I was wondering where can I find the performance (fps) for skeleton tracking for ZED BOX Orin and using one ZED2i camera. Do you have a table of its performance for different resolutions? Does it change if I use POE+ or DC-IN?
Yes, being in POE+ mode can impact the performance as you will have to use the 15W power mode due to the limitation of the POE+ bandwidth.
That will also depend on the detection model used.
For ex, with the Body 38 accurate, you can expect to have around 36 fps whereas with the Body 38 fast model, you will have 60 fps, without fitting enabled.
Those numbers are captured with an Orin AGX powered with DC-IN.
