i am using zedx camera and everything was working fine and one day when i run the zed camera it says camera not detected and capture card not plugged in …. my dmesg logs are below … please help …
Created: Mon Dec 22 2025
############ ZED SDK VERSION #############
ZED SDK Version (Diag): 5.1.1
ZED SDK Version (RT): 5.1.1
############ Linux Uname #############
Linux harvested 5.15.148-tegra #1 SMP PREEMPT Mon Jun 16 08:24:48 PDT 2025 aarch64 aarch64 aarch64 GNU/Linux
############ DMESG \[ZEDX\] LOG #############
############ DMESG \[MAX9x\] LOG #############
\[ 13.564842\] sl_max96712: module verification failed: signature and/or required key missing - tainting kernel
############ DMESG \[PCA\] LOG #############
\[ 3.785228\] pca954x 2-0070: probe failed
############ DMESG \[DTS\] LOG #############
############ DTB list original ###########
/boot/dtb/kernel_tegra234-p3768-0000+p3767-0001-nv.dtb
############ DTB list SLabs ###########
board.py
extlinux.py
fio.py
Headers
Jetson
Linux
**pycache**
Utils
zlconfig
############ EXTlinux file ###########
TIMEOUT 30
DEFAULT Stereolabs
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} root=PARTUUID=ba110521-9f2b-4b3c-89b2-77ed8f04e6e1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0
# When testing a custom kernel, it is recommended that you create a backup of
# the original kernel and add a new entry to this file so that the device can
# fallback to the original kernel. To do this:
# 1, Make a backup of the original kernel
# sudo cp /boot/Image /boot/Image.backup
# 2, Copy your custom kernel into /boot/Image
# 3, Uncomment below menu setting lines for the original kernel
# 4, Reboot
# LABEL backup
# MENU LABEL backup kernel
# LINUX /boot/Image.backup
# INITRD /boot/initrd
# APPEND ${cbootargs}
LABEL Stereolabs
MENU LABEL Stereolabs kernel
LINUX /boot/Image
FDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0001-nv.dtb
INITRD /boot/initrd
OVERLAYS /boot/tegra234-p3768-camera-zedlink-duo-sl-overlay.dtbo
############ Jetpack ###########
# R36 (release), REVISION: 4.7, GCID: 42132812, BOARD: generic, EABI: aarch64, DATE: Thu Sep 18 22:54:44 UTC 2025
# KERNEL_VARIANT: oot
############ Dpkg list ###########
ii stereolabs-zedlink-duo 1.3.1-LI-MAX96712-all-L4T36.4.0 arm64 NVIDIA Kernel DTB Modified Package by Stereolabs
/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max96712/sl_max96712.ko==> exists
/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedx/sl_zedx.ko==> exists
/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedone4k/sl_zedxone_uhd.ko==> exists
/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedxpro/sl_zedxpro.ko==> exists
/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9295/sl_max9295.ko==> exists
Active: active (running) since Mon 2025-12-22 14:23:06 IST; 1min 57s ago
Main PID: 5051 (ZEDX_Daemon)
Tasks: 5 (limit: 8808)
Memory: 940.0K
CPU: 216ms
└─5051 /usr/sbin/ZEDX_Daemon
Dec 22 14:23:06 harvested systemd\[1\]: Started ZED-X Daemon service.
Dec 22 14:23:06 harvested ZEDX_Daemon\[5051\]: \[ “Mon Dec 22 14:23:06 2025” \]\[ZED-X Daemon\] Using TCP port (Read/Write): 20206 and 20207
Dec 22 14:23:06 harvested ZEDX_Daemon\[5051\]: \[ “Mon Dec 22 14:23:06 2025” \]\[ZED-X Daemon\] \*\* Created Sub Endpoint “tcp://127.0.0.1:20206”
Dec 22 14:23:06 harvested ZEDX_Daemon\[5051\]: \[ “Mon Dec 22 14:23:06 2025” \]\[ZED-X Daemon\] \*\* Created Pub Endpoint “tcp://127.0.0.1:20207”
############ ZEDX Driver State #############
Note : If the following drivers has a id-state <0, reboot is required
sl_zedxone_uhd 36864 0
sl_zedx 28672 0
sl_zedxpro 20480 0
sl_max9295 16384 3 sl_zedxpro,sl_zedxone_uhd,sl_zedx
sl_max96712 24576 4 sl_zedxpro,sl_zedxone_uhd,sl_max9295,sl_zedx
tegra_camera 217088 7 sl_zedxpro,nvhost_isp5,nvhost_nvcsi_t194,sl_zedxone_uhd,nv_hawk_owl,nvhost_vi5,sl_zedx
videodev 249856 7 v4l2_async,sl_zedxpro,videobuf2_v4l2,tegra_camera,sl_zedxone_uhd,videobuf2_common,sl_zedx
############ I2C Trace \[-l\] #############
i2c-0 i2c 3160000.i2c I2C adapter
i2c-1 i2c c240000.i2c I2C adapter
i2c-2 i2c 3180000.i2c I2C adapter
i2c-4 i2c Tegra BPMP I2C adapter I2C adapter
i2c-5 i2c 31b0000.i2c I2C adapter
i2c-7 i2c c250000.i2c I2C adapter
i2c-9 i2c NVIDIA SOC i2c adapter 0 I2C adapter
############ I2C Trace /dev/i2C-0 #############
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – – – – – – – – – – – – – – –
50: UU – – – – – – UU – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
############ I2C Trace /dev/i2C-1 #############
00: – – – – – – – –
20: – – – – – UU – – – – – – – – – –
40: UU – – – – – – – – – – – – – – –
50: – – – – – – – – – – – – – – – –
70: – – – – – – – –
############ I2C Trace /dev/i2C-2 #############
00: – – – – – – – –
70: – – – – – – – –
> > No bus available at index 3
> > No bus available at index 6
> > ############ I2C Trace /dev/i2C-7 #############
00: – – – – – – – –
70: – – – – – – – –
> > No bus available at index 8
> > ############ I2C Trace /dev/i2C-9 #############
Error: Bus doesn’t support detection commands
> > No bus available at index 10
> > No bus available at index 11
> > No bus available at index 12
> > No bus available at index 13
> > No bus available at index 14
> > No bus available at index 15
> > No bus available at index 16
> > No bus available at index 30
> > No bus available at index 31
> > No bus available at index 32
> > No bus available at index 33
> > No bus available at index 34
> > No bus available at index 35
> > No bus available at index 36
> > No bus available at index 37
> > No bus available at index 38
> > No bus available at index 39
> > No bus available at index 40
