We are currently attempting to calibrate four ZED cameras using the ZED360 SDK. However, we are experiencing difficulty obtaining a correct calibration result.
Our setup places the four cameras back-to-back, as shown in the configuration below.
After running the ZED360 calibration, the resulting configuration consistently shows the cameras facing each other instead of facing outward as in the physical setup.
During the calibration process, we tried several variations, including having one or multiple people walk in the room and changing the walking speed from slow to fast to generate sufficient motion in the scene. Despite these attempts, the calibration result remains unchanged.
Could you advise whether this type of back-to-back configuration is feasible for ZED360 calibration? Additionally, any suggestions on how we might modify the calibration pipeline or adjust the ZED360 settings to obtain a correct result would be greatly appreciated.
ZED 360 is not designed to calibrate a multi-camera system providing an inside-out view of the environment. It must be used with outside-in configurations, where all the cameras point at the scene from a different point of view, and they have a huge part of the FoV in common.
We are working on new tools to calibrate systems with a setup similar to yours, but they are not yet available.
Hi @yeweihuang
I have found myself in a similar situation.
Although I am still in the process of trial and error, using a ChArUco calibration pattern might help you achieve the desired results.
The image provided is one example.
I had the similar problem. A ChArUco calibration pattern may help get the desired results.
Thank you for sharing your experience.
A marker-based calibration is a valid alternative to ZED360 when the cameras look at the same area. You can start from our zed-aruco multi-camera sample.
This approach requires the pattern to be visible to two or more cameras at the same time. With a back-to-back, inside-out configuration like the one described in the first post, the cameras do not share a field of view. A single board cannot link their poses that way.
As mentioned above, we are working on new tools for this kind of setup. Feel free to share your results here; they can be useful to other users.
