Hi there ![]()
I’m having an issue with an older ZED Box Orin NX 16 GB equipped with the ZED Link Duo capture card.
This system had an earlier installation based on JetPack 6.0 and was upgraded/reinstalled later. After the upgrade, both ZED X cameras are detected correctly, but only one of them can actually be opened.
Current setup:
- ZED Box, Orin NX 16 GB
- ZED Link Duo / LI-MAX96712
- JetPack 6.2 / L4T 36.4.3
- ZED X Driver 1.5.0
- ZED SDK 5.1.2
ZED_Explorer -a detects both cameras:
Cam 0
S/N: 48195837
State: AVAILABLE
Path: /dev/i2c-9
Cam 1
S/N: 48786790
State: AVAILABLE
Path: /dev/i2c-10
The kernel logs also show both cameras and serializers initializing successfully. The MAX96712 detects both ZED X cameras and configures both pipelines:
GMSL #2 : Link Camera zedx (id: 0) to port-index 1
GMSL #3 : Link Camera zedx (id: 2) to port-index 2
Both serializers report Serializer pipeline operational, and all four AR0234 sensor nodes probe successfully.
However:
- camera on
/dev/i2c-10opens and produces an image - camera on
/dev/i2c-9fails when opening - after the failure, Argus can become unresponsive and needs to be restarted
I initially reproduced this with ZED X Driver 1.4.4. I then upgraded to 1.5.0, but the behavior remains the same.
I also made sure the relevant NVIDIA camera/multimedia packages are aligned with L4T 36.4.3.
Since both cameras are detected correctly and the GMSL/serializer/sensor initialization succeeds, I’m not sure whether this points to the CSI/VI configuration for one of the Duo outputs or something left over from the JetPack upgrade.
Has anyone seen similar behavior after upgrading an older ZED Box from a JP6.0-era installation?
Is there a recommended clean upgrade/reinstallation procedure or ZED Box-specific configuration I should check for the ZED Link Duo on L4T 36.4.3?
