c                     \tI2C adapter",
        "i2c-1\ti2c       \tc240000.i2c                     \tI2C adapter",
        "i2c-2\ti2c       \t3180000.i2c                     \tI2C adapter",
        "i2c-3\ti2c       \t3190000.i2c                     \tI2C adapter",
        "i2c-4\ti2c       \tTegra BPMP I2C adapter          \tI2C adapter",
        "i2c-5\ti2c       \t31b0000.i2c                     \tI2C adapter",
        "i2c-6\ti2c       \t31c0000.i2c                     \tI2C adapter",
        "i2c-7\ti2c       \tc250000.i2c                     \tI2C adapter",
        "i2c-8\ti2c       \t31e0000.i2c                     \tI2C adapter",
        "i2c-9\ti2c       \tNVIDIA SOC i2c adapter 0        \tI2C adapter"
“Graphics Card”: {
“deviceCount”: 1,
“deviceDriverVersion”: 12020,
“devices”: [
“arch”: “Ampere”,
“computeCapability”: “8.7”,
“cores”: 1024,
“name”: “Orin”,
“totalMemoryBytes”: “65893720064”,
“totalMemoryMB”: 62841.1484375
“glx_info”: “OpenGL vendor string: NVIDIA Corporation\nOpenGL renderer string: NVIDIA Tegra Orin (nvgpu)/integrated\nOpenGL core profile version string: 4.6.0 NVIDIA 540.3.0\nOpenGL core profile shading language version string: 4.60 NVIDIA\nOpenGL core profile context flags: (none)\nOpenGL core profile profile mask: core profile\nOpenGL core profile extensions:\nOpenGL version string: 4.6.0 NVIDIA 540.3.0\nOpenGL shading language version string: 4.60 NVIDIA\nOpenGL context flags: (none)\nOpenGL profile mask: (none)\nOpenGL extensions:\nOpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 540.3.0\nOpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20\nOpenGL ES profile extensions:\n”,
“initResult”: 0,
“valid”: [
“Graphics card: Orin”
“Processor”: {
“L4T version”: “36.3.0”,
“OS”: "Ubuntu 22.04.4 LTS ",
“avxSupported”: false,
“coreCount”: “12”,
“cpu”: “”,
“datetime”: “2025-09-18 15时25分36秒”,
“hyperThreading”: “0”,
“motherboard”: “Jetson, NVIDIA”,
“ramCapacity”: “65.893720”,
“ramUsage”: “”,
“ramUsed”: “3.949556”,
“threadCount”: “12”,
“valid”: [
"Processor: “,
“Motherboard: Jetson, NVIDIA”
“ZED SDK”: {
“CUDA Toolkit version”: “V12.2.140 -->located in /usr/local/cuda-12.2/bin/nvcc”,
“CUDA loading”: false,
“GPU Driver Version”: “Driver Version : N/A”,
“GPU Performance”: " Performance State : N/A”,
“ZED SDK Version (Diag)”: “5.0.6”,
“ZED SDK Version (RT)”: “5.0.6”,
“ai”: {
“checkAI”: true,
“cudaVersion”: 12020,
“cudnnCudartVersion”: 12020,
“cudnnVersion”: 8904,
“cudnnVersionExpected”: 8904,
“tensorVersion”: 8602
“binFiles”: [
“libsl_ai.so”,
“libsl_zed.so”
“resourcesFiles”: [
“neural_depth_5.3.model”,
“neural_depth_light_5.2.model”
“resourcesFilesExpected”: [
“objects_performance_3.2”
“valid”: [
“ZED SDK version: 5.0.6”,
“CUDA version: V12.2.140”
Hi @wangchunyi120
Welcome to the Stereolabs Community.
What AGX Orin Platform do you use?
Please send a picture
