ZED Box Mini Installation Guide may corrupt system
I just put a Zed Box Mini with a ZEDX attached vis GMSL 2 into operation Following this guide:
It seems that the system update step:
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
is producing an error in the core components (bootloader, kernel, etc.) of the nvidia-l4t system leaving it in error state (the problematic issue is IMHO the output: Warning: Cannot get compatible board name) . In the following steps no camera is shown in the ZED Explorer. When i try to install a GMSL driver the broken installation of the kernel leads to a failure. So I am stuck now. I tried attach the log of the installation as well as the dmesg.log of the ZED diagnostics tool but am not allowed to do it.
How can I make the system work?
Hi @cweigel
Please find the solution in the Troubleshooting section of the documentation:
Thx. That solved the issue. Shall probably be linked in the installation instructions.
NVIDIA should solve that problem, that’s why we’ve not included it in the standard installation guide.
