Zed 360 With Jetson Nano and ZED 2i camera using Network_Workflow is not working properly
I was able to see the stream in zed hub, But while trying to run the ZED 360 with Network_Workflow I was getting this error. I had tried running the zed explorer on Receiver Server but i was not able to get the stream.
INIT FUSION
Unable to subscribe to 36922869 . CONNECTION TIMED OUT
Unable to subscribe to 32482761 . CONNECTION TIMED OUT
START RUN FUSION enableSK
ERROR : WRONG BODY FORMAT
Hi, we currently have an issue with this workflow, because of a very slight patch mismatch (4.0.2 on the ZED Hub app vs the version you have on the receiver). We’ll do different things :
  • Update our ZED Hub app (short term)
  • Make patches compatible (mid term)
    In the meantime, you can use 4.0.2 on the receiver or run your own sender with the version you need.
